Old Jul 19, 2012, 12:43 PM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
GForce Motor
I'm going to try this motor with a Castle Phoenix 25 or 36. Stock folding prop.
Specifications:
KV: 1200
Shaft Diameter(mm): 3.17
Stator Diameter(mm): 22
Stator Length(mm): 12
Weight(g): 56
Outside Diameter(mm): 28
Body Length(mm): 31
Load Current(A): 22
Unload Current(A): 1
Max Power(W): 200
Thrust(g): 300-1000
http://www.valuehobby.com/gforce-e400-2830-1200kv.html
-Rocko
rockom is offline Find More Posts by rockom
Old Jul 19, 2012, 12:44 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Jürgen
Thanks for the additional information about the mount. It favors the option A I mentioned.
Finding the right motor in the U.S., not being capable of following the instructions, is the real problem. Has Multiplex come out with a list of appropriate motors, with the shaft already through the fixed end, that are readily available in the U.S.? I've seen the Mike Mayberry post about the Cobra from Innovative Designs.
Rocko's choice above seems the answer to Texas Buzzard's question.
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Jul 19, 2012, 03:36 PM
skyhawk1 is offline
Find More Posts by skyhawk1
United States, WV, Calhoun
Joined Nov 2004
Specifications:
KV: 1200
Weight(g): 56
Body Length(mm): 31
Load Current(A): 22
Max Power(W): 200
Thrust(g): 300-1000
-Rocko
I am having a hard time understanding these outrunners. Why did you choose the E400 verses the E450? The E450 looks to me to be the better choice. Thank you for any insight into your choice.
Todd
skyhawk1 is offline Find More Posts by skyhawk1
Old Jul 19, 2012, 03:47 PM
rockom is offline
rockom's Avatar
Joined Jan 2004
Todd
Todd,
I think the E450 would work just fine as well. My target was a 175W~200W solution similar to the motor suggested in post #520 or #684. The E450 is a 250W motor.
So between the two, the E400 should get better flight times at lower peak current and the E450 will have a little higher performance at the expense of flight time and current draw.
-Rocko
Old Jul 19, 2012, 04:07 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Todd
Todd,
The E450 is 36mm in length. The E400 is 31mm, which is much closer to the 30mm specified by Multiplex. The E400 will also operate more efficiently.
Joe,
Ebay is flooded with 2830mm 1000KV outrunners with the shaft in the right end of the motor. The price range is from $10 (incl worldwide shipping) to $30.
Try searching "2830 outrunner" and see what you get!
NOTE: I found that I get very different search results (from the exact same search words) on different ebay sites (Ebay.com, Ebay.de, Ebay.co.uk, etc) even if I check the "Worldwide" box.
I've just flown my $9 (incl ship.), 2826 1000KV outrunner fitted ES ll for more than 1 hour FPV skysurfing. I must have put at least 6 hours on that motor now, and it runs absolutely fine. I have just ordered a 2830 1000KV (at $11 incl ship.) from the same vendor, to see if I can get a better climb rate. After I started skysurfing, I can't get up there quickly enough
mike_o is online now Find More Posts by mike_o
Old Jul 19, 2012, 04:48 PM
USA, IL, Wheaton
Joined Oct 2010
Thanks Mike_O
That's probably the information that should have come out in the first place to Texas Buzzard. Hopefully, he isn't too loyal to his local hobby shop. Some of us retired folks try to stay away from the temptations of E-Bay as much as we can.
Oh well, He can always buy an AXI 2212/20 Gold Series from Hobby Lobby at $89.95 a pop.
Joe
Old Jul 19, 2012, 04:53 PM
rockom is offline
rockom's Avatar
Joined Jan 2004
Originally Posted by DuPageJoe View Post
Thanks Mike_O
Joe
Joe,
Value Hobby is just around the corner from you in Bensenville. He allows "warehouse pickup". Or, shipping is only $3.99 in the lower 48.
I like my LHS but I can't even get their for $3.99.
-Rocko
Old Jul 19, 2012, 05:05 PM
USA, IL, Wheaton
Joined Oct 2010
Thanks Rocko
That shipping is a bargain. Chicago is pretty spread out. Bensenville is a 2 gallon round trip for me.
One thing Mike_o didn't emphasize when recommending the 400 over the 450, is the increased possibility of wire chafing from the longer rotating motor bell inside that pod. Look at the schematic of the motor mounting procedure and see the wires clipped to the inside of the pod. Best to stick to the one nearest the specified length.
Joe
Old Jul 19, 2012, 05:12 PM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
...Some of us retired folks try to stay away from the temptations of E-Bay as much as we can....
Joe
Joe,
I know exactly what you mean, and I'm not retired yet :-) I'm just waiting for the first scientific study to disclose what some of us already strongly suspect: That Ebay is as addictive as gambling
Well, just to get back on topic: After todays flight, I just have to say how pleased I am with the ES ll as a FPV plane. First of all it's so good natured, that when the video feed disappears (or the cloud gets too dense (no OSD)), I just let go of the sticks, and when the feed returns, the plane is just gliding happily along. Secondly, it's a very efficient bird, I power it upwards for 5-8 minutes at full throttle, reach the cloud base, and then soar almost forever. Finally, the "pack it into the box" - feature makes is so much more convenient. It lives in my trunk together with a small sports bag containing Tx, LiPos, and FPV gear. From I park the car till the plane is in the air takes less than 6 minutes
Old Jul 20, 2012, 11:08 AM
USA, IL, Wheaton
Joined Oct 2010
Originally Posted by Jurgen Heilig View Post
Well, if a modeler has problems mounting an electric motor in a plane, i.e. in this case following an illustrated instruction manual and using two machine screws, he (or she ) may have chosen the wrong hobby.
Jürgen
Before you make strident remarks like this, you should look at Texas Buzzard's stable of planes from 2008.
http://www.rcgroups.com/forums/showthread.php?t=770578
Joe
Old Jul 20, 2012, 12:23 PM
HBFP NL is offline
Find More Posts by HBFP NL
Kingdom of The Netherlands
Joined Nov 2009
OT Please
HBFP NL is offline Find More Posts by HBFP NL
Old Jul 21, 2012, 03:24 AM
foamybuilder is offline
Find More Posts by foamybuilder
India, Karnataka, Bengaluru
Joined May 2011
I tried NTM 3530 outrunner with 8x4 prop (with the small parts mount)
My plane is 1200grams with fpv setup. Had to give full throttle during the takeoff.
Not sure i have to move to a 9x4 prop.
foamybuilder is offline Find More Posts by foamybuilder
Old Jul 21, 2012, 11:48 AM
mwoneal is offline
Find More Posts by mwoneal
United States, CO, Denver
Joined Apr 2012
EasyStar Build Complete
Finished up the build of my Easy Star II. This was my first kit build, took a while, but I'm pretty happy w/ the results. My skill w/ duct tape is beginner, I ended up w/ a number of creases in the tape trying to work around curves. At least it's visible, and should be protected for landings. Hoping to maiden it this weekend.
Any tips for using the ailerons on the EasyStar? Are they primarily for keeping wings level, or can be used for 'bank and yank' turning?
mwoneal is offline Find More Posts by mwoneal
Old Jul 21, 2012, 04:22 PM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Originally Posted by mwoneal View Post
.........Any tips for using the ailerons on the EasyStar? Are they primarily for keeping wings level, or can be used for 'bank and yank' turning?
Nice color scheme!
The ailerons makes a huge difference in performance, do fit them! The only real way to turn a plane is to bank it, and the EasyStar without ailerons will also bank when turning (as inner wing speed decreases and outer wing wing speed increases when turning by rudder), but the rudder induced turn is hesitiant and wobbly compared to the aileron/elevator turn. I flew my ES2 with rudder only a couple of flights, and while it's doable, I'm not going back there if I can avoid it.
Couldn't you fit the motor inside the pod? There's just been a discussion on this in the thread - look back a few posts to see.
EDIT: Just saw your previous post on the motor shaft. I'd probably just skip the clip, and add a couple of washers or a spacer between the prop and the motor bearing to take up the thrust. Place the small, original washer next to the bearing to ensure that the thrust vectors into the inner, rotating part of the bearing only.
Good luck on the maiden!
Old Jul 21, 2012, 04:35 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by mike_o View Post
The only real way to turn a plane is to bank it, and the EasyStar without ailerons will also bank when turning (as inner wing speed decreases and out wing wing speed increases when turning by rudder)
At the risk of being labelled pedantic, the major reason that the bank is induced is not due to the relative speeds of the wings - though that does assist.
Every control on an aircraft (model or full size) has a primary and a secondary effect. The primary effect of using the rudder is yaw. When an aircraft with dihedral yaws, the yaw actually increases the effective angle of attack of the forward going wing, thereby increasing the lift on that side. Thus a bank is induced. Hence roll is the secondary effect of using the rudder.
Obviously, relying on the secondary effect of a control is far less positive and efficient than using the primary effect of the ailerons to do the same job. But personally, I have not found flying the EZII R/E/T wobbly at all - on the contrary I have found it smooth and stable.
Colonel Blink is online now Find More Posts by Colonel Blink
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 08:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 03:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 04:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 04:11 PM
