Old Oct 22, 2012, 10:40 PM
rclayton is offline
Find More Posts by rclayton
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Could someone tell me the kv on the v1 Beast? I'm debating on putting the motor in my Beast 3d. Any suggestions to alternate brushless motors?
rclayton is offline Find More Posts by rclayton
Old Oct 22, 2012, 11:05 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
beast v1 has 2300kv motor--superior to beast3d 2500
definetly put in the 2300 and run with 5043 prop and you will see much more power, quieter, and batteries last longer.
flyrtim is offline Find More Posts by flyrtim
Old Oct 22, 2012, 11:23 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
But with anything but the stock E-flight batteries! The amps for the 5043 are available only from Hyperion, Minivation, Thunderpower, et. al.
erkq is online now Find More Posts by erkq
Old Oct 23, 2012, 10:02 PM
tourist_603 is online now
Find More Posts by tourist_603
Joined Dec 2007
Wing repair
After a semi-bad landing on good grass, the next flight took a lot of right trim. Inspection after landing revealed that the lower left wing was free floating at the root. So it was not just the canopy that departed in mid-flight causing the trim change. My question is- what glue to use to reattach the wing root, or can I get away with just taping it across the bottom? The top of the lower wing to fuselage joint would be tricky to tape properly. I am thinking of a LITTLE bit of five minute epoxy run into that narrow joint, but that may make a clean replacement of the entire wing later more difficult.
tourist_603 is online now Find More Posts by tourist_603
Old Oct 24, 2012, 07:41 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Glues: Foam Safe CA or FoamTac. I haven't used it but there are some vehement supporters of that FoamTac stuff. As to the cracking at the root, it is a common place for the wing to break in a crash. After a RX interference issue that caused a full throttle, full aileron, full elevator straight down crash on my B3D both lower wings were severed and the top wing was cracked in half to one side of the cabane. I repaired it with foamsafe CA and some CF rods. It is probably stronger now than when it was new.
-Brian
kalmon is offline Find More Posts by kalmon
Old Oct 24, 2012, 08:21 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
UHU Por (also known as UHU Creative) is another excellent glue for these planes: http://www.hobby-lobby.com/uhu_glue_409_ctg.htm
Joel
turboparker is online now Find More Posts by turboparker
Old Oct 24, 2012, 10:35 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
I vote FoamTac. I really like the tightness of the bond and the flexibility. My Beast kept breaking right next to the last repair. Seems like the CA makes the foam brittle, the joint certainly is brittle. Also, the CA joint I can see as when I shoot kicker on it it makes a small ridge. The FoamTac is pretty much invisible if it is a clean break.
I'm waiting on wings for my Beast and hoping the wing kit comes with control horns as the replacement horn sent my by HH is crazy huge. It's so big the control rod doesn't fit and I have it taped on. Scary looking, but it flys.
shastamike is offline Find More Posts by shastamike
Old Oct 24, 2012, 11:24 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I dorked mine in the other day and broke both outer struts and knocked the wing loose from the inner struts.Glued everything together with hot glue and it flies the same as before. "A little dab'll do ya" as the old Brylcream add used to say I make my micro foamy horns from 1/32 aircraft plywood.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Oct 24, 2012, 11:51 AM
shastamike's Avatar
Joined Jun 2010
Thanks...it never occurred to me that I could make my own horns.
Old Oct 24, 2012, 01:14 PM
Bloosee is online now
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
Foam Tac is the only thing that holds my repairs. In my experience CA just doesn't cut it on this airframe. I don't like CA anyway as its brittle. Love foam tac, makes me confident in my repairs, and unlike CA it won't stick to your fingers and gives you plenty of time to break lined up. I use Foam Tac on the UMX planes but Welders Adhesive on EPP.
Bloosee is online now Find More Posts by Bloosee
Old Oct 24, 2012, 05:22 PM
shastamike's Avatar
Joined Jun 2010
Got an email from HH today and it was that control horns i've been looking for come with the replacement wing set. Not sold separately. Too bad, by now I have one of the funkiest Beasts around I bet. The oversized control horn on one side makes it look like it has a badly sprained ankle.
Old Oct 24, 2012, 05:34 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
That type of bs makes me less likely to buy any more products from HH. Why won't they sell them seperately? Because then they wouldnt be able to suck more $$$ out of you for parts you don't need. Can you imagine? "sir, I would like to buy a new tire for my car" " okay, but you can't buy just a tire, you have to buy a complete axle assembly too". Give me a break.
stuball56 is offline Find More Posts by stuball56
Old Oct 24, 2012, 05:43 PM
shastamike's Avatar
Joined Jun 2010
Happens with my Subaru. Can't just replace one tire as the All-Wheel traction system is tied together. Three worn tires and one new tire would supposedly burn the system out.
As to the very tiny horn part, I don't know. There are so many parts. Is kind of odd. They very nicely sent me control horns they sell separately, but they were for micro sized and look huge on my Beast.
BTW, found some nice looking vintage tires that might be nice on the Beast. http://www.graysonhobby.com/catalog/...12-p-1040.html
Old Oct 24, 2012, 07:14 PM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Are you thinking those wheels with or without the wheel pants?
Old Oct 24, 2012, 09:21 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
These are homemade liteply wheels 1 1/4 in. dia. they work very well as they cut through the grass rather than trying to roll over.
Gord.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
