Old Mar 19, 2012, 07:34 PM
d2tw4all is offline
Find More Posts by d2tw4all
United States, RI, Smithfield
Joined Dec 2011
Originally Posted by octanejunkie View Post
Interesting...
I like seeing the comparison between the mSR X and the mCP X as I am contemplating the purchase of an mCP X as my intro to CP model.
Anyone else fly both of these models willing to offer their observations?
I have both, motor on my msrx just died though which annoys me but I beat it running 4-5 consecutive packs through it without a break so I guess I shouldn't be surprised. I'm thinking maybe I'll try to solder on a small heatsink or something, I haven't heard anyone mention trying that.
What was stated about the msrx vs. mcpx is right on, it's a challenge going from flying the msrx to mcpx without paying close attention because it is WAY more sensitive. I've been flying helis for a while now and and comfortable flying CP birds, but you get so sloppy on the sticks flying the msrx that if you go right to the mcpx you can get into trouble quick. Happened to me today as a matter of fact, first flight was about 1 sec on the mcpx as I throttled up too quick and then dropped throttle/pitch and it decided to pile into the pavement. Good news is that the mCPX is almost as durable as our beloved msrx and will take an absolute beating. My mcpx is modded with aluminum upgrades and a full brushless conversion. It's an absolute monster in the air. The msrx is fun to do figure 8's in the living room and I buzz around a parking garage on crappy days at work during lunch when I can't fly bigger helis or planes outside. The mcpx is only slightly larger than the msrx but it's a completely different experience, kind of like going from a cadillac to a corvette. Both great rides in their own right, but one is sluggish and easy going and the other is aggressive etc. Bear in mind you can dial down the mcpx if you have a good tx, you can even make it "fixed" pitch if you want by adjusting the pitch curve so it is completely flat. Ultimately, the msrx is my guilty pleasure that I can pile into the ground at full speed with no damage, I beat on that when I want to "relax fly" since it's cheap and docile and hard to break. The mcpx is a great bird in it's own right, but you will definitely need to be a lot more sensitive on the sticks once you dial things up and don't over deaden with expo and travel etc... Let me know if you have any other questions.
Tom
d2tw4all is offline Find More Posts by d2tw4all
Old Mar 19, 2012, 08:11 PM
d2tw4all is offline
Joined Dec 2011
Someone with motor problems confirm?
I started reading this thread but just don't have all night and searching for motor search terms yielded way too many results. Can someone confirm that the behavior I'm seeing is consistent with a motor failing? Basically I was flying FFF a bunch today and what I thought was early in the pack I noticed that the heli was losing lift. I switched out packs and flew a little bit more but after only 1/2 the pack it wouldn't fly any more. I figured maybe the pack wasn't fully charged, so I tried another later in the day and it flew for less than a minute and then didn't have enough power to stay in the air. Tried another fresh pack and the motor slowly died down until it wouldn't spin anymore. I pulled the motor and hooked it up to a power source and was able to get it to turn, put it back in and it actually spooled up for me and flew for a minute but definitely lacked power, then it wouldn't start on the ground without me giving it assistance to start turning. Pretty sure it's the motor and I just ordered a new one, but hopefully someone here can ease my uncertainty and confirm the behavior based on their own experience...
Tom
Old Mar 19, 2012, 08:37 PM
dakilen is offline
Find More Posts by dakilen
mCP-X, mSR-X, DX6i
dakilen's Avatar
United States, WI, Superior
Joined Aug 2011
I've had aluminum cooling fins super glued onto my main and tail motors since day one. Both motors get warm, but never hot.
dakilen is offline Find More Posts by dakilen
Old Mar 19, 2012, 08:55 PM
dweikert is offline
Find More Posts by dweikert
United States, PA, York
Joined Jan 2012
Tom
Yep. All of that is all too familiar. Drop a new motor in and I'm sure you'll be back to normal.
dweikert is offline Find More Posts by dweikert
Old Mar 19, 2012, 09:00 PM
dakilen is offline
mCP-X, mSR-X, DX6i
dakilen's Avatar
Joined Aug 2011
Main Motor and Tail Motor Cooling Fins
This helps on mine - motors get warm, but never hot.
Old Mar 19, 2012, 09:14 PM
kurmet is offline
Find More Posts by kurmet
kurmet's Avatar
Joined Mar 2012
this is what i use a transistor heatsink
kurmet is offline Find More Posts by kurmet
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
AHhhhhhh sunuva %$&&^1@ I just broke a control ball off the swash plate on my like third flight with aluminum grips. Just the run of the mill blade strike into solid object.. I think a door. Skidded out of a left turn
seeingeyegod is offline Find More Posts by seeingeyegod
Old Mar 19, 2012, 10:28 PM
dakilen is offline
mCP-X, mSR-X, DX6i
dakilen's Avatar
Joined Aug 2011
Mix settings for rudder
I remember seeing somewhere on here about some mix settings for the rudder to help out a bit with the left/back, right/forward issue. Anyone care to share what's currently working best for you? I've got a DX6i. I've done all the MM adjustments and can compensate just fine on my own, but would like to try some mix settings.
As a side note (I'm sure this has been cussed and discussed), I just bumped my "Travel Adjust" settings up to 125% on the rudder and the right and left fast Piro's are faster and easier. Of course it doesn't help with slow piro's.
Thanks in advance!!!
Old Mar 19, 2012, 10:41 PM
greyhoundfan is offline
Find More Posts by greyhoundfan
Joined Feb 2012
like that..can you post pic?
greyhoundfan is offline Find More Posts by greyhoundfan
Old Mar 20, 2012, 12:08 AM
d2tw4all is offline
Joined Dec 2011
Just turn it there are extra balls on there...unless it's an ali swash too?
Tom
d2tw4all is offline
Joined Dec 2011
I figured as much, and already ordered one, just figured I'd sleep easier knowing it wasn't the board... SMT soldering is a bitch!
Tom
Old Mar 20, 2012, 12:12 AM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
that is because you did not come completely off the power before an emanate crash.
Learn to get real quick on the throttle kill switch or it will bust your balls.
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Mar 20, 2012, 12:38 AM
Polecat_af is offline
Find More Posts by Polecat_af
Polecat_af
Japan, Okinawa Prefecture
Joined Jan 2012
For dweikert...
My hyp 160s were never really 'warm' after a flight. More like 'not as cold as when I picked them up out of the box'. But never really more than body temp. Except for that flight when the motor was intermittently cutting out. My main motor had gotten hot before, but not like the time I was describing in my earlier post. I have somewhere in the neighborhood of 150 flights on it and have replaced ZERO parts on it so far. I do a lot of hovering, piros, and circles/eights and every once in a while some fast outside stuff, so I guess it's had an average life. I have flown it several times back to back before, but most of the time I let it cool down for five minutes or so between flights. I forgot to mention that I have my timer set for five minutes, and I've got plenty of time beyond that to bring her back for a spot landing or just hover her close by and grab her out of the air with my hand.
Polecat_af is offline Find More Posts by Polecat_af
Old Mar 20, 2012, 12:41 AM
Ron
Yeah I don't cut power when I don't think I'm going to crash! This was just a miscalculation... I actually CA'd the control link back onto the swash (maybe my wording is wrong, talking about the bottom piece that the servo arms link to, not the top part with the 4 control balls) and so far it is holding, even through another couple of knocks.
Old Mar 20, 2012, 01:08 AM
A Rdnek is offline
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
I know what you mean, I have had a bunch of crashes that made me think, "what just happened, I didn't see that coming". Anyway glue em up and keep em flying till the new parts get here. I have been luckly so far.
Ron
Discussion mSR vs mCP X Nomad57 Beginner Training Area (Heli-Electric) 32 Dec 20, 2014 10:08 PM
Discussion mSR to mCP X transition Nomad57 Micro Helis 23 Dec 31, 2011 07:07 PM
Discussion Quick MSR/MCP-X question... bp_968 Micro Helis 10 Oct 23, 2011 06:28 PM
Sold Eflite mcpx mcp x rtf!!!! Msr sr120 sr hootie7159 Aircraft - Electric - Helis (FS/W) 0 Aug 26, 2011 10:11 AM
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 10:27 AM
