Latest blog entry: Wltoys V929 Quad Copter (Blade mqx...
-Brian |
United States, CA, Sebastopol
Joined Dec 2010
A few had mentioned that their wings were fluttering... I didn't follow this topic very closely because I wasn't seeing that issue. I'm seeing it with my new Beast. What was the issue and resolution? Is this an indicator that my servo is going to fail and if so do I need to go ahead and call HH?
-Brian |
![]() Then it sucks trying to get the battery out. Took me a few minutes. |
Back in the 90s, I thought about setting up a plane with variable CG. I figured it could be done with servo-operated sliding weight, controlled by a three-position switch on the tx. Forward position for normal flying, center position for 3D, and the rear position for wild tail-heavy antics. I never got around to doing it, however. Figured that knowing my luck, the thing would end up getting stuck in the aft position. ![]() Ever heard of anyone actually trying that? Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
-Brian |
Yep. Some of the guys used servo operated variable CG in their Tournament of Champions planes in Vegas. Was a huge help when it came to the 4 min free style. Good memories! rc
Check out my maiden flight-report: http://www.rcgroups.com/forums/showp...&postcount=700Joel |
Beast 3D lives again
Wing repair is now done... it was a longer process than I had expected, but I took my good old time to ensure it was all going back together correctly. Took my good old time getting the old wings off too - lots of delicate xacto knife work to make sure I wasnt losing foam anywhere I didnt need to. I did decide to reuse the CF that was there before - it was all fine, saved me some effort in assembling all the rigging.
I put it back together dead stock - so had to open up the fuse to rethread the servo leads back through the lower wing. No more decals, but who cares. Looks like it went back together very straight. Ill do some manual trimming, and then wait for a warmer day to remaiden it. This time, not close to any trees ![]() >>> EDIT - Trimming complete, ready for re-maiden. Had to adjust left aileron a little (apparently got the servo mounted a little far forward, but more than enough adjustment available in the pushrod. Was happy to see that the motor still ran smooth with lots of power. One mistake I made when I put it together was forgetting to note which hole the pushrod was in for the ailerons. When I reassembled it, I put it between the two settings called for in the manual. The throws look a little tamer than I remember them, maybe it came stock in the agressive position? Now on to the next tech project - reinforcing the nose gear on my T-28. Maybe Ill go crazy and do the power upgrade on it too - would have to go buy some CF and a motor, but sure would like to speed it up. <<< A couple pix of the reconstituted beast below... After getting it out of the tree, the wings were badly torn, the upper was pretty much off the plane. There were hunks of foam that wee missing from the lower where the branches cut into it. There was a some cosmetic damage to the fuse, took care of that the best I could with a little Sharpie work. Not sure why, but I replaced the wheel pants (which were missing completely). Motor seems fine, brick still is working fine, the AS3X seems to be working fine. If it still flies well, Ill be looking for more batteries - still flying the stock ef 180s (I have 2), but not going to put more money into it until I prove to myself that its ok. jc |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16633 | Yesterday 08:48 PM |
| Sold Eflite UMX Beast w/3batt and charger $120 shipped | RobDog | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Feb 06, 2011 09:40 PM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
