AS3X has its uses, like said it is very well suited to flying in windy conditions. Seeing as there is no way to turn off the gyros I'm thinking of fitting my Cub with regular (non offset) aileron servos. Tony |
Latest blog entry: Ridge Flying Fun :)
Not at all. In fact - quite the opposite. I fly everything from micros to 1/4-scale. AS3X actually helps, as it makes these planes behave much like 60-size or 1/4-scale ships, rather than twitchy little foamies that fly unrealistically. AS3X planes are great platforms for practicing your large-scale routine without having to go to the club field all the time, and without having to burn up gallons of glow-fuel or gasoline. As Mike noted - AS3X is not an autopilot. It is simply a 3-axis damping system that dampens movements in pitch, roll, and yaw that are not commanded by the pilot. It does not fly the plane at all. It simply makes them fly more realistically, and allows them to laugh at winds that would ground most giant-scale ships. ![]() ![]() Quote:
The Hyp 180s are designed for 5c charging with no reduction in performance or lifespan, so 800 mAh is fine. However, you can charge them the normal way with one of the 2s UMX charge-adapter cables. Use the UMX power plug part to gain access to the power leads & plug that into the charger's output port, be sure the 2s balance plug from the harness is not connected to anything, and then plug the pack's balance plug into your balance-board. That's how I charge my 3s Babbelbatts with my TP 820CD, which will not charge through the balance port. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
United States, NM, Santa Fe
Joined Aug 2011
found an old post-- might want to call first. deoxit in vancouver Deoxit Faderlube. its $18 or so at rpelectronics.com they are located in burnaby near willingdon and lougheed hwy just near brentwood mall. |
United States, CA, Sebastopol
Joined Dec 2010
Cheaper, no tax, no shipping, no driving and they send you candy too!! |
Joined Aug 2011
not sure about shipping price to canada-- free only in USA website also indicates limited international shipping |
About Sweetwater. The free shipping was great, the candy sweet, but really...I don't play an instrument anymore and the catalogs are a bit much. Interesting reading though. $45,000 for a sound board. They most likely don't have a clue that we are spraying this on little foamy planes.
Mike |
Joined Dec 2010
erkq:
Try Active Electronics in Vancouver. They carry a good range of electronic sprays for contact cleaning. Just MAKE sure that you ask whether any of these MAY dissolve foams. If you are unsure, please PM me. I am a chemist and can probably help with the contents for compatibility. FAI/Active may also be a good search. ANY good wholesale electronics store does carry these types of contact cleaners. Another option is isopropanol (isopropyl alcohol, 90+%, sold as "rubbing" alcohol) for cleaning using a Qtip, and then add a drop of 3in1 or similar light-weight oil and wipe with a Qtip as well. I've done this on my micro champ servos, and these products work very well too, and are foam safe. SkyCadet |
Latest blog entry: more "bling" for the glider...
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16819 | Today 02:09 PM |
| Sold Eflite UMX Beast w/3batt and charger $120 shipped | RobDog | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Feb 06, 2011 09:40 PM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
