Old Oct 20, 2012, 02:23 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Originally Posted by B dog View Post
Where are you guys getting the battery adapter to allow the mcpx battery to fit the stock plug?
Brian
You can use the battery charging adapter that comes with the mcpx. They're easy to find.
If you have any soldering skills, you can do what I did and split the connectors on the charge adapter, and direct solder each end into a 'nub'. I plug the nub into my msrx battery cable and it lives there permanently. Takes up hardly any room and you don't even know it's there. If I ever want to go back to regular msrx size batteries, I can just pull the nub and it's good to go.
ruzam is offline Find More Posts by ruzam
Old Oct 20, 2012, 04:19 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Selling MSRX if anyones interested
Alex Schauer is offline Find More Posts by Alex Schauer
Old Oct 22, 2012, 02:55 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Went outdoors with the MSRXs again yesterday. It was just windy enough that my 9958 and V911s were barely able to keep from being blown away from me. (Broke a MSR flybar on my 9958 after a hard nose-down attempt to fly into the wind caused me to crash. Easily fixed though.)
Now, the MSRXs were doing very well, but I did have one interesting blow-out. I was doing a HARD banked turn into the wind and I could hear the tail rotor SCREAMING as it tried to keep the nose pointed in the right direction. That was about 1:15 into the flight (using a Turnigy Nanotech 160) and right in the middle of the turn, the low-voltage cutoff behavior kicked in and the heli fluttered down to the ground. I rebooted the heli and I found that I had at least 2:45 left in the battery (I only fly to 4min as a rule). I guess the current spike of that hard tail rotor usage cause the voltage to temporarily drop below the acceptable levels.
I decided to install MCPX tail booms on my MSRXs last night. I test flew both of them indoors and they both flew VERY well. In fact, if anything, they might have been easier to piro right and left than they were before. I won't be able to go outdoors until the weekend to try them out, but the extended tail length should be a little easier on the tail rotor.
RoboHeli is offline Find More Posts by RoboHeli
Old Oct 27, 2012, 04:49 PM
B dog is offline
Find More Posts by B dog
United States, CA, Foster City
Joined Nov 2011
Hey guys,
I bought a second hand msrx to complement my existing msrx, I got it for $60 so I thought it was a deal. It was a good deal except the tail motor was failing (quick full throttle blasts would cause a piro/spin). So I did some home work and bought a new mcpx complete tail (longer) along with the mcpx landing skids and a Thunder Power mcpx 240mAhr battery. I got home and installed everything then realised the battery connector is diferent, bummer. I just got home from the LHS with a battery adapter to allow the mcpx battery to be used on any UM plane/heli. I have not shortened the wires up yet but the results are good. The mcpx tail on the msrx moves the CG back, the mcpx landing skids/ battery holder/ big mcpx battery, makes everything just right. To break in the new battery I flew 4 mins (110mah to full charge from a TP AC6), second charge I flew 6 mins and never had a LVC! Good times! I think everyone should explore this win-win situation when your tail motor fails.
Brian
B dog is offline Find More Posts by B dog
Old Oct 27, 2012, 10:01 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
So, I've also heard that the mcpx tail on the msrx moves the CG back. But after I installed the tail on my MSRXs, I was doing some slow circuits around my studio and I really didn't notice anything that would make me think that it wanted to pitch backward. I haven't had a chance to fly them outdoors yet, but we'll see.
Old Oct 27, 2012, 10:21 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
I thought the AS3X system compensates for this?
Daryoon is offline Find More Posts by Daryoon
Old Oct 27, 2012, 10:34 PM
roidspop is offline
Find More Posts by roidspop
roidspop's Avatar
Joined Apr 2005
I got this heli today at our new LHS...hurrah for Hobby Town and welcome! Saw the mSRX and bought it, just 'cause. Thought I'd taken a step down from my SR120 and had found something a few cuts above the CX. Ha! Well, this is how we learn.
I've spent about twenty flights getting to the point that I can (sort of) fly circuits right AND left indoors. The first hover was like something from a kamikaze scene in a WWII movie with my face being the target. The one skill that has transferred well from my other small helis is chopping the power just before smashing into something. Reflexes: hunnerd percent. Anyway, this little guy was a major surprise to me...it is really something else!
The MMM thing seems to show that the heli has a tendency to drift off to the left-front but before I start messing with the swash links, I did some of that with my others and have not found a good, low-trauma method for getting the ball links unhooked and then stuck back together. Anybody have some idea for approaching this that will keep things un-bent? No tools seem to exist for these little guys. Any thoughts?
Looking forward to taking it out tomorrow morning early and seeing how it does with some space to play with.
roidspop is offline Find More Posts by roidspop
Old Oct 28, 2012, 01:19 AM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
I use my fingernail to pop them...putting them on is a littel bit more work..you have to make sure you turn the black part in 1 turn increments...they only go back on one way...I use a little spit on the swash and then holding the swash arm with needle nose pliers (carefully), I pop the rod back onto the ball.
I thought this heli was a handful until I bought a Nano CPX, which I sold a few days later....the nano cpx to me was like a dragonfly on steroids...I had a really hard time controlling it...like the MSRX tho.
Jake8131 is offline Find More Posts by Jake8131
Old Oct 28, 2012, 10:40 AM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Just take it easy with the ball links. I also use my fingernail.
I've had great success with the RakonHeli aluminum parts. I strongly recommend the aluminum blade grips right out of the box. I've experienced a spontaneous break of a blade grip ball on my stock blade grips in flight that caused a spectacular crash. I know others have experienced the same thing.
Regarding the MMM, I found that my swash looked "level" to the ground (e.g. with the heli sitting on its skids) when I took it out of the box. In fact, both of my MSRXs started out this way. I extended the aileron a little bit (2-3 turns) and shortened the elevator a little bit (1-2 turns) and did that for both of my birds and found that it worked pretty well for letting me do circuits indoors.
Outdoors? Don't need to even worry about it, as far as my experience has been. You just blast this little guy around like a hotrod and the momentum takes care of any weirdness. I LOVE how this thing cuts through the wind like it's not even there.
It's raining on my parade today. I wanted to go out and fly my MSRXs with the MCPX tailboom that I installed last weekend but the weather is too bad right now.
Old Oct 28, 2012, 11:49 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Tweezers - they work great to get the links back on - position them on the back of the ball and against the ball link and squeeze
whichwaysup is offline Find More Posts by whichwaysup
Old Oct 28, 2012, 12:34 PM
B dog is offline
Joined Nov 2011
AS3X compensating for COG change from mods.
The AS3X will compensate but proper COG is still a good thing. With the COG moved rearward from adding a mcpx longer boom, the AS3X will tilt the swash forward (down elevator) to compensate. This will in effect limit your servo throw because its' dead stick position (hover) within the linear servo will no longer be in the middle. So while flying with an aft COG, you will have less FFF authority and more than needed rearward pitch. Might be good for back flips but we should always try to keep the basics correct.
Brian
Old Oct 28, 2012, 04:04 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Good call, B dog. How do you measure COG on the MSRX? With a flybarred heli, it's a bit easier since you can just balance the flybar between two supports...
Old Oct 28, 2012, 07:50 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
I guess you can hold by the blades.
Old Oct 28, 2012, 08:09 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
For most of these Heli...if you can disengage the motor pinion and main gear mesh. I.e. pushing up on the motor slightly, you can hold the the main shaft so it's parallel to the ground. Then you'll be able to see which side is heavier.
Old Oct 28, 2012, 08:16 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Thought about that but it's a little wonky with blades that can pivot. Daryoon's idea of holding it by the shaft might work as well.
I'm intending for my tail mod to ultimately grow in to a full-on brushless conversion eventually complete with mCPX skids and batteries so I'm not going to sweat it. It'll all come eventually.
I'm going to really try hard to find a time when I can go flying outdoors with them before the snow comes...
Discussion mSR vs mCP X Nomad57 Beginner Training Area (Heli-Electric) 32 Dec 20, 2014 10:08 PM
Discussion mSR to mCP X transition Nomad57 Micro Helis 23 Dec 31, 2011 07:07 PM
Discussion Quick MSR/MCP-X question... bp_968 Micro Helis 10 Oct 23, 2011 06:28 PM
Sold Eflite mcpx mcp x rtf!!!! Msr sr120 sr hootie7159 Aircraft - Electric - Helis (FS/W) 0 Aug 26, 2011 10:11 AM
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 10:27 AM
