I'm starting to think that slightly beat-up Beast flies better than a brand new one! I put mine through the ringer last night in my front yard. Now that I'm really getting the hang of rolling harriers on my larger planes I'm trying to translate that same knowledge to my wee Beastie.
Well... I can say that I've basically got them nailed down but I beat up my little Beast in the process that's for sure! I can now do full rate rolling harriers on the Beast and they are smooth as silk. But trying to do them in a fairly tight space will REALLY test your skills and your nerve. I need to get some video footage up again soon. I'm also really starting to figure out torque rolls on this plane as well so that I'm more in control once it starts torque rolling. I'm trying to control it so that it doesn't just fall out of the roll. I've had a few instances where I get way too many rotations to count but it requires you to establish a perfectly balanced stationary hover first and then if you EASE into the torque roll while staying perfectly balanced then you can slowly speed up the roll (by gradually letting off right aileron) and sometimes go into a full left aileron roll where it will spin madly. If you get it right you can hold it for quite a while. It's pretty cool! |
I'd love to see the vid Turnerm... the 3D stuff is cool, but somewhat confusing to me. I can see that most of the flight damage on these planes is from doing/learning 3D lol.
Couple questions.... how much flight time are you getting from Hyperion 180's on the stock setup?? ... and how long do you wait between flights??? Had a perfect flying day after work yesterday (love the daylight savings time change). ZERO wind, slightly overcast. I am still waiting on my 5043 prop (have not put the V1 motor in yet), so running stock. Most of my flying was pattern, and basic acrobatics, and 90% was full throttle. I ran through 3 hyperion 240's, then started on my 180's. Really was not waiting at all between flights as this motor will be out of the plane in a day or 2 max anyway. I broke in the hyperions on a 3 minute timer, then had changed to a 4 minute timer for about 10 flights each, and now had it set at 4 mins, 30 seconds. First 180 was fine, timer went off, landed. The second one at the timer I noticed the plane slowing, brought it over near me... heard the LVC (first time ever), and landed immediately. The next (and last hyper 180) then went in the plane and hit LVC just over 4 mins... lost power very fast.. literally had to land where the plane was cuz it was coming down. Just to see after landing I tried to throttle it to hear close up the LVC noise, motor would even come on. Think I had read somewhere that after a few flights the motor will use more power as it is warm, this could explain it, and would mean I need to run the weaker batteries first. But does make me wonder if I will even be able to use my 180's after the motor prop change. Also I have not ruled out that this motor (which is my problem motor, but seems ok now) may be pulling more current that it should. Opinions? |
(BTW -- In simple terms, what's the diff between a rolling harrier and a torque roll? Do they look pretty much the same to spectators, even if the pilot initiates and controls them differently?)
The new HD linear servos that were designed for AS3X are mandatory. Horizon's older linear servos can't handle the extreme loads of a fly-by-wire system, such as AS3X. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Pug, Time to spend some time with the BoneDoc. http://www.rcgroups.com/forums/showthread.php?t=904349 Also, the B3D isn't the machine to begin with. ![]() rc
A torque roll in (usually) when you have the plane locked into a hover and it begins to rotate to the left. I perfectly executed torque roll will have the plane sitting still and rotating perfectly around it's axis without drifting (but this is rather difficult). I can do them with my larger planes MUCH easier than with the 3D Beast. The smaller plane means you have to be WAY quicker on the sticks. A rolling harrier is a manuever where your flying in harrier (tail stalled) but the plane is rolling without losing altitude. There are many varieties of this but that's mainly what it is. You can go in circles (a rolling circle) or you can roll straight (rolling while the plane travels in a straight line). You can also do normal rollers where you're rolling but not in harrier. To see examples of both, check out this video of my 51" Slick from this past weekend. It's mainly full of rolling circles/harriers but I think there's a dirty torque roll or two in there too.
The Sim has been "helpful", but for whatever reason, I dont translate well from Sim to reality for 3D maneuvers - I think just because I'm too chicken to fly the Extra 300 low when trying 3D - For example, I think a hover would be "easier" if it were at 10' where I can see it than it is at 75' where I'm comfortable that I can recover before having a bad case of toothpickitis. I expect the Beast will be the HARDEST of my planes to 3D - despite its fantastic responsiveness - but I could be wrong, would not be the first time! ![]() jc |
You are NOT wrong here. This plane is not easy to 3D with. It's fun and it's rewarding but it's not the easiest. |
jc, Lil bro is a Slick addict. Excellent plane! Just put in a bunch of stick time and have some fun! rc
Thanks for the comments... good things to think about! Cant wait to get the ES in, and start messing around. I hoping it will make me a better Extra Pilot, and a better Beast Pilot - if even by a little bit. I will be interesting to see how skills developed on IT will translate to the Beast (or extra). |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16679 | Today 04:07 PM |
| Sold Eflite UMX Beast w/3batt and charger $120 shipped | RobDog | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Feb 06, 2011 09:40 PM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
