Old Mar 12, 2012, 05:59 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by BobaFett1138 View Post
That sounds like the end of EVERY flight of mine....... Ok, not quite, but yes, I do scare myself quite often. My beastie is gonna need some replacement wings pretty soon.....
LOL
I've replaced the B3D's wings, and done several rounds of various other repairs.
She don't pirouette quite so sweet anymore.........
So, while I still fly her (plus a bunch of other rescue birds), I daydream of the next generation of objects of desire -- which I hope will be appearing soon in our LHS!
pugsam is offline Find More Posts by pugsam
Old Mar 13, 2012, 08:28 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I can pick up a full scale p-51 in my LHS ?!?! SIGN ME UP!!
-Brian
kalmon is offline Find More Posts by kalmon
Old Mar 13, 2012, 10:10 AM
Swilson50 is offline
Find More Posts by Swilson50
Dodge City, Kansas
Joined Oct 2003
Which aileron servos for AS3X
For you guys who are putting your Beast AS3X bick in other planes, which aileron servos are you using?
Swilson50
aka Stan in Dodge City
Swilson50 is offline Find More Posts by Swilson50
Old Mar 13, 2012, 10:35 AM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
Swilson50
Think you have to use the beast servos, IE, 1.9 grams w/ball bearings.
http://www.spektrumrc.com/Products/D...d=SPMAS2000LBB
The 1.7grams should WORK, however, the reason that they put the 1.9's in the beast is because of the constant chattering. According to them, the regular servos would likely wear out quickly. Whether it's true or not... *shrugs* however, I'd get a pair of 1.9's to be safe.
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Mar 13, 2012, 10:59 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Swilson50
Yup... the HD servos went on the wings of my Sbach when the Beast 3D brick went in.
erkq is offline Find More Posts by erkq
Old Mar 13, 2012, 11:08 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Beast 3D guts into UM Stryker?
I'd like to transfer my B3D brick, motor and servos into a more durable airframe.....the UM F-27Q Stryker.
There doesn't appear to be any report of anyone doing that, so far.
Would it work, since the Stryker has an elevon setup? (My TX is the DX6i.)
Anybody actually tried it?
Dave
Old Mar 13, 2012, 11:12 AM
erkq is offline
Joined Dec 2010
Dave
1. You'd have to run each elevon on a separate channel and then the AS3X system would only work on one.
2. Does the DX6i have elevon mixing?
3. That brick may well not fit in the Stryker? It's pretty cramped.
Old Mar 13, 2012, 11:22 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Thanks, Erkq!
3. So I'd dig out a little foam... not a big deal?
2. I use my DX6i for my UM Stryker and its big brother, too. The elevons work just fine on the TX's wing/tail elevon mix.
1. This is the issue that's most mysterious to me. What does this mean, in practical "AS3X for Dummies" language? What flight controls would/could I have, either with regular functioning or with AS3X doing its thing as well?
Dave
Old Mar 13, 2012, 11:30 AM
erkq is offline
Joined Dec 2010
Thanks, Erkq!
Dave
On second thought, I don't think this would work at all. I put my AS3X board in an Sbach and it flies great! Try that, you won't be disappointed!
It won't work because the elevator gyro is connected to only one servo output at the receiver so there's nothing you can do with mixes for that. You need the elevator gyro to act on both elevons. Just think what would happen if only a single elevon were used to correct pitch!
The ailerons have a similar problem.
Old Mar 13, 2012, 11:45 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
On second thought, I don't think this would work at all. I put my AS3X board in an Sbach and it flies great! Try that, you won't be disappointed!.....
Drat.
I'll ponder your Sbach suggestion.
/Waiting for the newest cool stuff (Carbon Cub, UM Spitfire, MiG-15, etc.) to arrive, and looking to try something interesting in the meantime..........
Old Mar 13, 2012, 11:49 AM
erkq is offline
Joined Dec 2010
Drat.
IMHO, the FrankenBach is very interesting. I'd do that if I were you! I love it. Wait... did I already say that?
Old Mar 13, 2012, 11:56 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
You may have done this already but I'd be curious to see a step by step tutorial on how you did this (at least the major steps... don't need details on the pushrod construction or stuff like that unless there's more to it than I think there is!).
Actually... I bet they'll be coming out with one soon. You think?
turnerm is offline Find More Posts by turnerm
Old Mar 13, 2012, 11:58 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'm also curious as to why you like the AS3X modded Sbach moreso than you do the 3D Beast. I've always enjoyed my Sbach but I just wasn't in love with it. How does AS3X change it? Is it fair for me to assume that if I enjoyed the non-AS3X Beast a lot more than the non-AS3X Sbach that I'd feel mostly the same way about both models after the AS3X upgrade?
Old Mar 13, 2012, 12:03 PM
erkq is offline
Joined Dec 2010
I've been told they won't... that they're moving on to new products with their AS3X system and they only did the Beast because of its large following.
There really is no step-by-step. It's a very simple "out with the old, in with the new". Use the opportunity to get the CG right! Install that AS3X board back. Measure the CG with battery before you glue it in position.
And, don't forget to change out the aileron servos for the new HD servos for the Beast 3D.
But step-by-step? It starts with "cut the tape". Really... I would know how to write it.
Old Mar 13, 2012, 12:10 PM
erkq is offline
Joined Dec 2010
It's a different beast for sure. It cuts the wind better, less floaty, faster, more precise. It does pattern stuff really well, on rails, but not a great 3D performer. In all fairness, the SBach was never marketed as a 3D airplane. And, I'm not good enough to really evaluate it.
But the wind handling is way better. I was flying the Sbach in very strong winds and having fun. Then I put the Beast 3D up and initially thought there was something wrong with the radio! It was a dramatic difference.
I'd say your last statement is probably right.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19222 Feb 03, 2016 03:36 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 10:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 05:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 02:16 AM
