Old Jul 05, 2012, 10:23 AM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
That motor was recommended for the original EZ Star although it should be okay with the V2 but on a 2S Lipo, not 3S unless you use a smaller prop.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Jul 05, 2012, 02:20 PM
EBerris is offline
Find More Posts by EBerris
Minneapolis, MN and Durango, CO
Joined Apr 2002
Mike you are correct sir and your solution of running a 2 cell pack will do the job. That combination produce 175 watts of power. With a 3 cell pack it produce 375 watts but the life of the motor and flight times would be significantly reduced so two cells is what I will use.
Thanks for your input.
Ed
EBerris is offline Find More Posts by EBerris
Old Jul 05, 2012, 03:08 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Well I finally maidened my EZII....sort of.......well yes.....finally.
With the ludicrous weather we've been having here in the UK the combination of my availability and the weather being suitable for maidening a new model has meant I've been waiting weeks.
Trudged (squelched) up onto the moor, and put the model together, making trebly sure that the elevator was securely connected. Range check, corrected the elevator trim so the elevator was neutral (hmmm...must have changed with removing the tailplane and replacing it), control check, one third throttle, throw.......
........into a severe nose dive and crash!!
I immediately realised what was wrong - pilot stupidity!!! I had left the tranny on Model 1 (EZI) not Model 2 (EZII). This meant that the elevator was reversed and caused the crash. The doubly stupid thing was that I hadn't noticed when doing my control check that it was reversed. The triply stupid thing was that I hadn't even noticed when retrimming the elevator (and that's the reason I had to retrim....).
The fuz halves joint at the front had come apart, and the battery had tried to come out the front. There is a slight misshape, but not much. I had used double sided tape - if I had glued, would it have caused more damage? The underside had packing tape on it. Moved the battery back, squeezed the fuz back together (after a fashion) and RESET THE Tx!!!!!!!!!!!
Next flight was much better - it doesnt climb like an EZ1 on a 2700kV inrunner on 3S, but definitely better than a std EZ1. It gains height quickly and without fuss. It is also very quiet - just the thing for flying at 6am!!. It flies very smoothly & gracefully - most relaxing!!! However, the surprise for me was the fact that it (well, mine) drops a wing quite markedly in a stall. I tried three times, and three times it dropped. Not viciously, and as soon as you relax the back pressure it flies again - but by then you can be 90 degrees off your original heading. Be ready!
After less than 5 mins, the stupid 2012 summer weather meant we went from cloudy but warm evening to big, very wet, drops of rain - and my model was still at 250ft or so!! I brought it in for its first landing in heavy rain on a long, slow final towards me. By the time I got to the car, it was thunder & lightning and I was soaked!
Oh and that nice glossy box doesn't stand up to getting wet very well.....
Colonel Blink is online now Find More Posts by Colonel Blink
Old Jul 05, 2012, 03:41 PM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
mike_o is offline Find More Posts by mike_o
Old Jul 05, 2012, 04:40 PM
Mehari is online now
Find More Posts by Mehari
Joined Aug 2008
Your description of the Ilkley weather brought back memories from a LONG time ago.
My Wife and I lived above Middleton Woods on the edge of the moor for 12 months. The weather often changed from clear blue sky at 8am to cloudy with rain at midday and back to clear weather again before dark. Made outdoor activities quite a challenge.
Mehari is online now Find More Posts by Mehari
Old Jul 05, 2012, 09:37 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Sir Blink, is this legal over there ?
BERLIN [german version] (3 min 4 sec)
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Jul 05, 2012, 09:50 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Why would you want to wade through a swamp with tall weeds and fly?
That great inovation made things better I see
eckace1 is offline Find More Posts by eckace1
Old Jul 06, 2012, 12:23 AM
Joined Nov 2008
I doubt that that sort of thing is legal anywhere, and is the sort of thing that will get FPV banned, and likely the rest of RC flying fall under far stricter controls. And will that guy care about the millions of people who are affected? No - the same as he couldn't give a tinker's cuss about those in the cars who his flying may injure in the ensuing accident should he have some sort of catastrophic failure of his model/system. I'm all for freedom, but that flight seemed to ignore some basic common sense.
To keep away from those who complain about anything and everything.
Bob - I presume that you are clumsily referring to the removable tailplane? Well, if you read my post you will see that that had nothing to do with the reversed elevator issue. It was purely my own non-application of what little intelligence I have been blessed. I'll admit that for the price Multiplex charge, I should have expected self-loading tailplane and wings and full 360 degree airbags, but then a fool and his money are easily parted, eh???
Old Jul 06, 2012, 05:51 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
I to would keep away from Scott he is a bad influence.
I Might try and talk Scott into purchasing a 2 but was wondering if you could eliminate the tiny parts that are for the removal of the tail feathers and just glue it in place ?
That way we could compare the 2.
You still need to look at the other plane Scott has talked to you about
I would think you could with the great engineering of mpx
Old Jul 08, 2012, 11:25 AM
mwoneal is offline
Find More Posts by mwoneal
United States, CO, Denver
Joined Apr 2012
Picked up an Easy Star II kit at the LHS this week, only one they had in stock. Been researching power system this weekend, lots of (mis)information out there to sort through! This is my first ES platform, so trying to duplicate stock power system and get it here quick. Looking at this motor/esc combo, any thoughts?
http://www.headsuprc.com/servlet/the...0-Sport/Detail
http://www.headsuprc.com/servlet/the...-30-Amp/Detail
mwoneal is offline Find More Posts by mwoneal
Old Jul 08, 2012, 12:22 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Ok guys, since this thread will have hundreds of pages soon may I suggest starting new thread committed only to electronics, power settings (motors, ESC, FPV equipment etc.)
It is very hard here to find anything specific and sort through hundreds of chit-chat talk posts. Its been done with Skywalker and we could model the posts as here:
http://www.rcgroups.com/forums/showthread.php?t=1494373
This way we could avoid answering/repeating same questions over and over again by simple redirecting these questions to the specific thread.
It could be combined with Bixler and Skysurfer as the planes are virtually very similar.
nakelp86 is offline Find More Posts by nakelp86
Old Jul 08, 2012, 01:01 PM
ANK3RS is offline
Find More Posts by ANK3RS
ANK3RS's Avatar
United Kingdom, England, Staffordshire
Joined Jul 2012
ES II RTF will be available in the UK next month "August" think i might hang out until then £200 not bad considering you get the SMART SX M-LINK TX & RX.
Greetings Modellers my 1st post
ANK3RS is offline Find More Posts by ANK3RS
Old Jul 08, 2012, 02:58 PM
Joined Nov 2008
Originally Posted by ANK3RS View Post
.... £200 not bad considering you get the SMART SX M-LINK TX & RX.
....wait until Bob reads that - then you'll hear some new words!!
Welcome, Ank3rs - hope you've brought your sense of humour!!!
Old Jul 08, 2012, 04:27 PM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Seems to be very close to the recommended set up. I doubt if 1050KV will make any difference from 1000KV.
Old Jul 08, 2012, 04:55 PM
Asheville,NC
Joined Jun 2002
Col Blink
I have a shinny new EZ* II box , that I would behappy to share with you
I won't need it, soon as I get this EZ togeather ..
...............te
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
