Old Jan 30, 2012, 03:18 PM
Verid is online now
Find More Posts by Verid
Joined Jan 2009
Originally Posted by EZCanuck View Post
Remind me again folks why so much mod chat before ever flying it stock?
At what point will you know you have improved performance or degraded performance vs stock?
Cuz I'm FPV flyer that beats s.... out of a EZ* Mk.I and I already know where it gonna break if I push it too hard. Since Mk.II already has nice mods done by Multiplex (ailerons and sturdy motor mount) so I added only some reinforcements that allowed my Mk.I to survive two years of frequent crashing.
I'll repeat it again:
There's absolutely NO necessity to add any modifications to stock EZ* Mk.II if you are going to fly it LOS or peacefully FPV with light equipment. Those mods are only for those who like to fly no higher than 3 meters and love tree hugging.
Verid is online now Find More Posts by Verid
Old Jan 31, 2012, 02:34 PM
Wayno Complaino is online now
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
My ES2 was waiting for me when I got home, hopefully the power parts will be here tomorrow.
Excuse the potentially silly question: Is there a way of joining the two halves of the body in a way that it can be opened again later?
Wayno Complaino is online now Find More Posts by Wayno Complaino
Old Jan 31, 2012, 02:53 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
Yup, use double-sided tape
Can also use CA blobs if you like. It'll open up fairly easily with a knife afterwards (I used strips of DS tape, then dribbled in small amounts of CA where the halves didn't meet up too well)
Edit: got my tape from the craft area of The Range - medium, not permanent. It survived a very solid prang on Sunday.
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Feb 02, 2012, 12:45 PM
shrubber is offline
Find More Posts by shrubber
Joined Feb 2012
I've set up EZ II RR with stock equipment and measured the static thrust at full throttle with a kitchen scale. It gave me 350 grams. Is that enough? I expected a higher value.
shrubber is offline Find More Posts by shrubber
Old Feb 02, 2012, 12:48 PM
Joined Dec 2011
sounds okay. My non-stock is 308g
Old Feb 02, 2012, 12:57 PM
shrubber is offline
Joined Feb 2012
Thanks for your answer. My RC knowledge got stuck in 1990, and I don't have a feel for foamies and electric motors.
Old Feb 02, 2012, 01:38 PM
Joined Dec 2011
I need to check the stock motor in motocalc, I'm not sure that folding prop (although nice) is optimum
Old Feb 02, 2012, 01:46 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
What makes you doubt the ability of the stock equipment?
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Feb 02, 2012, 01:48 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Optimal for what? The EZ is a gilder and a prop that folds and reduces drag seems optimal to me.
Old Feb 02, 2012, 02:43 PM
shrubber is offline
Joined Feb 2012
I was doubting my ability to set up the controller.
Old Feb 02, 2012, 03:07 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Ok, I see. You might want to consider a watt meter http://compare.ebay.co.uk/like/14068...Types&var=sbar
Much better method of checking power.
Old Feb 02, 2012, 07:41 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Hi Ashton,
Folding props do in fact allow planes to experience less drag when the motor is off, and we are just floating around on either thermals or coming gradually down from high altitudes with the motor off.
With that said though, there are many flyers who don't do a lot of their flying with the motor shut off; preferring instead to fly a more aggressive style where the motor is on a good deal of the time.
Your gut feeling then, may have some merit in that the folding prop may be less than optimal for certain types of flying.
For these types of flyers, they may find that a different prop would allow better efficiency for their flights, in the sense that they get more bang for the buck with a fixed blade prop than they do with the folder.
So you are correct in thinking that folding props are not necessarily the optimal choice in all situations.
Take care,
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Feb 02, 2012, 07:46 PM
Joined Jul 2006
It's relatively easy to get a 'feel' for foamies and electrics when coming from gas and nitro planes; in spite of the seemingly insurmountable task of trying to decipher all the mumbo jumbo.
I've written a tutorial on the basics, in words that even the rankest newcomers can understand and feel comfortable with. Have a look for yourself, and see what you think.
Beginners Guide to Picking Motors and Props
Chuck
Old Feb 03, 2012, 01:59 AM
Joined Dec 2011
It's not the folding aspect that I was thinking of, in fact I think it's great. It's the prop pitch.
MotoCalc:
"The diameter (7.0in) to pitch (6.0in) ratio is less than 1.5:1, which will result in reduced propeller efficiency at low speeds (the propeller is stalled). Although this is not likely to affect flying characteristics, it may make take-off or hand launching difficult."
I couldn't find a single power combo that recommended a 7x6 prop. Plenty for 7x4, 7x3.5 or 7x5 though - the real optimums are in the 8x range, but unless I mod the mount or chop the fuse, they're a no-go.
Thanks for the link - I'll try WebOcalc at work when it's quiet
Old Feb 03, 2012, 04:43 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
How can you get "more bang for the buck" than with a prop, which is already included in the kit?
Whatever alternative prop you'll buy, it will cost you additional money.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 08:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 03:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 04:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 04:11 PM
