Old Jul 12, 2012, 10:17 AM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by Colonel Blink View Post
I think it's safer to the check before the model is in the air, Bob!
Ya Scott should have done that before he maidend his p-51.
Or his first and last flight with his first Radian.
eckace1 is offline Find More Posts by eckace1
Old Jul 12, 2012, 03:13 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
And even when you think you got everything right ... :
Last Flight of Kevin's YAK-54 (1 min 29 sec)
This is hopefully my only "off-topic" reply - please try to stay on-topic.
There is a reason why beginner models are usually not made from wood anymore.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 12, 2012, 04:40 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Originally Posted by eckace1 View Post
Mybe I'm doing it wrong but for me I push up on the tx and the plane goes down
I pull down on the stick and the plane goes up.
Oh man... that explains why I keep crashing so much!!! Ok... new method, up/down, down/up... got it!!!!
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Jul 12, 2012, 07:30 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
What would you guys use as a connector so I can disconnect my lighting when I remove the wings. It is rbg lighting so it has 4 wires
rcrich is offline Find More Posts by rcrich
Old Jul 13, 2012, 05:09 PM
Verid is offline
Find More Posts by Verid
Joined Jan 2009
2 simplest options:
1)go to nearest electronics shop and get male and female single row goldpin connector and some heat shrink tubes. Very light connector but no reverse polarity protection so double check when you plug in your lights.
2)go to nearest hobby shop and get green Multiplex connector. It has 6 pins, is keyed so no way to connect it wrong but much heavier than goldpin and harder to disconnect.
Verid is offline Find More Posts by Verid
Old Jul 13, 2012, 06:47 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
check here first:
http://www.hansenhobbies.com/products/connectors/
or here
http://www.rctimer.com/index.php?gOo...9&productname=
nakelp86 is offline Find More Posts by nakelp86
Old Jul 14, 2012, 08:17 AM
mwoneal is offline
Find More Posts by mwoneal
United States, CO, Denver
Joined Apr 2012
The power system, servos, and Rx came in this week. This the first kit I've put together, so I assembled everything and bound the Tx to it to ensure it all worked together. This is my first experience w/ a brushless motor, those things are stealth quiet! Waiting on the Small Parts CNC Easy Star ii motor mount to arrive, and then its build time.
mwoneal is offline Find More Posts by mwoneal
Old Jul 14, 2012, 10:13 AM
skyhawk1 is offline
Find More Posts by skyhawk1
United States, OH, Corning
Joined Nov 2004
No ailerons?
What are the components of the various systems?
skyhawk1 is offline Find More Posts by skyhawk1
Old Jul 14, 2012, 10:55 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Servos?
Terry has some nice motor mounts :-) and ships them out PDQ
I don't see 4 servos ?? For sure ya need to have Ailerons - makes this plane much easier to fly with that small Rudder ... ...te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Jul 14, 2012, 11:41 AM
mwoneal is offline
Joined Apr 2012
Originally Posted by skyhawk1 View Post
No ailerons?
I did get 4 servos to setup the ailerons, the two in the photo are actually connected with the Y harness.
Radio - Spektrum DX4E and AR600
Prop - Stock
Motor - http://www.headsuprc.com/servlet/the...0-Sport/Detail
ESC - http://www.headsuprc.com/servlet/the...-22-Amp/Detail with programming card
Servos - http://www.headsuprc.com/servlet/the...-dsh-55/Detail
Battery - http://www.headsuprc.com/servlet/the...-30C-EZ/Detail
Mark
Old Jul 14, 2012, 07:17 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Welcome every one to chip in to this thread:http://www.rcgroups.com/forums/showthread.php?t=1687469
Jurgen,
could you post the link on the first page and chip in to it :-))
Old Jul 14, 2012, 07:55 PM
skyhawk1 is offline
Joined Nov 2004
Prop - Stock
Mark
I am trying to understand why you need a special motor mount to use this motor on your EZ 2. What am I missing.
Thank you. Todd
Old Jul 14, 2012, 10:06 PM
mwoneal is offline
Joined Apr 2012
Thank you. Todd
As it turns out, I don't need one. When I first pulled the c-clip off the Power-Up 400 and took the motor apart, there was only one groove on the shaft for the c-clip, meaning the shaft could only be configured for 'standard' forward facing mounting. I had already ordered the mount, and out of curiosity emailed Heads Up's customer service this morning to confirm the shaft was non-reversible. They said the stock Power Up 400 was not reversible, but that the shaft from their Fire Power 400, which does support reverse mounting for pusher installation, could be installed on the Power Up 400.
In any case, I received the mount, and it is extremely high quality. And it has 3 mounting positions allowing up to a 9 inch prop to be installed. Probably not necessary, but what are gadgets without options
Old Jul 15, 2012, 03:37 PM
Asheville,NC
Joined Jun 2002
Ez* ii
My Easy is done now
APC SPORT 6 X 4
GO BRUSHLESS 2505-2535
SMALLPARTSCNC Motor Mount
Magnets in Wing root
Carbon Rod in Elev for stiffness
Will Put Extreme tape on bottom of Fuse , for landing on grass
Added an Carbon Rod that slides inside supplied glass spar - that go further out in wing , for added stiffness ..
...............te
Old Jul 15, 2012, 04:20 PM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
If this has been answered please accept my apologies for asking but I did a search and couldn't find the answer.
Does this power system still work for the Easy Star II?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVF5&P=X
Curtis
Montana
Curtis Suter is offline Find More Posts by Curtis Suter
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
