Old Dec 13, 2011, 05:13 AM
mifau is offline
Find More Posts by mifau
mifau's Avatar
Joined Jan 2004
Good to hear that you airborned your scoprio
Nice!
mifau is offline Find More Posts by mifau
Old Dec 13, 2011, 07:54 AM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Originally Posted by milouze View Post
Hey Mifau!
I'm waking up this thread with a short vid of the flight of the Scorpio frame
So far, I'm very happy with it, especially with those 2226/25 roxxy motors. I was worried of using some 2200mAh lipos because of the weight, but the hexa handled it with no problem.
Lots of power and very agile, so a very nice setup for FPV!
The flight controller I've used is a TMF pro one. Works very good.
Next time I'll try some onboard video
Cheers_
PS: here's the vid:
http://vimeo.com/33585045
password: scorpio
Thank you for posting this video.Is that a 450 landing skid or 500?
Did you manage to calculate flight times? Enough power for mounting a video TX and a gopro?
panos2408 is offline Find More Posts by panos2408
Old Dec 13, 2011, 09:12 AM
milouze is offline
Find More Posts by milouze
Registerer Used
milouze's Avatar
Paris
Joined May 2010
The landing gear is a gaui330x that I've adapted, but any 450 can be adapted (and I guess the 330X one is a 450 skid cut in two pieces...).
Next time I'll manage to record the flight time, but I can say for sure that it could lift a gopro and a video TX, even with a 2200mAh lipo. Though, if I do that, I'll probably switch to capacity between 1000 an 1500mAh, just to save some weight (and flight time of course).
The hexa with everything included (except lipo) weights 430gr, and with a 2200mAh lipo, it weights 610gr.
Cheers
milouze is offline Find More Posts by milouze
Old Dec 13, 2011, 09:17 AM
mifau is offline
mifau's Avatar
Joined Jan 2004
Align 450 landing gear is just perfect for that frame.
I use one. It's light and durable.
About flight time....
Without GoPro and fresh 2200mAh I can fly for about 15-16 minutes.
With GoPro attached flight time is 8-9 minutes.
Quite good result I think.
Old Dec 13, 2011, 09:30 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Excellent... Can't wait to build and fly this thing and shoot some videos that only small hexas can shoot e.g ladies room JK
Old Jan 03, 2012, 12:32 AM
Dehas is offline
Find More Posts by Dehas
Dehas's Avatar
France, Lorraine, Saint-Diť-des-Vosges
Joined Aug 2011
Hello
I'll try to do is frame by hand because I did not cnc, I need the length of the arm.
Mifau great job.
thank you
Sorry for my English, I'm french !!
Dehas is offline Find More Posts by Dehas
Old Jan 06, 2012, 11:53 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Ok received my frame along with the gopro housing. Frame seems very strong and it's so cute I decided to go with the roxxy motors after all since those are really light and deliver lot's of power for their size.
I am not sure though how the FC should be mounted on. The pre drilled wholes are not on a 45 degree angle which leaves me in doubt of what flight configuration this hexa is using.. I thought this hexa was supposed to be flown in x mode... and if it is how I am suppose to mount the FC?
Old Jan 06, 2012, 11:57 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Originally Posted by Dehas View Post
Hello
Mifau great job.
thank you
Front Arms = 120mm
Mid Arms = 115mm
Rear= 95mm
P.S If you don't plan using the motor mounts extend all the arms by 25mm to have enough clearance for 5" props.
Old Jan 07, 2012, 12:49 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Never mind I figured it out. You have designed this model for use with your own FC which has different orientation.
Well i have to say that the design can't accommodate my board although it should accept both orientations of the square type FCs. Maciej you might wanna look into this and correct your schematics. No offense but you shouldn't expect every user of the scorpio to go with a cyberdrone fc.
Anyway since this is a mini hexa and weight is a major factor I came up with this little thing that shouldn't weight more than 10g-25g depending on the mat used and will make your life easier. Feel free to use it.
Spec:
Outer Diameter = 48mm
Inner Diameter = 42mm
Opposite whole distance = 45mm
Whole clearance from inner and outer diameter = 3mm
Old Jan 08, 2012, 01:05 PM
Dehas is offline
Dehas's Avatar
Joined Aug 2011
Thank's Panos
Old Jan 09, 2012, 05:17 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Thank's Panos
No problem.
Note that all measurements I gave you were taken from the DFX file attached by the designer in the beggining of this thread.
Old Jan 10, 2012, 10:43 AM
Dehas is offline
Dehas's Avatar
Joined Aug 2011
Thank you, but I do not just open the files DFX is a friend who's going to cut them to the CNC.
Old Jan 24, 2012, 12:51 PM
Dehas is offline
Dehas's Avatar
Joined Aug 2011
Here are the changes that I give during assembly, when I have all parts (motors, ESC, etc.)
Length 43 ​​cm, width 32 cm (motor to motor)
The propellers are 8x4.5 Gaui
Old Jan 27, 2012, 01:59 PM
milouze is offline
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Hello Dehas, don't you think it would have been a good idea to have the center plates bigger, for strengh and stiffness purposes?
Old Jan 27, 2012, 04:01 PM
Dehas is offline
Dehas's Avatar
Joined Aug 2011
I do not think because my center plate is 1.5 mm thick.
Discussion My new Multiwii Mini Hexa caotri Multirotor Talk 1 Jul 08, 2014 06:44 AM
Discussion Arducopter 3dr new carbon frame build log ezmobius Multirotor Talk 0 Oct 01, 2011 06:44 AM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Discussion New hexa xl carbonite frame moslowflyer Multirotor Talk 7 Jun 07, 2011 12:56 AM
Wanted Quad and/or Hexa frame - MK frame / Flexlander beeker_12 Aircraft - Electric - Helis (FS/W) 1 Feb 18, 2011 07:04 PM
