Old Jan 30, 2013, 06:59 AM
MozFlyer is offline
Find More Posts by MozFlyer
MozFlyer's Avatar
Brazil, ES, Vitória
Joined May 2009
Thanks for the info guys
Brian,
If i remember correctly on the T-28 I am using about 40% expo on ailerons and elevator and 50% on rudder
Just checked the tracking of my parcel and it has arrived in the country, problem now is customs. It can take weeks!
Anxious to fly the B3D.............although not for any 3D because i know nothing about it, but hopefully for some well controlled aerobatics
At my age and not having had many stick hours, things dont just happen anymore
MozFlyer is offline Find More Posts by MozFlyer
Old Jan 30, 2013, 06:17 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Brian,
That seems like a lot of expo for the T-28 it is a pretty docile plane to begin with. But it is mainly just personal preference. To get a similar feel I'd start with 20-30% expo with the B3D, Once you get the hang of it I'd slowly start dialing it down a bit, Though leaving it at around 20% should be fine.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 31, 2013, 07:31 AM
MozFlyer is offline
MozFlyer's Avatar
Brazil, ES, Vitória
Joined May 2009
I agree with you. Indeed it is a lot of expo but i feel more comfortable with it because i am tired of crashing and only after i started using highish expo i manage to keep my planes in good shape, but soon i will start reducing the expo.....as you mention
Problem was also that only recently i got the DX6i. Was using a DX5 before
Anyway, thanks for the comments. They were very useful
Will report back when i fly the B3D
I intend to do a few tests because i also ordered the GWS props and a spare Beast V1 motor
Carlos
Old Jan 31, 2013, 08:03 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Carlos
No testing needed the V1 2300kv motor and a GWS 5043 prop will get you over 30% more power as long as you're using a quality battery. I'd recommend Hyperion 240mAh packs. I don't know if RCBabbel can ship them to your location but you can PM him and ask. He makes a lightened version that will save you a couple grams.
For those of you not following the CC thread...
New Twist on AS3X!! A custom software that allows independent incremental gain adjustment on each surface and (possibly) a way to enable and disable the gyros remotely using channel 5. Also stick override priority for each axis as well.
Software here. I am hosting this at my personal webserver. Files have been scanned with Kaspersky 2013 and clean of malware/spyware/virus.
-Brian
Old Jan 31, 2013, 04:58 PM
MozFlyer is offline
MozFlyer's Avatar
Brazil, ES, Vitória
Joined May 2009
Overlander battery
Has anyone heard of or used this battery?
Overlander Sport 200 2S 7.4 20C
Length 33mm
Width 20mm
Depth 10 mm
Battery Capacity 200 mA
Discharge Rate >20C Constant
I have ordered some for my B3D
They are from the UK and i have read some favourable reports from UK guys
They come with 2 leads
I will probably cut 1 of them off to save some weight
Carlos
Old Jan 31, 2013, 05:14 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
If you are ordering from the UK then I would advise you to look into Miniaviation products. I use them on all my UMs, along with some BabbelBatts.
Tony
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jan 31, 2013, 05:34 PM
MozFlyer is offline
MozFlyer's Avatar
Brazil, ES, Vitória
Joined May 2009
Hi Tony,
I looked at the Miniaviation ones but i had already ordered 10 of the Overlander because the guys (Steve Web Models), told me they had used them on the UMX Stryker and they performed very well, so i decided to leave them for the next order from the UK
BTW, i did get a couple of 5043 and 5030 props and 6 way parallel charger plugs from Miniaviation
I am using the Overlander 1S on the T-28 and i am happy with them
Will report back on the 2S performance on the B3D
Cheers
Carlos
Old Feb 12, 2013, 07:56 PM
carbow is online now
Find More Posts by carbow
Canada, BC
Joined Sep 2012
5043 prop
I have the 5030 prop on now and was wondering if the 5043 would be any better.
As I am new to all this would I notice a difference. Thanks for the information.
carbow is online now Find More Posts by carbow
Old Feb 12, 2013, 08:39 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
I believe it goes like this: the 5030 prop is for the 2800kV motor in the newer AS3X Beasts. The 5043 is for the 2300KV motor if you have that. Other than that, I think the 5043 would only help if you are flying at higher ground elevations above 5000ft. I"m awful rusty at this though. I know if I'm wrong here someone will speak up.
shastamike is offline Find More Posts by shastamike
Old Feb 12, 2013, 09:54 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
The only thing wrong is the new motors are 2500kv, not 2800kv. The 5043 just bogs them down too much unless, as you say, you are flying at higher elevations.
erkq is online now Find More Posts by erkq
Old Feb 13, 2013, 07:50 AM
Canada, BC
Joined Sep 2012
about props
thanks for the information
Old Feb 13, 2013, 11:29 AM
shastamike's Avatar
Joined Jun 2010
Dang..I knew I'd mess something up. Mis-information. Been too busy skiing to keep fresh on RC stuff. Good thing you guys keep an eye on me.
Old Feb 13, 2013, 02:10 PM
strows is offline
Find More Posts by strows
plane demo expert
strows's Avatar
United States, CA, South Gate
Joined Nov 2012
Just received my wheel pants from Shapeways, these things look awesome! I am rebuilding my UMX Beast 3D, after lots of practice and many crashes it's time to replace the main wing, fuselage, rudder and elevator. Once its all done and ready I'll post up more pictures.
strows is offline Find More Posts by strows
Old Feb 13, 2013, 02:34 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
I've had this broom for ten years and three, it's had seven new handles and ten new heads
Aviefly is offline Find More Posts by Aviefly
Old Feb 13, 2013, 03:10 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Good one! I'm still chucking...
Joel
turboparker is offline Find More Posts by turboparker
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19222 Feb 03, 2016 03:36 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 10:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 05:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 02:16 AM
