Old Aug 05, 2012, 04:08 PM
Verid is offline
Find More Posts by Verid
Joined Jan 2009
http://en.wikipedia.org/wiki/Duszatyn
It used to be quite large village before war with 100+ houses, church, school, inn, sawmill and train station. Now it's only 3 houses, barrack for woodcutters, small bar for tourists and remnants of camping field.
Verid is offline Find More Posts by Verid
Old Aug 05, 2012, 06:52 PM
Stantheman is offline
Find More Posts by Stantheman
Stantheman
LaGrange, Ky.
Joined May 2004
I want to move there! Do they speak Kentucky?
Stantheman is offline Find More Posts by Stantheman
Old Aug 05, 2012, 08:03 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
hey guys dont forget to pitch in some infos here
http://www.rcgroups.com/forums/showthread.php?t=1687469
nakelp86 is offline Find More Posts by nakelp86
Old Aug 06, 2012, 12:11 PM
Verid is offline
Joined Jan 2009
Stantheman - they speak every language in the universe when treated with appropriate amount of alcohol.
nakelp86 - already did.
Old Aug 06, 2012, 07:27 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Lol
Old Aug 07, 2012, 07:25 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Quick question to anyone else using the std folding prop.... is yours as rattly as mine? I've just checked out some keycam footage from my EZII and the prop is making a constant clattering like a terrified skeleton.....
Colonel Blink is online now Find More Posts by Colonel Blink
Old Aug 07, 2012, 03:44 PM
Mehari is online now
Find More Posts by Mehari
Joined Aug 2008
I am running the standard prop with a 1200kv NTM PropDrive 28-26 motor mounted inside the tower.
The noise of the power train is distinctive but I am not sure that I would describe it as a clatter. I haven't noticed anything unusual in camera sound recordings although wind noise tends to mask things a lot.
After reading your comment I checked the play of the prop halves on their shafts and this is certainly more than I would have expected but no more than a couple of other HK folders that I have.
Mehari is online now Find More Posts by Mehari
Old Aug 07, 2012, 04:12 PM
Verid is offline
Joined Jan 2009
I used stock prop for maiden only as I wasn't happy with it's power output but I didn't notice any excessive noise.
Old Aug 07, 2012, 05:48 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Mine is not rattly. This is with KeyCam 808 #16:
MPX EasyStar 2 unedited. Highs @ 5:44 (Skywalker) and 7:33 ( ultra low pass) (9 min 59 sec)
mike_o is online now Find More Posts by mike_o
Old Aug 08, 2012, 01:37 AM
scrtsqrl is online now
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
http://youtu.be/Ra0IsWTepZU
Can you disable the 808-16's date/time stamp?
scrtsqrl is online now Find More Posts by scrtsqrl
Old Aug 08, 2012, 01:45 AM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Yes, it's off topic, but you can do it
Make the camera write a config file to the memory card, wordpad edit a single character in the file, make the camera upload the edited file, and you're done. Takes 3 minutes. Procedure is well described in manual and in the dedicated Tom Franks' "The new 808 #16 keychain camera" thread
Old Aug 13, 2012, 09:13 AM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
Maidened my ESII yesterday! It flew great!
I'm not very good at hand launching yet and had a close call. I was late on the up elevator after my toss. After that experience I programmed a mix to give me up elevator on a switch. Once in the air, I turn the mix off.
The gear:
Motor: Value Hobby E400 1200kv (perfect fit)
http://www.valuehobby.com/gforce-e400-2830-1200kv.html
Battery: GForce 3s 2200mAh
ESC: Castle Phoenix 25
BEC: Castle 10A
Servos: (4) Hitec HS-55's
Rx: Spektrum AR600
Performance was great. I'm getting about 150W. 12.5A full throttle. After 7 minutes I had 4.0v/cell so, flight times are great. Can't wait to get back out with this one.
-Rocko
rockom is offline Find More Posts by rockom
Old Aug 13, 2012, 10:03 AM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
The gear:
BEC: Castle 10A
Rx: Spektrum AR600
-Rocko
great news, chip in here if you dont mind
Old Aug 15, 2012, 09:19 PM
Commander Clumsy is offline
Find More Posts by Commander Clumsy
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
I followed the whole thread and yet I don't seem to remember if the wings of the ES 1 will fit the fuselage of the ES 2..
Did anyone try this yet?
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Aug 16, 2012, 01:40 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
As both models use the same wing/wing section, it should be fairly easy to fit an EasyStar wing onto an an EasyStar II. The "notches" in the wing (front and rear) may need to be slightly modified.
But why would you want to put an EasyStar wing on an EasyStar II? For those wanting ailerons, an EasyStar II wing on an EasyStar would make more sense.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
