Old Dec 18, 2012, 09:40 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by turboparker View Post
I can't hover either plane worth a damn, but I agree that the Beast is a lot easier to hover than the Sbach, regardless of whether they are AS3X-equipped or not. As RG mentioned, it seems odd that a short-coupled bipe would be easier to hover than a mid-wing monoplane - but that's the way it is with these two airframes.
Marlin - great flying! Nice torque-roll @ 1:07. Looked like nearly 3 rotations!
Joel
I'm pretty sure it is the ability on the Beast to get the CG a bit farther back. On the Sbach and even on the S3D the %MAC of the CG is still farther forward than on the Beast. That huge tray the Beast has allows for it. I've found that with a aft CG my AS3X Sbach hovers better than the beast, however even AS3X has trouble keeping up with that twitchy aft-CG flight when on the wing.
I do agree that when flying at a neutral CG the beast is a bit easier to hover though when it falls out Look Out! It falls out hard.
-Brian
kalmon is offline Find More Posts by kalmon
Old Dec 18, 2012, 09:57 AM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
-Brian
Brian,
That makes sense. I've never actually measured the CG on my S3D. I just used the flight-test method to find the spots for my various packs & marked the tray accordingly. I noticed the same thing with an aft CG on the S3D. I shoved a Hyp 240 nearly all the way back for some hover attempts, which made it quite tail-heavy with the cf rod & glue fillets on the stab. The plane was quite squirrelly in regular flight, and I had to really push the nose over on approach to keep it from doing an 'auto-loop'. But the worst part was that I still couldn't hover it worth a damn!
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 21, 2012, 02:11 PM
Mathrips is offline
Find More Posts by Mathrips
Joined Mar 2009
I posted this on the other beast thread before it dawned on me that my questions are for a Beast 3d, so apologies if it is already answered there I will see it.
I have two broken beasts off ebay (no need to comment on why I do this to myself)
First plane/problem: The servos on the board on the plane did not work. I removed and cleaned the contacts, even checked the motor brushes. Still they try but won't move unless I spin the gear first with my finger. All feels free when turned off. Anyway I replaced the board with one off another as3x beast that I got off ebay (glutton for punishment). All works except that the elevator and left aileron are reversed. Is there a way to reprogram these using the tx sticks to reset it back to standard Beast 3d programing?? If not, then can someone point me to what I can I do?
Second Plane problem: The motor on this one just stutters and barely turns. If I go to full throttle it quits entirely and the rx light blinks a few times. I tried a different motor with same results. Is there any hope or is internal esc likely fried?
Mathrips is offline Find More Posts by Mathrips
Old Dec 21, 2012, 02:41 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Answered on the Beast thread. No worries most of us check both threads.
-Brian
Old Dec 22, 2012, 12:06 AM
Mathrips is offline
Joined Mar 2009
I just reversed the elevator using the tx stick logic in the manual. Now I need to reverse the left aileron. Can anyone tell me which of the servo wires, red, orange, and brown, is ground and which is the signal?
Thanks!
Old Dec 24, 2012, 09:52 AM
kevinrc is offline
Find More Posts by kevinrc
Happy Habu Hustler
Joined May 2012
Thanks!
Red=positive
Orange=signal
Brown=ground
kevinrc is offline Find More Posts by kevinrc
Old Dec 27, 2012, 01:15 AM
Mathrips is offline
Joined Mar 2009
Thanks. Done and works like a champ.
Old Dec 27, 2012, 06:05 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
If that's the case something is wrong with your ailerons. The champ is a 3 channel trainer plane!
-Brian
Old Dec 27, 2012, 09:03 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
-Brian
LOL exactly what I was thinking
Aviefly is offline Find More Posts by Aviefly
Old Dec 31, 2012, 12:59 PM
JamesFM is offline
Find More Posts by JamesFM
Joined Nov 2012
Some issues are cropping up in my bone stock Beast 3D. I'm using 3s 180 batteries and now the motor is cutting out mid flight on me. Happened 3 times in a single battery. If I'm high enough I can cut the throttle and do what little gliding I can for 3 or so seconds then give it throttle and it'll come back on. I did a bench test and the motor isn't getting hot, even after 30 seconds of WOT, nor did it cut out. Any ideas?
JamesFM is offline Find More Posts by JamesFM
Old Dec 31, 2012, 01:18 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
The ESC is getting hot or your prop is now out of balance and it is drawing more amps and you're hitting Over Current Protection. You said stock but what prop you using? The Stock is the Eflite 5x2.75 but it draws a little more than the gws5030 because it is thicker and has squarer tips. First off I'd get a couple 5030 props and balance them and give them a try. Second you'll have to PM Erkq here and ask him about the heatsinks, Put one on across the ESC and one on the Voltage regulator. This should make sure the ESC and VR don't overheat.
Where abouts are you located? Temps? weather? Elevation?
-Brian
Old Dec 31, 2012, 01:24 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Just to make sure... you do know this is a 2S plane, right? Running 3S on it is above and beyond the call of its design.
That said, I can send you some heatsinks as kalmon indicated. PM me if interested.
erkq is online now Find More Posts by erkq
Old Dec 31, 2012, 01:25 PM
JamesFM is offline
Joined Nov 2012
-Brian
Yeah I'm using the stock prop. I do have some GWS 5030's coming in the mail though. I'm in northern Utah. It's about 28 F outside right now at 5000 feet.
I did swap the prop to a new one before flying, so I'm going to try putting the old tattered one back on. Was working fine with it.
Yeah, yeah. I bought some 3s batteries last week because this poor bird has been neglected for far to long. Just didn't have the power nor the 3d capabilities to make it fun on 2s! I'll send you a PM.
Old Dec 31, 2012, 07:12 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Yep!!
Sooo fun!!!!!
rc
HAPPY NEW YEAR
RCBABBEL is offline Find More Posts by RCBABBEL
Old Dec 31, 2012, 07:50 PM
kevinrc is offline
Happy Habu Hustler
Joined May 2012
Wait a minute! I thought this plane really woke up and fulfilled its destiny on 3s.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
