United States, CA, Sebastopol
Joined Dec 2010
Well, yeah... they are loud little suckers. But I sure can't hear them over that screaming 3000kv motor! I think that motor is louder than your Hacker. I have an A30-12XL turning a 15x6 and the little 3000kv hornet is definitely louder than that!
hi guys, i have a few questions, after reading several pages of the thread of the beast 3d is that the new stock motor is better with 5x3 two blades or the 3 blades?? (i understand the old motor 2300kv and the new 3000kv is better than the stock 2500)
and which of the hyperion batterys is better the 240mah or the 180mah??for an all around performance including 3d) and the most important question: what prop adaptor should i use for the gws props after searching and searching cant find the proper one. thxs in advance |
Since the Hyp 180 2s packs are lighter, they are better for 3D & they're better for indoor flying. But I think the Hyp 240 2s packs are the best for general outdoor flying, pattern aerobatics, and for flying in the wind. I suggest getting both. The GWS 5030 is a direct fit, so no adapter is required. The spinner also fits the 5030 without modification. Just use some foam-safe ca or other adhesive to reattach it. Be sure to dynamically balance the prop afterward. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Dynamically balance?? How is that done Joel? Should have my V1 and 5043 in a couple days... didn't realize I needed to do that. Also do you know if I will need an adapter with the V1 or is it direct fit also? Thanks |
Regarding dynamic balance - it's really easy. Just spool her up in your hand & check the vibration level. Temporarily put a small piece of clear packing tape on the backside of one blade & spool her up again. If the vibration gets worse, move the tape to the other blade. If it gets better, add more tape & try again. I usually get it right within a few iterations. This method balances the entire rotating assembly, rather than just the prop. Joel |
![]() I ordered a new spinner with the motor and props.. figured I would mount a permanent 5043 and keep the original stock also. If I remove the backplate will that effect anything? Not sure how to get a longer prop screw unless I can just match it at a hardware store... what have you done? Got it on the tape thing.. if the tape smooths it should I leave the tape on it?? |
Regarding the tape - yes, if it works, you leave it on the backside of the blade. Be sure that it is smooth & wrinkle-free. There are other methods. Some people put the prop on their prop balancer & either sand the backside of the heavier blade near the tip, or use some clear-coat on the tip of the lighter blade. A prop balancer allows one to accurately balance the prop, but other things also affect the balance of the rotating assembly - such as the spinner, propshaft/adapter, and sometimes the motor itself. Joel |
As is my normal way even though the B3D was grounded for engine issues I got off work Saturday (to no new motor yet)... and near perfect flying conditions (cloudy.. no bright sun, and wind about 3mph). So... I just had to fly
![]() 8 flights... not a single motor issue, and minor servo hunting on that aileron twice for less than a second. Weird. Again... LOVE this plane, and am really looking forward to the V1 and 5043. She just seems slow to me now. Guess I have a total of 60 flights on it now... and as I am a newbie (maybe 100 rc plane flights total) I have not tried 3D before, but was able to harrier the plane quite well Saturday. Looking closely I have a definite crease on the elevator at the control horn.. same spot and look I have seen through this thread that has torn on others. I cut a 3" 1mm carbon fiber rod which I am going to CA right behind the control horn.. actually touching and ca'd to the horn also. Gonna be using thin CA and doing a clean job. Plan on a 1/4" piece on packing tape to cover it. Question is should I put it on the bottom or top of the elevator or will it make any difference at all? |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16616 | Today 03:24 AM |
| Sold Eflite UMX Beast w/3batt and charger $120 shipped | RobDog | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Feb 06, 2011 09:40 PM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
