Old May 14, 2012, 07:12 PM
flydown is online now
Find More Posts by flydown
flydown's Avatar
United States, AZ, Peoria
Joined Aug 2010
Any recommendations for what full wheel pants work well.
I seen this photo.
http://static.rcgroups.net/forums/at...%20fairing.jpg
flydown is online now Find More Posts by flydown
Old May 14, 2012, 07:32 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
I seen this photo.
yep that's my photo.
I was selling my used shapeways pants--sold.
to buy new:
http://www.shapeways.com/model/30623...eel-pants.html
shipping is steep so consider also getting the beefy prop adapter--
and/or order directly from ICU here on the forums. He might have some himself and shipping directly from him may be less. ICU is the designer of the pants I believe.
flyrtim is offline Find More Posts by flyrtim
Old May 14, 2012, 07:42 PM
flyrtim is offline
Joined Aug 2011
stuck elevator servo--creative solutions desired
1. replace whole brick--most likley--waiting on backorder
1.5 clean out elevator servo and lubricate a bit--helped some--not enough..
2. replace elevator servo (nope soldering and wiring too advanced for my skills)
3. reroute rudder servo and control arm to elevator . program dx6i to have rudder be on the right elevator stick? possible ? if so, how ? intermittent rudder no problem. intermittent elevator-big problem.
Old May 14, 2012, 08:08 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
If this is a Beast3D you cant swap the control arms. AS3X would then be making pitch corrections on the rudder and yaw corrections on the elevator. Needless to say it would fly very poorly or most likely not at all.
looks like best option is to wait on the new brick.
-Brian
kalmon is offline Find More Posts by kalmon
Old May 15, 2012, 12:01 PM
RV4flyr is offline
Find More Posts by RV4flyr
RV4flyr's Avatar
Canada, ON, Brampton
Joined Mar 2011
Originally Posted by RV4flyr View Post
My last 2 flights on the 3s I have experienced LVC type cut off in the 1st min. Or so,battery was fully charged, landed oK but I am wondering what is going on, running 5030 prop, motor is fairly cool.
ANY input or cause would be appreciated.
KF
Update:
I have flown 2 180-3S Babbel Batts since above issue & now the LVC like symptoms ("touch wood") seem to have gone. The only thing I changed was the prop to a new 5030, It seems I had a light prop strike which cracked 1 prop tip & I am assuming that maybe the unbalance caused it to respond as low battery or overtemp.....go figure.
I am having so much fun I will likely need more 3S batteries !!
KF
RV4flyr is offline Find More Posts by RV4flyr
Old May 15, 2012, 06:14 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Update:
KF
KF,
Excellent news!
When I first started flying (3S) in my B3D, my slightly out of balance prop was freaking out the AS3X system at WOT.
Once I got everything balanced it's been pure joy!
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old May 17, 2012, 11:51 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I just posted my 3S opinion over on the other Beast thread here.
-Brian
Old May 17, 2012, 12:32 PM
RV4flyr is offline
RV4flyr's Avatar
Joined Mar 2011
-Brian
Interesting comparison & may be worth a try. I assume you extracted the 3000 kV motor from the GeeBee ?
I hope I didn't miss it but did not cover any flight time differences, knowing that we all fly different power settings at times, but a estimate would still be interesting....
Thanks for your work in starting this comparison,
KF
Old May 17, 2012, 12:34 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
The Stryker runs the 3000kv motor.
erkq is offline Find More Posts by erkq
Old May 17, 2012, 12:54 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Check out my B3D flying field...
Google Earth.
Search: 371 Eastland Dr. N. Twin Falls, ID
Ascension Field.
Perfect RC name.
Always empty during weekdays.
Comes with my own porta potty.
New restrooms currently being built just for me.
The Church leases the land to the Cily.
Recently the minister came out to check on me.
Just wanted to introduce himself and see if I was having a good time.
I'm spoiled!
rc
Old May 17, 2012, 03:19 PM
RV4flyr is offline
RV4flyr's Avatar
Joined Mar 2011
Sorry if already asked but I am curious......
Does Stryker have same board/ESC as B3D for running 3S with confidence ?
KF
Old May 17, 2012, 04:31 PM
erkq is offline
Joined Dec 2010
KF
No, it does not. It's very different with elevons and all, plus no on-board servos. I'm not sure anyone has tried the Stryker on 3S. It's so crazy with a 4040 prop and good batteries I don't think anyone has thought they needed to! But there are always those envelope pushers.
Old May 17, 2012, 06:12 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
KF
The Stryker & Sbach use the AR6400NBL non-AS3X brick. If I remember correctly, running 3s in the Sbach turned out to be a crap-shoot.
Joel
turboparker is offline Find More Posts by turboparker
Old May 17, 2012, 08:06 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Joel
Yeah that's correct, There were quite a few reported failures, even some at 12.0v
KF
I bought a 3000kv motor from HH. I used a safety pin to remove and then reverse 2 wires from the connector so the direction would be correct. It was VERY easy, no soldering required.
Flight times are not going to be very useful as I think my brick is a "Monday" weak quality one. On 3S I can't fly any sustained 70% or more throttle without hitting OCP. So the flight times are a little longer than If I could really fly it hard. I guess comparatively speaking I was getting 5:30min to 80% with leisurely sport 2S flying on the 3000kv. And even though I've only had a few 3S flights I've been landing at 5min and been at about 65% discharge so it'd appear that for the same type of flying it's pretty close. Although I definitely do not have a lot of 3S data to confirm that. I'd assume that at the higher voltage the amp draw should be slightly lower for similar flying.
My last charge:
5:00 flying
battery 3S 180
put back 123mAh - 68%
to get to 80% would be 5:50 flying
.41mAh per sec on 3S
my average on 2S
5:00 min flying
210mAh MA battery
put back 150-160mAh
.5 - .53 mAh per sec on 2S 3000kv
my average 2S flying is much more hard aerobatics, not much 3D though. Even so a .1mAh per second draw is enough of a difference to get another min of flight especially considering its lugging another 8 or so grams of battery around.
-Brian
Old May 17, 2012, 11:11 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
I got one (3S) Stryker 4040 flight in a few months ago.
http://www.rcgroups.com/forums/showp...postcount=3583
WOW was she fast!
Flight attempt #2 cost me my brick.
For some strange reason, the AR6400NBL Rx in my Sbach doesn't mind 3S power.
rc
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19286 Apr 11, 2016 03:54 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
