Old Mar 23, 2012, 01:09 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Took the Beast 3D out again today, 4 more BB240s through it today.
It was much better this time round since I learnt to keep it still after putting the battery in!
A couple of things though: even with the H240 onboard it seemed underpowered on the stock prop
It also needed a lot of left aileron trim and right rudder. Turns to the right were awful - it just sideslipped unless lots of rudder was used...
I landed and adjusted the control surfaces so the trims could be centred, they look way off now on the ground but it flies well.
The wheel pants have gone too! On the second battery one caught in the grass and got pulled off so I took the other off.
All in all though nice flights
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Mar 23, 2012, 01:54 PM
jaas75 is offline
Find More Posts by jaas75
jaas75's Avatar
United States, PA, Pittsburgh
Joined Oct 2006
try the gws 5x3 prop on the stock motor , give it lot more power than the stock prop.
Also some people here upgrade the motor to the one in the v1 beast 2300kv or the geebe motor of 3000kv for more power.
Wish begs the question guys does some one of you know any similar motor to the 2300kv or 3000kv on the cheap side?? (29dls its not much i know, at least any more lol).
i mean like hobbyking or any chinesse supplier??
lets say i have 2 beasts one stock and other ready for "upgrades" (i know the eflite ones im looking for the easterns upgrades)
jaas75 is offline Find More Posts by jaas75
Old Mar 23, 2012, 02:19 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
SP,
I suggest trying the 5030. It provides a noticeable increase in performance & slightly longer flight-times, as it is more efficient than the stocker.
Regarding the excessive trim - you mentioned that it needed lots of left-aileron & right-rudder trim. Sounds like a possible cross-control issue to me. For instance - too much right-rudder trim would cause a roll to starboard, which would require left-aileron to correct. This results in a cross-control situation - the same thing one does on purpose during a forward-slip crosswind landing. However - in normal flight, cross-controlled rudder & ailerons can cause a number of handling problems.
A misaligned vertical or horizontal stab can also cause strange trim issues. I've noticed that a few V1 & 3D Beasts have misaligned tail surfaces. I got into the habit of inspecting my UM planes before leaving the LHS. I once looked at four Beast 3Ds before finding one that was right on the money, alignment-wise. I've seen vertical stabs that weren't quite vertical, and a few that weren't quite parallel to the fuse. I've also seen horizontal stabs that weren't quite horizontal.
For your reference, here is a flight-trimming guide, courtesy of the NSRCA (National Society of Radio Controlled Aerobatics):
http://nsrca.us/index.php?option=com_content&view=article&id=177:t rimchart&catid=114:flying&Itemid=187
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 23, 2012, 02:51 PM
BMFA 190658
Joined Mar 2007
Thanks Joel!
I do give all my models a pre-flight check, just like my full size gliders. With the Beast though I'm still a noob. I just check all the wing bracing for security and check for damage.
I have an Sbach with a 3000kv/5030 combo which is spot on power wise, just a bit on the loud side. I'd like to keep the 2500kv on the Beast as it is nice andd quiet. I have another 5030 in stock but think I'll try my 5043 in this one. Does that sound fair?
FYI I fly at sea level at my gliding club and about 500' at home so no mammoth elevation to worry about...
Cheers,
Tony
Old Mar 23, 2012, 03:05 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Thanks Joel!
I have an Sbach with a 3000kv/5030 combo which is spot on power wise, just a bit on the loud side. I'd like to keep the 2500kv on the Beast as it is nice and quiet. I have another 5030 in stock but think I'll try my 5043 in this one. Does that sound fair?
Cheers,
Tony
That's the first time I've heard that one!! If you like quiet try the 2300kv 5043 combo it really close to the power of the 3000kv 5030 combo, except MUCH quieter..
-Brian
kalmon is online now Find More Posts by kalmon
Old Mar 23, 2012, 03:11 PM
BMFA 190658
Joined Mar 2007
Hi Brian,
Yeah I've heard that about the 2300/5043 combo, I'm on the lookout for a cheap 2200/2300kv motor.
Guess I'm just thinking it's quiet compared to my Sbach!!
Tony
Old Mar 23, 2012, 03:20 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Hope you guys can help me. I've got a Beast 3D receiver and the ESC is not working right. I've gone through the programming to make sure everything is set to the defaults. When throttle is applied, the prop chatters back and forth... the more throttle, the harder the chatter. Sometimes at high throttle it'll start running right, but it has a weird harmonic. The motor shaft gets warm (I'm holding it) during the chatter. I've measure AC voltage through ever pair of the three motor wires and get 6 volts at mid-throttle.
EDIT: It does this with 3 different motors, so that's not it.
erkq is online now Find More Posts by erkq
Old Mar 23, 2012, 03:38 PM
Joined Jul 2009
Thanks Joel!
Cheers,
Tony
Tony,
You're welcome! Regarding the 2500Kv/5043 combo - many of us find the 5030 to be a much better match to the 2500Kv motor. As has been noted - the 2300Kv/5043 combo dramatically improves vertical performance and top speed, as compared to the 2500Kv motor with any commonly-available, appropriately-sized prop. The 2300Kv/5043 combo provides similar speed & thrust to the 3000Kv/5030 combo - with longer flight-times.
With the 2500Kv motor, I'd go with the 5030 on the B3D.
Joel
Old Mar 23, 2012, 03:45 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Sounds like you've got a bad board. I had this happen with a replacement Sbach that was sent to me one time...
turnerm is offline Find More Posts by turnerm
Old Mar 23, 2012, 04:15 PM
Joined Jul 2009
Erkq,
I agree with Turnerm. Sounds like a bad ESC.
Not sure what you used to measure the AC, but the frequency & waveform shape of the ESC's output usually causes multimeters to display erroneous readings. Most multimeters are only accurate when measuring sine-waves at or near 60Hz. Some are rated for sine-waves in the audio frequency range. A scope is typically used for measuring the amplitude of complex waveforms, such as those produced by modern ESCs.
Joel
Old Mar 23, 2012, 04:26 PM
erkq is online now
Joined Dec 2010
Originally Posted by turboparker View Post
Erkq,
Joel
Yeah... should have been clearer about the use of the MM. I realize all that you say but do not own a 'scope. I was only looking for something "different" between the pairs.
Well, dang... lost my AS3X board. What do you do, just throw it out? Can the servo's be taken off and used?
Old Mar 23, 2012, 07:31 PM
BMFA 190658
Joined Mar 2007
Thanks Joel!
If I dont get a 2300kv motor then I'll use one of my 5030s
Old Mar 23, 2012, 07:53 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Check the motor/esc wire connectors for a loose pin connection. Also check to see if the wires are still soldered in place on the board. The next components in the chain would be the fets themselves. These usually show physical damage when they're blown.
If it's a fet, I can replace it for you. Overall, it sounds like your 3 phase bl motor is only running on two phases.
Reference:
http://www.stefanv.com/rcstuff/qf200212.html
http://www.helifreak.com/showthread.php?t=64727
Silverexpress is offline Find More Posts by Silverexpress
Old Mar 23, 2012, 07:59 PM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
Why not call horizon and try to get a new one? Sounds like a defect, so I'd assume they'd replace it.... But you should be able to use the servo mechanics, but they'd need to be soldered onto another board.
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Mar 23, 2012, 09:00 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Spring has Sprung!
Beast 3DS addict checking in.
60+ Hyp (3S) 180mAh flights and loving every minute!
I've changed only the prop (GWS 5030) and the batt.
She still flies light enough to spot land her on my driveway.
Her power is spectacular!
AS3X is simply amazing!
rc
Joel received his beta Hyp (3S) 180s this week.
Shoot him a PM and tell him to post a Beast 3DS vid sn.
RCBABBEL is offline Find More Posts by RCBABBEL
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
