Old Oct 20, 2011, 06:02 AM
mifau is offline
Find More Posts by mifau
mifau's Avatar
Joined Jan 2004
New Product
NEW Carbon-Glass-Alu SCORPIO Mini HEXA Frame (WITH PLANS)
I'd like to present a new version of my hexacopter frame.
I've been using prototype version for few months and I'm very satisfied with it.
Since first version some changes and improvements were introduced, that made whole construction more stable and durable.
I hope that you will like the construction.
Original frame was dedicated for Robbe Roxxy 2216/25 motors and GWS 5x3x3 props.
One can use any other motors with sufficiently high kv ofcourse.
Frame motor plates support both 12 and 16 mm spacing between mounting holes in motor.
Here is slight view on frame dimensions and design:
Construction consists of:
- centerplates + arms + motor mount plates.
- battery shelf
- FC protection plate (included but not necessary to be mounted)
Kit looks as follows:
(there are no screws and spacers on the photo - they are included ofcourse)
Frame after assembly:
Fully assembled frame weight: 118g
I'd like to draw your attention to arms composite construction.
Since carbon tube is quite fragile, composite with aluminium is made to strenghten whole arm without much gain on weight.
In front of the frame there are holes allowing to mount GoPro housing or FPV camera.
Both battery plate and FC protection shield have holes allowing installation of accessories/antennas etc as well.
In case of mounting GoPro (but not only then) it is more comfortable to use undercarriage.
Align Trex 450 fits there perfectly and makes landing safer.
Here you can see this frame in flight (at 1:15)
Dwa coptery w Wieliszewie (4 min 10 sec)
Frame is currently available in shop: http://cyberdrones.com/shop/product....t=14&id_lang=1
Currently two on stock, in case of backorder lead time is about two weeks.
mifau is offline Find More Posts by mifau
Old Oct 21, 2011, 02:38 AM
mifau is offline
mifau's Avatar
Joined Jan 2004
Update...
If somebody wants to build that frame by himself and for himself (not for commercial use)... here you are... DXF files: http://cyberdrones.com/small_hexa_dx...hexa_frame.zip
Old Oct 21, 2011, 12:28 PM
Connexxion is offline
Find More Posts by Connexxion
Nemo in a blender
Connexxion's Avatar
The Netherlands-Amsterdam
Joined Mar 2007
Nice build!
How did you mount the alu tube into the composite?
Is it a press fit or did you use glue to keep it in place?
Last question that may interest more people: How much?
Connexxion is offline Find More Posts by Connexxion
Old Oct 21, 2011, 12:36 PM
mifau is offline
mifau's Avatar
Joined Jan 2004
Originally Posted by Connexxion View Post
Nice build!
Tnx
Both
Glued + pressed. Very durable combination
Here is everything ... http://cyberdrones.com/shop/product.php?id_product=14
But... it's about $89 + shipment
Old Oct 23, 2011, 10:39 AM
milouze is offline
Find More Posts by milouze
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Hey, I bought that sweet lookin' frame, and I'm eager to try it out
Since I don't plan to use roxxy motors (2216/25), I'm looking for an alternative; which kv would you recommend?
1800kv? 2000kv?
I found that motor that may suit the needs of that frame:
http://www.giantcod.co.uk/a220812-18...-p-405608.html
milouze is offline Find More Posts by milouze
Old Oct 24, 2011, 07:42 AM
mifau is offline
mifau's Avatar
Joined Jan 2004
1800kv? 2000kv?
Frame has been shipped just 15 minutes ago
Robbe 2216/25 has also 1800kv, so from this point of view...your motors will be ok.
But.....
It is not only matter of kv. Efficiency is also very important.
If your motors (I have no experience with them ) have too small efficienty at higher rpm....you copter will be too weak to handle GoPro (or other load), and it is very probable that flight time will be heavily decreased).
That's why I do not like cheap motors. Manufacturer declared parameters are usually great, but it's just fiction.
Old Oct 24, 2011, 10:02 AM
apache64 is offline
Find More Posts by apache64
Germany, BY, Munich
Joined Aug 2010
Hi Mifau,
Thanks for posting this great design, and i am going to order the frame but would like to get some answers from you first. I am new to quads, so forgive me for these questions, but what battery do you use, and how long can you fly with it? will a KK controller be able to fly this frame , as i am looking at FPV too, and currently my quad will only fly for 8 minutes on a 4S 2200ma, so the motor efficency is quite crucial i guess?
Regards,
apache64 is offline Find More Posts by apache64
Old Oct 24, 2011, 11:09 AM
mifau is offline
mifau's Avatar
Joined Jan 2004
Originally Posted by apache64 View Post
Hi Mifau,
Regards,
Tnx
In short....
I use 3S 2200mAh battery which gives me 12-15 min FPV flight time and 8-9min with GoPro onboard.
Without GoPro and FPV it can achieve even 18min.
Ofcourse with well balanced motors (I strongly suggest robbe roxxy or something better/more expensive) and props.
Every FC which can manage 6 motors will do the job.
But....look at this one: http://www.rcgroups.com/forums/showthread.php?t=1514544
This is my FC, and some of videos there were made by this hexacopter (scorpio frame + GoPro)
Old Oct 24, 2011, 01:46 PM
milouze is offline
Registerer Used
milouze's Avatar
Paris
Joined May 2010
But.....
Thanx for all these details, of course things would be better with some roxxy motors...
Still, I'm really amazed it could carry a gopro without problem!
I'm also considering trying your FC which seem well thought and well designed; maybe when I've tried the small hexa.
Cheers and thanks for the answers
Old Oct 25, 2011, 05:33 PM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
The frame kit looks nice and I like how light the frame is it opens up lots of possiblities for combinations of things. Reasonably priced too I might add.
Any chance on making a frame kit that can handle 10" to 11" props in the near future?
drcigg is offline Find More Posts by drcigg
Old Oct 25, 2011, 05:50 PM
Centurion1 is offline
Find More Posts by Centurion1
Joined Sep 2011
just scale it up by 20-30% and use the 10" with 10mm boom
Centurion1 is offline Find More Posts by Centurion1
Old Oct 27, 2011, 04:47 AM
mifau is offline
mifau's Avatar
Joined Jan 2004
Ok... I scaled it up.
For 10" props it will look like this....
(all dimensions in [mm])
Production will be easier than small haxa, so it could have similar price I think. (but I have to check it to be 100% sure).
Arms (boom) will be 10mm alu, not carbon.
Old Oct 27, 2011, 01:50 PM
milouze is offline
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Hey, if you make those, I'll be interested too
Tomorrow I'll have the small hexa, it's waiting in the post office right now (yeah, my postman is a laaaazy guy who does not want to climb stairs )
Old Oct 30, 2011, 05:15 PM
mifau is offline
mifau's Avatar
Joined Jan 2004
Could be done
Wow...that's fast!
3 days from Poland to France...
Old Oct 31, 2011, 05:39 PM
milouze is offline
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Yep, and it would have been even faster if the postman was an athlet!
So, I had some time to build the frame up, and well it's really a cool one!
Really light but yet stiffer than I thought..
I didn't took long to build it, everything was neatly packed so you can't go wrong for the build. + 1
Here are some pics.
Discussion My new Multiwii Mini Hexa caotri Multirotor Talk 1 Jul 08, 2014 06:44 AM
Discussion Arducopter 3dr new carbon frame build log ezmobius Multirotor Talk 0 Oct 01, 2011 06:44 AM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Discussion New hexa xl carbonite frame moslowflyer Multirotor Talk 7 Jun 07, 2011 12:56 AM
Wanted Quad and/or Hexa frame - MK frame / Flexlander beeker_12 Aircraft - Electric - Helis (FS/W) 1 Feb 18, 2011 07:04 PM
