Old Nov 12, 2012, 09:41 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
How COOL is THAT?!
Nicely done... what camera is used there? extra gear? I cannot imagine the B3D taking on TOO much more weight...
Thanks for sharing this!
SC
SkyCadet is offline Find More Posts by SkyCadet
Old Nov 12, 2012, 11:01 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Originally Posted by SkyCadet View Post
How COOL is THAT?!
SC
+1 Good Work Sir
I too would like to know what FPV setup that is, I would quite like an FPV plane (or helicopter) of my own, and that looks like a great setup.
How does the camera rotate? My first thought was that it might be linked to the Rudder, but that was until the deadstraight flybys with the camera over to the side...
Tony
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Nov 12, 2012, 01:54 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by SilentPilot View Post
+1 Good Work Sir
Tony
Tony,
VRflyer is flying from the cockpit, using goggles w/head-tracker! Here's his thread: http://www.rcgroups.com/forums/showthread.php?t=1740796
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 12, 2012, 09:01 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Originally Posted by turboparker View Post
Tony,
Joel
That was an amazing Video from VRFlyer ... sure shows the flex and pressure on the stringers and control rods going to the upper wing! Seems we are flying with a little bit of Flapperon on our upper wings at any good speed.
Just a seriously cool video! (He needs to put some mock IMAC patterns on that white clipboard in the cockpit and it would look absolutely real!
Marlin
OOPS ... just checked his blog and he HAS the mock IMAC patterns on there, just didn't show up too well in the video. WOW ... what a great job.
Fish99 is offline Find More Posts by Fish99
Old Nov 13, 2012, 09:31 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
I have finally had time to put my B3D through it's paces with the stock set-up. I have the 2300K motor and 5043 props, what performance differences will I notice after I install them?
Aphro is offline Find More Posts by Aphro
Old Nov 13, 2012, 11:02 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Stronger, faster, quieter... as long as you have good batteries, not the E-flight cr@p.
erkq is offline Find More Posts by erkq
Old Nov 13, 2012, 11:17 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Mini Aviation 210mah and Turnigy 260mah on the way...
Old Nov 13, 2012, 11:20 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Do I need a longer prop screw for the 2300k/5043... or skip the spinner back plate?
Old Nov 14, 2012, 12:17 AM
erkq is offline
Joined Dec 2010
You skip the spinner back plate.
Old Nov 14, 2012, 12:50 AM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
That was my guess... Thank you erkq
Old Nov 14, 2012, 10:30 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
I have found stock screw can work even with that combo--just enough threads
if you skip backplate--prop is pretty close to cowl--nicks likely.
I use the little black plastic washer from the sbach prop adpaters
flyrtim is offline Find More Posts by flyrtim
Old Nov 15, 2012, 10:58 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
THE BEAST IS BACK! Finished my re-winging and it's like having a brand new plane again. Thank you guys for all the advice.
shastamike is offline Find More Posts by shastamike
Old Nov 16, 2012, 09:15 PM
chasingair is offline
Find More Posts by chasingair
Joined May 2011
Considering getting one of these to throw around out front. Ill be using the 3 cell set up with batts in the 180 mah size.
My only confusion at this point is the connectors used on the beast. I know e flite has there own and its a three wire set up I believe ?
The batts I want to get are the normal type with a red and black and the balance plug....nano tech 180 3 cell 25c
chasingair is offline Find More Posts by chasingair
Old Nov 16, 2012, 09:25 PM
jevs is offline
Find More Posts by jevs
United States, MO, Union
Joined Sep 2012
I believe you will need to change the connector in the plane to match your battery. I beleive it is 3 pin JST-PH Female in the plane. Depending on your battery you may want to change to a red 2 pin JST. Your 3S will likely have a 4 PIN JST-XH male balance plug and a 2 pin red JST. Of course this depends on what battery u get.
They make an adapter for this also, but i would do it with just changing the connector to save weight
jevs is offline Find More Posts by jevs
Old Nov 17, 2012, 08:17 PM
Joined May 2011
thanks for the info. I think the nanos come with the 2 wire jst. Im use to using deans and I believe they make a micro version so that will be my route.
But back to the beast and the 3 wire going to the speed control. what do i do with the third wire if I'm using the deans micro ?
Can a plane with the AS3X system cause any issues when flying non AS3X ?
in other words can it induce bad flying habits when flying non AS3X bigger 3d planes ?
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
