Old Jun 04, 2012, 09:21 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Hey guys after requesting Glenn over at rc-connectors make a mcpx 1s to umx beast 3s plug, he has emailed me the link to buy it cant wait for it to get here! I have a ton of the mcpx batteries laying around and at $2.75 a piece at hobbyking, the price cant be beat. Heres a link to the connector!
http://www.rc-connectors.com/index.p...roducts_id=374
3d astronaut is offline Find More Posts by 3d astronaut
Old Jun 05, 2012, 02:36 AM
Geoff2005 is offline
Find More Posts by Geoff2005
Geoff2005's Avatar
Perth, Western Australia
Joined Jul 2006
Just tried out fitting the Mighty Midget. Slides straight in same mount same motor tube hole. With prop the MM is 9gm, comparedt to 10g for stock motor that also has spinner and connector.
Pics show motor in place with 6 x 3 prop.
Geoff2005 is offline Find More Posts by Geoff2005
Old Jun 05, 2012, 09:10 AM
GoElectric is offline
Find More Posts by GoElectric
Canada, AB, Edmonton
Joined Jun 2002
Rudder servo not moving at all
Please help.
I have the beast 3D for about 25 to 30 flights and the rudder servo just stops working, it does not move at all at the center position. There has not been any end travel binding, no crashes. Does it happen to anyone else ?
Can I just replace the servo mechanic (SPM6832) and see ? How can I find out whether it is the servo motor or the servo electronics problem ?
GoElectric is offline Find More Posts by GoElectric
Old Jun 05, 2012, 11:32 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
How does it fly? I know that on the stock motor the 6x3 bogs it down. What is the kv of the Mighty Midget?
-Brian
kalmon is offline Find More Posts by kalmon
Old Jun 05, 2012, 12:30 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Originally Posted by GoElectric View Post
Please help.
My elevator servo locked mid-flight on about my eighth flight. Horizon support had be ship it in. A whole new plane was dispatched about an hour or so after the old one showed delivered. Not happy I had a problem, but the service is top-notch. Perhaps their service is just as good in Canada.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jun 05, 2012, 07:10 PM
Geoff2005's Avatar
Joined Jul 2006
-Brian
Hi Brian,
I haven't tackled the electrical connector yet, and hence no flight trials.
I would have thought putting a bigger prop on the stock motor would just result in overcurrent problems.
Mighty Midget don't put specs up for the motor kV but they do a table of prop size, amps and static thrust based 2S or 3S. I am using the slower wind 8gm.
http://www.microbrushless.com/productsG3.htm
BTW what are the sort of currents is the Beasts speed controller is happy with? On my outdoor flight I got what I thought was a LVC while trying out a prop hang. I was using the recommended Eflite 180 2S and when I recharged it took less then 80mAhr to full. I've just got same size batts (Nano-Tech) from HK.
Old Jun 05, 2012, 07:27 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Hi Brian,
I don't have a way of testing amps on this scale, however the brick is completely happy with quite a bit of draw. The LVC you got was almost certainly from poor quality eflite 180. Those batteries have REALLY BAD V-drop under load even when new. With a Hyperion240mAh I flew my stock 2500kv motor with a 5"x3" three bladed prop and didn't have a single over-current issue. Same while testing with a 6x3. That said the 2500kv motor is probably the weakest in the BL180 line. The 2300kv and 3000kv both outperform it. I just came in from flying my B3D, Fully charged 3S 12.6v packs on a 3000kv motor with a 5030 prop. Not a single current problem.
Sorry I don't have hard numbers but I hope that helps.
-Brian
Old Jun 05, 2012, 08:39 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
......BTW what are the sort of currents is the Beasts speed controller is happy with?.....
Geoff,
The Beast 3D's ESC is rated for 4.9A continuous & 5.8A peak. It also has an over-temp shutdown. Not sure what the temp threshold is, however.
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 05, 2012, 10:50 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
Honestly though changing to the 2300kv motor, while kinda pricey,
I think 2300 is cheap.....
2300kv for almost free --$1
buy new 2300 for $18 shipped
sell your used 2500 in classifieds for $20 shipped (spend $3 on shipping and paypal fees)
I've done the above 3 times.
http://www.ebay.com/itm/Parkzone-BL1...item3f16410d41
flyrtim is offline Find More Posts by flyrtim
Old Jun 05, 2012, 11:00 PM
flyrtim is offline
Joined Aug 2011
Please help.
similar thing has occured to a number of us on the elevator servo. the mechanic fix might work....and seems worth a try since mechanics are less than $5 and probably easier to replace mechanics then replace the whole servo and have to solder. also since this is the rudder--much less risky---if it doesn't fix it then you won't crash unlike my elevator servo dying.
Old Jun 06, 2012, 01:52 PM
flyrtim is offline
Joined Aug 2011
She Rises: Ode to a Beast
Warbird-
Not she, though valor and glory are hers
A wounded existence—true
Let not your Foam-Tac wing by liquefied by the sun
Icarus is not your name
Rise again,
Turn once more 5043
Spin forevermore on the 2300
Hyperion- Let your electrons dance
Let loose the fury within
Rise up,
She has the markings of the beast-
Is this the apocalypse ?
Be you a fallen angel ?
Rise once more-
Gravity has no right to you
All shall know this being,
Submit whilst you raise your eyes
She rises
Old Jun 06, 2012, 02:27 PM
marke14 is offline
Find More Posts by marke14
RC pilots do it in the air
marke14's Avatar
Joined Dec 2011
flyrtim - I love your poem! Are you riffing on another, similar poem? Sorry, poetry is not my forte ...
GoElectric: same thing has happened to me, just last week. I just sent my B3D back to Horizon for warranty evaluation. My problem is exactly as you described - except that mine only took 4 or 5 flights to develop this issue!
If you look at the UMX Carbon Cub thread, there is a big discussion of essentially atmospheric corrosion (in China, where the components are manufactured and assembled) that has affected, seemingly, large batches of HH components. Notably their linear servos. Some of the Carbon Cub guys are proactively using some kind of cleaner or solvent or something to try to remove the corrosion before it becomes a fatal issue. I guess it's called "Deoxit"
http://www.rcgroups.com/forums/showt...umx+carbon+cub
I am not stating that this is what lies at the heart of this issue with the Beast 3D; I am only making an observation based on reading way too many RCGroups threads and posts, comparing symptoms reported by different users of the same company's products, and drawing my own conclusions.
I will say, for the HH employees who will undoubtedly read this, that I am a huge HH fan otherwise and currently 80% of my fleet is either Horizon (Champ), Parkzone (UM T-28 and PZ T-28) or E-flight (Beast 3D).
I was in my local hobby store yesterday after work (looking wistfully at the Beast 3D), and I remain impressed by the breadth of their offering.
marke14 is offline Find More Posts by marke14
Old Jun 06, 2012, 05:04 PM
bonnie9496 is offline
Find More Posts by bonnie9496
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Enjoying my Beast 3D.
It is though starting to look beaten up and needs a replacement wing set. I presume they are........however can anyone confirm that the original Beast and 3D Beast have same wings set??
Thanks Bonnie
bonnie9496 is offline Find More Posts by bonnie9496
Old Jun 06, 2012, 05:14 PM
Joined Jul 2009
Flyrtim,
I also enjoyed the poem. Well-done!
Bonnie,
The only difference between V1 & 3D wings is the graphics.
Joel
Old Jun 06, 2012, 05:20 PM
flyrtim is offline
Joined Aug 2011
Deoxit
anyone know which one to get ? lubricant, grease, spray, gold, cleaner......
many products to choose from.
one with needle applicator seems best I think for applying to servo.
http://www.caig.com/
http://www.ebay.com/sch/i.html?_sop=...w=deoxit&rt=nc
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19303 Yesterday 10:00 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
