DS,
My experience follows Turnerm's. I agree - it is very unlikely that you're hitting LVC. Regarding any problems with the Hyp 240s - sometime last year, i did end up with three defective Hyp 240 cells while building UMX packs. One of the packs simply faded away before it even hit 50 cycles - similar to the Eflite packs & most of the cheapies. On the other pack, one cell ballooned after less than 50 cycles. Hyperion claims a 1:1000 failure rate due to cell defects. So, it is certainly possible to get a defective Hyp cell, although it is a relatively rare occurrence. BTW - running the Beast 3D on the stock prop & motor, I was getting 6 minutes to the 80% discharge point with a Hyp 180 pack - while flying similarly to what you see in the video below:
Running the 5043 prop & stock motor, I was getting ~6:20 to the 80% discharge point with my Hyp 240 packs. With my Hyp 180 packs, I only got 4:45 to the 80% discharge point. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Actually, what Mutha said has happened to me several times. While I'm using a crappy eflite 120mah battery, it does this. I once plugged it in, taxied out, and pegged the throttle to do a hover right off the bat. It climbed up, and then within 2 seconds lost power, started pulsing. It nosed over and bent my wing up. I recharged the battery, and started out gently. Did a circle or 2 in the air at 1/3 throttle, then came back down for a hover. held it rock solid for 10+ seconds and then I did a full-power vertical climb. No issues whatsoever.
While this might not be it, it's worth a try. Again, my battery is a piece of crap, but the behavior is very similar to what you're saying.... |
Well everyone... looks like we have a motor failure. Took the Beast to my LHS (where I bought her).. hooked it up for the RC plane guy to hear. We put the throttle to 1/3 and there it was sounding crappy and warbling.. then went to normal.. then back. Throttled up and it kept doing it. We hooked up 3 different fully charged batteries and same thing. Almost like I was hitting a button... normal... crappy half power and warble sound... back to normal. He tried adjusting my throttle setting down and then did some test he claimed would show a glitch if it was the ESC... no change. Then went on to say his buddy had some plane he took out the box and did this... it was a motor stater problem and I should call Horizon.
IMO as much as I love this plane a motor issue in less than 1 month and 40 (maybe) flights.. not cool. Guess I'll be calling Horizon tomorrow, I have read they take care of people. I do not want to be without the plane, really do not want to cut decals and crack the fuse on a defective 3 week old plane, and will be mentioning a few things I had knowingly overlooked until this current issue... the tail does not seem to be centered fully from the factory. Noticed it does take about 4-5 clicks to the right rudder to trim after surfaces are manually centered (noticed this about 5 flights in). The right lower aileron is a bit too low.. top aileron is dead on, left side is perfect, but lower right is a few mm down. I would be very happy if they will exchange the plane given everything, and will fill you guys in on the convo. Wish me luck... we shall see. |
Beast Down!
I got a chance today to fly at an indoor field that puts even Joel's to shame! It was in a indoor soccer field, but not the small indoor sized fields, a regulation soccer field! 360ftx260ft with 75ft ceilings. There was about 50-60 people flying there. And I was flying just fine then in the middle of a nice scale loop, on the downline of all places, I lost all control inputs. I watched helpless as my beast pounded itself straight down into the AstroTurf. Completely fractured one wing and the vertical support. Servo was hanging by the horn and wire, 2 of the other wings cracked 1/2 - 2/3 of the way through. It was painful. I didn't have my camera with me or I'd post pics. It was repairable and I fixed it already. Lots of CA, CF, and a sharpie to hide the scars. Quote:
-Brian |
P.s... that sucks. What was the loss of input from? |
Joined Jul 2011
btw anyone know if you can fly the beast without a battery hatch???? mine dosnt come in for a few days should i just wait or can i still fly it? |
Oh, and dragonshade, if you can't get a motor out of them, I have a practically brand-new Beast3D motor that I want to get rid of. I'll let it go cheap. Anyway, good luck with Horizon! |
Dragonshade if you don't get a new motor from horizon another option would be to get the 3000kv stryker motor. The beast flies SOOO much better with that motor. It's a worthwile upgrade even if your old motor was perfect. If you don't want to upgrade I'd take up BobaFett on the cheap 2500kv motor. basically the motor prop combos in order of performance are: 1. 3000kv with a gws5030 prop 2. (very close second) 2300kv motor and a 5043 prop. (some prefer this as its much quieter) 3.(distant third) stock motor 2500kv with a gws5030. you already have good hyperion packs. so nothing else is needed for batts. -Brian |
Joined Jul 2011
thanks, plane is repaired and will be back in the box till the new hatch arrives, gives me time to recieve the new batteries also, im flying it with only 1 120mah v1 beast battery and this recommends 180mah so ive got 6 coming and a proper charger, should make for a much better flight time
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16603 | Yesterday 03:53 PM |
| Sold Eflite UMX Beast w/3batt and charger $120 shipped | RobDog | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Feb 06, 2011 09:40 PM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
