Old Jul 26, 2012, 04:28 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Originally Posted by Colonel Blink View Post
For instance, a PA28 will mush with the yoke pulled right back into your stomach whether flown in balance or out of balance
If your gut is the size of your avatar that's really not that for is it
Seriously though it's an interesting conversation and I can see both sides. It would be interesting to use the rate switch and experiment with both sides of the argument.
Aviefly is offline Find More Posts by Aviefly
Old Jul 26, 2012, 04:51 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by Aviefly View Post
If your gut is the size of your avatar that's really not that for is it.
It is and now I am deeply offended by your callous remark................!!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 26, 2012, 05:09 PM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
....Your comment about correcting the wing drop at stall with the ailerons is interesting. At the stall, the wing drops because one wing stalls before the other (often due to not flying perfectly balanced or directly into wind). Trying to pick it back up with ailerons means that the aileron on the 'dropping' side goes down, increasing the effective angle of attack. This will put that wing deeper into the stall, and in full size flight is a well known killer when it happens low down. Pilot training drills into you that when a wing drops in a stall, you pick it up again with rudder, not aileron. Basically you accelerate the stalled wing by yawing away from the dropping wing....
Col,
very true, but probably due to the fact that Jürgen points out (our models picking up speed fast), it just seems so much easier to control the plane. I fly my ES2 FPV, and as you don't get a good feeling of the airspeed through a set of FatSharks, you will just feel/see controls getting sloppy, and typically a wing (and nose) drop shortly afterwards. The plane is easily "caught" after that with the right (aileron+20%rudder/elevator) stick. You'll see, when get the ailerons going.
Just to go off topic on the stall/spin discussion for a sec; The most challenging 1:1 plane, I have flown is the Zlin Z242, which I did an aerobatic course on a few years ago.
Prior to a spin exercise, the instructor introduced me to the general spin habits of that particular plane by stating: "The Zlin has 3 surprises for you:
1) When she starts spinning, she'll go instantly inverted.
2) When you try exiting the (inverted) spin (by applying opposite rudder), nothing will happen... For 360 degrees, THEN the spin will stop.
3) The last surprise is that, when the spin stops, the plane will immediately start spinning in the opposite direction if you haven't removed opposite rudder at the exact right moment...
Great plane to fly, but quite a handfull for me
mike_o is offline Find More Posts by mike_o
Old Jul 26, 2012, 11:37 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Ah, I understand the point you are making now, Jürgen! But I'm not sure that being able to get an aircraft (model or full size) to gently 'mush' down at minimum speed, rather than drop the nose or wing in a pronounced or even sudden stall is purely a factor elevator throw.
Personally, I won't be reducing the elevator throw to less than the recommended amount - I only put it into the stall as part of a (normal) initial flight program. Know thy enemy!
Of course elevator throw is not the only criteria here. You also need a design, which is basically very stable and forgiving - like the EasyStar.
It makes however not much sense - for a beginner model - to have bigger elevator throws, than what it takes to stall the modell (3D models on the other hand sometimes use to 90°, but for different reasons). You don't want a beginner to stall unintentionally.
CG and control surface throws are also a matter of personal preference. The more forward you have your CG, the quicker you will run out of elevator authority. Beginners tend to over-control the model by big stick inputs. Experienced pilots sometimes prefer to control their models with small stick movements, being able to throw the model into a snap or a spin instantly by moving the stick into a corner.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 27, 2012, 05:27 AM
Joined Sep 2000
Know the basics ...
Quite amazing, that those basics are not widely known/understood. They pop up from time to time however:
http://www.rcgroups.com/forums/showp...postcount=1188
Jürgen
Old Jul 27, 2012, 04:22 PM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Water landing...will it work in stock form?
I was wondering how feasible a water landing with a stock ES ll would be
Assuming that I seal the rear antennae tube, tape over the entire fuselage seam, and shield the front air intake, I gues no water would enter the hull, ahem, I mean fuselage
The aileron servos may be a little exposed as the one in the lower wing would sit only 2-3 cm above water.
Did anybody try it?
Old Jul 27, 2012, 11:32 PM
vascoboy is offline
Find More Posts by vascoboy
United States, CA, SF
Joined Apr 2011
prop recommendation w/ Emax BL2220-07
I also will be using Terry's (CNC Small Parts) motor mount...I am looking for a quiet set up, so looking to prop w/ 8" or 9"...is it possible to use a folding prop? my thinking is that it will reduce drag...
thanks,
christian
vascoboy is offline Find More Posts by vascoboy
Old Jul 28, 2012, 01:12 AM
Joined Sep 2000
Not much difference between an EasyStar and an EasyStar II here:
Water landing the Multiplex EasyStar (0 min 44 sec)
Jürgen
Old Jul 28, 2012, 01:15 AM
Joined Sep 2000
thanks,
christian
The stock setup with the 7x6" folder is already fairly quiet and low drag. Using above add-on motor mount will increase the drag. Even when using a folding 8" or 9" prop, the drag will be higher than stock.
Jürgen
Old Jul 28, 2012, 03:07 AM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Jürgen
Haha - very nice. I have to try that
Thanks for the link!
Old Jul 28, 2012, 08:24 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
http://www.youtube.com/watch?v=7Uh3wKn0Pis
Jürgen
Cool.
If it had some way to "unstick" the wing tip from the water, you can probably take off too...Perhaps a small skid made out of Popsicle sticks...hmmm...
I guess one can always pick it up and throw it...lols...
Thanks.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jul 28, 2012, 10:34 AM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
HeadsUp motor for in pod mount
thanks,
christian
Christian
HeadsUpRC recommends the following motor as the "behind the firewall" mount option to the one you mention. It's 36.5 mm long, though.
Emax GT2218/11
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Jul 28, 2012, 05:33 PM
Thermal Hobby is offline
Find More Posts by Thermal Hobby
Joined Dec 2010
sounds like a himax motor
Thermal Hobby is offline Find More Posts by Thermal Hobby
Old Jul 28, 2012, 07:26 PM
USA, IL, Wheaton
Joined Oct 2010
Thermal Hobby
It's not
http://www.headsuprc.com/servlet/the...ushless/Detail
Old Jul 29, 2012, 12:45 AM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
. I have an ES 2. Does anybody know if the easy star 1 canopy and the ES 2 canopy are the same? I want to chop the canopy to mount a gopro so I want a spare for when I fly without a camera. I don't think parts for the 2 are available yet.
Lammergier is offline Find More Posts by Lammergier
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
