Old May 09, 2012, 12:00 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Thanks - the Leeds depot is about 16m away, so doable if I'm at work......
Colonel Blink is online now Find More Posts by Colonel Blink
Old May 09, 2012, 08:36 AM
RCITGuy is offline
Find More Posts by RCITGuy
RCITGuy's Avatar
United Kingdom, Croydon
Joined Feb 2010
Electricwingman and DPD are grat, surely they can just deliver to you at work :-)
RCITGuy is offline Find More Posts by RCITGuy
Old May 09, 2012, 09:13 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
In my hunting for an EZ * II, it looks like some places are sold out of the EZ * in preperation for the EZ* II.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old May 10, 2012, 01:33 AM
Murocflyer's Avatar
Joined Nov 2005
No word baxk from Horizon today. If I don't hear from them in the morning I'll give them a call. I'll check to see when they expect to get them in, how much they will cost and see if I can pre-order one. Maybe I can get a pre-order discount.
Now I just need to figure out what glue and servos are best to use.
Frank
Old May 10, 2012, 01:56 AM
Joined Nov 2008
Ordered mine from Electricwingman last night; plus 4 x HS55s. Personally never had an issue with Hitec servos, and they are 28 for 4, as opposed to 49.36 for the MPX ones.....
Less than a ton for kit, servos & P&P.....
Old May 10, 2012, 02:19 AM
Murocflyer's Avatar
Joined Nov 2005
Cool! Looking forward to your photos and review.
I believe I am going to use HS-65HB for my servos and I read in the other thread that medium CA and CA kicker is best for bonding the EZ * together. That is assuming the faom is the same on the original and the EZ*II.
Frank
Old May 10, 2012, 04:27 AM
McMoron is offline
Find More Posts by McMoron
Joined Dec 2007
Mulitplex was aquired by Hitec some years ago, chances are MPX servos are rebranded Hitecs... Personally, in a docile plane like this I wouldn't hesitate going for HXT900.
McMoron is offline Find More Posts by McMoron
Old May 10, 2012, 05:26 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Frank, medium CA (non-foam safe) and kicker work really well. One thing you might consider is joining the fuselage halves with double sided tape. I bought a big roll from a craft shop for couple of dollars. The "tape" is actually just a wafer thin strong adhesive. I think it is used for scrap booking and the like. I found the 6mm (1/4") size perfect.
Less stressful to join as you can take as much time as you like, adds zero weight, is very strong.
Best part is if you ever need to get it apart you can slide an ordinary knife along the seam and ease it apart. Alternatively if you have a prang, when you soak the foam in hot water to expand it back, the glue softens as well and you can move it around to realign.
I also then put a 1/2" glass fibre reinforced tape strip along the whole underside length of the fuselage join just to add bit of strength but it was unnecessary.
Makes a neat joint IMO. I did my original EasyStar this way and it has been totally solid.
Frank
jj604 is online now Find More Posts by jj604
Old May 10, 2012, 06:01 AM
adioperator is offline
Find More Posts by adioperator
adioperator's Avatar
Joined May 2010
My EZ*II gliding very nicely in wind, without motor. One obstacle, tree
EasyStar II - Zbor la panta (7 min 1 sec)
adioperator is offline Find More Posts by adioperator
Old May 10, 2012, 06:33 AM
Joined Nov 2008
Originally Posted by McMoron View Post
Mulitplex was aquired by Hitec some years ago, chances are MPX servos are rebranded Hitecs... .
Don't think so - see below!
I think I possibly have.....
Old May 10, 2012, 06:49 AM
McMoron is offline
Joined Dec 2007
According to servodatabase.com Nano-S is indeed a rebranded HS-55
http://www.servodatabase.com/servo/multiplex/nano-s
Old May 10, 2012, 06:51 AM
McMoron is offline
Joined Dec 2007
http://www.youtube.com/watch?v=z60jtApTx-A
Indeed, the folding prop is a really nice touch to the design, such a versatile platform!
Old May 10, 2012, 08:02 AM
Joined Nov 2008
Actually, I could be being fooled by the plastic colour. The HXT900 has square corners to the mounting tabs, the Hitec & MPX have rounded - so possibly.
Old May 10, 2012, 08:12 AM
McMoron is offline
Joined Dec 2007
The HXT900 has nothing to do with the other two. HXT900 is just the best bang for the buck out there, even though the HKSCM9-6 I'm testing right now is promising. Hard to believe, less than $3 for 10g/1.6kg/.07sec servo..
However, extensive testing before use is a must with these cheap offerings. Eg. never put them in the elevator without having them run in a redundant place (eg. dual aileron) or a servo tester. That's the main difference between the branded ones, and the chap ones, QC.
Old May 10, 2012, 09:21 AM
Murocflyer's Avatar
Joined Nov 2005
The Mulitplex web site states: "Powerful brushless motor - three times the power of the EasyStar I"
Do we know what this motor is and how many amps it will be drawing on the stock 7x6 folding prop?
Frank
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
