Old Jan 03, 2012, 07:05 PM
freesex is offline
Find More Posts by freesex
freesex's Avatar
Joined Aug 2011
Originally Posted by tracknoob View Post
Yup, I have both, and today I had the V2 out in 15MPH winds, with no real problems. No other UM, including my V1 Beast would allow a pilot of my limited skills to do that........
I broke my V1 at the same spot, I also fixed it with CF rod enforcement. I did notice significant increase in elevator authority afterward.
your story made me decide to do this again on my uncrashed V2.
freesex is offline Find More Posts by freesex
Old Jan 03, 2012, 10:04 PM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
how do i go about doing this?? elevator is real thin.....
how do you press a round tube into the foam?
also how much and where do you glue along the tubing?
lastly, do you have to use foam safe?
thanks
hidaven is offline Find More Posts by hidaven
Old Jan 03, 2012, 10:54 PM
MugMan is offline
Find More Posts by MugMan
MugMan's Avatar
Elida, Ohio
Joined Apr 2010
thanks
Yes, use foam safe CA. I grabbed regular CA by mistake to re-glue a strut to the wing on my V1 and it melted the foam.
MugMan is offline Find More Posts by MugMan
Old Jan 03, 2012, 11:11 PM
freesex is offline
freesex's Avatar
Joined Aug 2011
thanks
I used 11 size surgical scalpel blade, carefully cut open a 1/3 to 1/2 thickness groove, bury 0.5 mm CF rod into the groove. then apply a few drops of foam safe CA along the seam.
it's kinda tricky, especially when elevator has been installed on the airframe. patience and steady hands are the key, otherwise you will do more damage rather than enforcement to the model.
Old Jan 04, 2012, 03:12 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
One thing that got me last outing though was somehow I was having very reduced elevator authority. Yet when I would preflight it, it seemed to be operating correctly. Well, finally doing a simple (but fast) loop, it just would not pull out, and I crashed it badly. Broken wing, spinner, etc. When I had it on the bench to check out and repair, I found the root cause of my elevator problems: the surface had torn right near the control horn, at the thinnest part, so when it was tested just sitting still, both sides moved fine, but you could easily waggle it to make the sides move separately, like from even the slightest touch, or a breath of wind.
Sorry Guys, I'm a bit late with this reply. I go to sleep and the thread grows another page!
Cases like this are why we do a "positive control check" on full sized aircraft. By this I mean we operate a control while gently holding the surface still. Don't be too heavy handed or damage to a perfectly good control could result, careful handling shows up any problems like what happened here.
I think that I will be doing this mod too. Might look to see if it can be done on the Sbach too, kill two birds with one stone - strengthen the elevator and push the CG back too...
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jan 04, 2012, 03:19 AM
DangerDave is offline
Find More Posts by DangerDave
Joined Oct 2009
Deleted
DangerDave is offline Find More Posts by DangerDave
Old Jan 04, 2012, 03:36 AM
BMFA 190658
Joined Mar 2007
D'oh!
Old Jan 04, 2012, 11:01 AM
hidaven is offline
Joined Apr 2009
will thin CF tape work too? wouldnt have to cut any grooves.....
Old Jan 04, 2012, 02:41 PM
Wayne on Maui is offline
Find More Posts by Wayne on Maui
Wayne on Maui's Avatar
Joined Mar 2011
I have done this mod of ca ing cf on the elevator ,rudder,struts ailerons etc..just laid it in place and a drop of ca to hold it there
Wayne on Maui is offline Find More Posts by Wayne on Maui
Old Jan 04, 2012, 02:45 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
What's up Wayne? Haven't seen you around in a while. You got the new 3D Beast yet?
turnerm is offline Find More Posts by turnerm
Old Jan 04, 2012, 03:09 PM
Joined Mar 2011
Ha turnem not yet funds are very low at the moment hoping to get buy the end of the month ..Christmas I have to give toys to others!! but soon I will get one can't wait
Old Jan 04, 2012, 03:14 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I might be taking the wife back out to Maui again soon. We went there on our honeymoon. We stayed at the Westin in Kanapali (sp?). LOVED it!
I hope to get her back out there sometime this summer.
Old Jan 04, 2012, 03:24 PM
Joined Mar 2011
Nice place !! We'll have to get together if you make it back
Old Jan 04, 2012, 03:34 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Absolutely!! Maybe you can let me fly your Beast so I don't have withdrawals while I'm away from home!!
Old Jan 04, 2012, 04:51 PM
Joined Mar 2011
Lol.... not a problem if I have one by then still have to get me one beast and some new batteries and props sold all my stuff when I moved.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19303 Yesterday 10:00 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
