Old Jun 13, 2012, 07:50 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by erkq View Post
Your write about your passions very well. + about a billion...
Originally Posted by flyrtim View Post
3S made easy ?
the passionate talk of amazing 3s has got my attention this time--and I shall now consider the possibility of 3s for my 3d beast and as3x sbach.
any decent 3s batts available that use the umx connector and not the minijst that are reasonably priced like the 2s hyperion 240 which is $11 shipped ?
I rather not solder on new connectors on the planes or on my 2s hyperions--though
perhaps Glenn makes an adapter....
Erkq,
Thanks for the kind words!
Flyrtim,
See RCBabbel for 3s Hyp 180 packs w/UMX connector & a balance tap that are nearly the same weight as the stock 2s pack. See Glenn for a charging cable to fit your aftermarket charger. Be sure to tell him that you're charging a 3s Babbelbatt.
Regarding the DeoxIT - you want to spray it into into the wiper area. I use it whenever a servo starts to get jittery. Happens about every 20-30 hours on my mCP X. I have over 90 hours on original servos. So far, the mCP X is the only UM on which I use DeoxIT as part of a regular PM routine.
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 13, 2012, 08:05 PM
Jwhatley is offline
Find More Posts by Jwhatley
Joined Apr 2010
I don't know if you guys have looked at navigation lights for your Beasts but I installed them a couple of days ago and they look pretty bad a$$. You put them on your gear switch (channel 5) so you can turn them on & off. They're really tiny and light and they don't appear to affect the flight times. www.sf-design-solutions.com
Check them out.
Jwhatley is offline Find More Posts by Jwhatley
Old Jun 13, 2012, 08:44 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
Originally Posted by turboparker View Post
Erkq,
Flyrtim,
Joel
which is the wiper area of the servo please ?
flyrtim is offline Find More Posts by flyrtim
Old Jun 14, 2012, 06:34 AM
Joined Jul 2009
The wiper & resistive strip are right under the jackscrew. Usually, you can just spray the cleaner into the opening along the jackscrew. I'm not sure where it lives, but there is a servo cleaning/disassembly tutorial somewhere in the UM threads.
Joel
Old Jun 14, 2012, 08:32 AM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Joel
http://www.parkflyingfun.com/ParkZone_linear_servo.html
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Jun 14, 2012, 10:15 AM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
BobaFett1138 ---
I wonder if you are having the sticky servo issue that I and others are having...
Hmmm.... never mind. I took off the hatch, manually centered the mechanics, and now she's working fine. Bizarre though....
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Jun 14, 2012, 12:50 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Dogfight: 2300kv vs 3000kv motor
I posted my review of the 2300kv vs the 3000kv motor over on the other Beast thread here.
kalmon is offline Find More Posts by kalmon
Old Jun 15, 2012, 07:20 AM
bonnie9496 is offline
Find More Posts by bonnie9496
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Great review of the options
Love my B3D flying on 240mAH Hyperion 2s with GWS 5030. Have been looking for more performance and hovering on 2300kv, 3000kv or going 3s
Hmmmmmm
bonnie9496 is offline Find More Posts by bonnie9496
Old Jun 15, 2012, 07:47 AM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Brian or others,
Did you ever try my 3S combo?
Stock motor (2500Kv) GWS 5030 prop??
My motor is barely warm after a flight.
I've never experienced OCP or OTP, ever.
I've flown in 80 temps.
rc
Old Jun 15, 2012, 08:01 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Not yet
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jun 15, 2012, 09:59 AM
Fighting Gravity
bonnie9496's Avatar
Joined Jan 2011
Originally Posted by RCBABBEL View Post
Brian or others,
rc
3s is very, very tempting. Even if the batteries do have to come from half a world away
RC do you need to do anything to the brick for 3s....or just "plug em in and fly" ?
Old Jun 15, 2012, 11:18 AM
khooke is offline
Find More Posts by khooke
Joined Aug 2004
I just checked the HH site and they have the AS3X receiver back in stock... for those waiting for a warranty replacement, hopefully they're shipping them out soon :-)
khooke is offline Find More Posts by khooke
Old Jun 15, 2012, 02:11 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
aoisdufoi Cant wait!!!!!!!!!!!!!!
3d astronaut is offline Find More Posts by 3d astronaut
Old Jun 15, 2012, 03:21 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Just plug and fry...er..fly! j/k but even though there have been no reported failures of AS3X bricks on 3S it is still at your own risk. That said it is REALLY fun!
Brian or others,
rc
RC I've tried the B3D on all the known normal setups.
2500/5030- 2S 3S
2500/5x3x3 - 2s
2500/stock prop - 2S
3000/5030 -2S 3S
3000/5x3x3 - 2S
2300/5043 - 2S 3S
I left out the 2500 from the review as it definitely is the lowest performance of the 3 and there are tons of reports on it already.
As a general rule on 3S any motor that works is 200% better than any combo on 2S. The trouble for me was finding a combo that worked on 3S without my weak brick shutting it down in flight!
The main reason I have the 3000kv motor in there is it has the best overall performance on 2S. I live out of town and the noise doesn't bother me at all. I kinda like it, it is still <25% of even the quietest gassers.
Hmmmmmm
If you are looking for hovering the 3000kv and a 5030 is probably the best i've found so far. I do plan on testing my 2300 with my custom5530 and a stock gws 6030. If the 6030 works well it "should" provide the best hovering as the prop disc is larger, if the motor can swing it effectively. All very theoretical at this point as there is a lot that goes on when changing prop sizes.
-Brian
Old Jun 15, 2012, 06:30 PM
RV4flyr is offline
Find More Posts by RV4flyr
RV4flyr's Avatar
Canada, ON, Brampton
Joined Mar 2011
Got my 3s fix !!
Thanks to RCBabbel, I rec'd 3 more 180 3s packs this week for outstanding B3D performance. If you haven't tried it you should, you will never go back to 2S.
Thanks again RC,
KF
RV4flyr is offline Find More Posts by RV4flyr
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19299 Today 03:51 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
