Old Mar 01, 2012, 02:38 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by hillm1234 View Post
Will these batteries work well in the Beast 3D if I use the two UM x Beast Y-connector from Glenn? I'm a bit worried about the length of the leads.
http://heli-heli.com/items/heli-part...1SM-detail.htm
Anytime you use a 1s adapter you'll lose efficiency and power. You'd be better off buying the right batteries hyperion 2s240 from rcbabbel.
* wife moved the camera, I'll post pics of the battery tray/wires tonight *
-Brian
kalmon is offline Find More Posts by kalmon
Old Mar 01, 2012, 02:46 PM
dragonshade is offline
Find More Posts by dragonshade
dragonshade's Avatar
United States, GA, Marietta
Joined Dec 2011
The connector is different on those.
Get these... http://www.allerc.com/hyperion-g3-cx...or-p-6479.html
Ordered without issue, love em, and they came in 2 business days, and are the right connector.
dragonshade is offline Find More Posts by dragonshade
Old Mar 01, 2012, 02:49 PM
Joined Dec 2011
-Brian
Brian... yes please do. Quite sure I know what you mean, but would like to see.
My tray is glued in rock solid.
As you guys know Horizon is sending me a new motor, but just ordered a V1 motor today, along with a couple 5043 props and a new spinner. That is the trick combo correct?
Had thought on the Styker motor, but do not want to lose flight time. Does anyone know the prop screw size... need to buy a small set of screwdirvers so I do not strip it out.
Joel... from reading back seems the V1/5043 combo may gain me 10mph top speed... is that correct?
Thanks to all of you as always
Ray
Old Mar 01, 2012, 06:30 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
Ray
Ray,
That would be an ideal number. The actual number is likely lower. Remember, the speeds I posted are simply pitch-speeds - static RPM x pitch. Prop slippage, efficiency, unloading, and airframe drag are not taken into account - so the actual numbers will be different. What I will say is that the increased thrust & speed are very noticeable in flight.
Until someone does some proper radar passes (no angle/geometry errors) with the plane in various configurations, actual flight-speed will remain an educated guess, at best.
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 01, 2012, 09:15 PM
Joined Dec 2011
Thanks.. noticeable will be nice
Man, I hate to be the new kid with nothing but questions and problems.. but I have a secondary issue, and you guys are the BEST knowledge base on the B3D.
When talking to Horizon I mentioned the weird chatter I was hearing once in awhile, and the motor issue.. guess why he said we'll try the motor first. I noticed them about the same time. Today left work as the sun was setting (cannot wait for longer days).. wind had died to nothing.. put up for a flight. Hooked up a 240, the initial beep... then as I was waiting for the gyro/synch tones heard the chatter. Sounds like a mini machine gun for a half to a full second. Flew beautifully. After landing heard the chatter.. put the plane on the car roof.. sitting still... chatter. After listening closely no doubt it is the right wing aileron servo. I can watch it move the slightest bit as it chatters.. the other is fine. Control horn is solid. I really so do NOT want to open this 1 month old plane, and looking.. the servo seems to be a royal pain to replace. I have access to di-electric grease.. is this a known issue, and is there a way to fix it save for calling Horizon and having them send me a new servo?
Also I am seeing a crease at the elevator where the control horn attaches. I saw some failures earlier in the thread in this area. Is there a real way to strengthen it or is it this is a throwaway plane after 100 flights or so? Yes it has about 50-55 flights on it but most have been in less than 8mph wind.. 15 or so in the 10-12mph range, and once only in a 12 mph wind with 20 gusts. Really do love it, but now starting to get concerned.
Old Mar 01, 2012, 09:24 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Dropping the price on that as3x beast board. $50 shipped to continental U.S. if anyone is interested please shoot me a pm.
That being said.. I freaking love this plane!
3d astronaut is offline Find More Posts by 3d astronaut
Old Mar 01, 2012, 09:58 PM
Joined Jul 2009
Try some of this on the servo's resistive track: DeoxIT FaderLube F5. If it doesn't work, replace the servo.
Regarding the plane - it is most definitely not a throwaway after 100 flights or so! Quite a few of us have many hundreds of flights on our Beasts. I have over 100 hours on one of my V1s with no problems at all. To strengthen the area around the control horns, some people use a c/f strip, others use a strip of clear HD packing tape, and others spread a layer of foam-safe ca or a very thin layer of epoxy around the area.
Joel
Old Mar 01, 2012, 10:16 PM
Joined Dec 2011
Joel
Please bear with me.. lol.. what is the resistive track? Do I just kinda spray it into the servo? Seems one piece with the plastic housing.
Old Mar 02, 2012, 07:48 AM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
http://www.parkflyingfun.com/ParkZone_linear_servo.html
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Mar 02, 2012, 08:11 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Are you willing to ship to Canada? If you use Paypal, I will gladly pay the difference in shipping.
RealGambler is offline Find More Posts by RealGambler
Old Mar 02, 2012, 08:18 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by RCBABBEL View Post
Wow, thanks RC, that's great info!
(The kind of stuff I love to read, but likely will never actually try because I'd probably screw it up!)
pugsam is offline Find More Posts by pugsam
Old Mar 02, 2012, 09:04 AM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
Agreed. It is simply giving me the tools for my own destruction....
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Mar 02, 2012, 11:09 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Yup.
A little knowledge can be a dangerous thing....
Old Mar 02, 2012, 11:14 AM
Joined Dec 2011
LOL... kinda how I feel too. Reading through looks like I would try to cut the servo free from the the little foam spacer that gives it clearance at the wing. Then try to disassemble enough to access the resistive tracks, then try to put it all back together and glue it back.... scary lol.
I have a guy here at work who races RC cars.. telling me it is the servo hunting for neutral. Looking at the plane the control horn is solid, but there is some looseness in the servo rod... meaning I can gently wiggle the ailerons and have the slightest freeplay. He suggested tightening the u-bend until there is a slight pressure (will screw up trim a touch, but better than tearing things apart). Says sometimes that will stop the hunting. He had had a few car servos do this and says eventually if it continues they will overheat and lock up. Though I do know the B3D servos are intended for constant adjustments (but maybe not machine-gun scatto)... so perhaps it would be ok. Also gonna make a call to Horizon to see what they say. Another idea my buddy had was since I first noticed this when I noticed the motor getting flakey.. I should first replace the motor. If it is arcing could be sending too much current to the servos, and if this one is a touch weaker than the left could be causing this, or the faulty motor could be drawing too much current and causing low voltage to the servo. So... hate to say it but guess I am grounding my B3D until I get my new motor/motors. Man I hope it is that.
RC... I appreciate the link... but not really wanting to even attempt it.
Old Mar 02, 2012, 02:28 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Ray
Here are the pictures of where the wires go through. Note the new custom 5030x2.25 bladed prop. That was a casualty of the lockup crash I had at the huge indoor event. I noticed in the pictures that the battery tray is now broke free of the motor mount, I can assure you it was glued securely before the crash when I changed the motor.
Regarding the 2300+5043 v. the 3000+5030 combos: They are very close in power with a slight edge to the 3000kv, both are WAY more than stock and noticeable in the air you wont go wrong with either setup.
I used a #0 Phillips for it but I'd bet a #1 would work to,might be a little to big. It doesn't have to be torqued on to 700 ft/lbs just snug it then give it another 1/4 turn. That's what I've been doing and haven't had any prop slippage yet.
-Brian
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Sold Eflite UMX Beast w/3batt and charger $120 shipped RobDog Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 06, 2011 09:40 PM
Wanted eflite UMX Beast fnlrun Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Dec 12, 2010 04:23 AM
Sold eflite UMX BEAST TERMAGATOR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Dec 04, 2010 01:16 AM
