Old Feb 10, 2013, 09:45 PM
Bloosee is offline
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
Originally Posted by rtbates View Post
I use these 350mah 2s http://www.hobbyking.com/hobbyking/s...idProduct=9028 in both my GB and Beast. The Beast NOW has a 5030 prop the GB 's is the stock one. The GB can also benefit from a 5030 prop?
That is a very big pack for the Beast, I prefer my Beast to be as light as is reasonable, I occasionally fly it on 120mah packs, with those light batteries the first minute of flight is great, but it's downhill quick and done in 3 minutes.
Bloosee is offline Find More Posts by Bloosee
Old Feb 10, 2013, 09:50 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
I have some G-force 180's...
microflitedude is offline Find More Posts by microflitedude
Old Feb 11, 2013, 12:56 AM
twincobra is offline
Find More Posts by twincobra
twincobra's Avatar
Australia, VIC, Melbourne
Joined Jan 2012
5030 is better because it stops the OCP issue (if your geebee suffers from this!). It also seems to have a little more thrust.
Mine was terrible with the cutout - til I swapped out the prop.
twincobra is offline Find More Posts by twincobra
Old Feb 11, 2013, 09:51 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Tell us for those like me that don't know what OCP is ??
thanks
I do have some 5030 props that I will use on mine when it comes in
brushless55 is offline Find More Posts by brushless55
Old Feb 11, 2013, 10:04 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
thanks
over current protection - prevents fried bricks
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 11, 2013, 10:48 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
I fly the Beast from 10-12 minutes using mostly 3/4 throttle with full on occasion.
rtbates is offline Find More Posts by rtbates
Old Feb 11, 2013, 10:49 AM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Still listed on the Horizon site almost ne year later...
"Gee Bee EFLU4580
Over Current Protection
During production of the E-flite UMX Gee Bee, small tolerances of components have led to some Gee Bee models hitting the Over Current Protection (OCP) during the first initial run of a fully charged battery. When this happens, the motor will shut off as programmed to protect the electronics from an over-current condition. The servos will not stop working and you will still have control of the plane. This only happens when the battery is at a fully charged state and will not happen in the course of an entire flight.To reset the motor, the throttle needs to be cycled back to low power. After the motor has been run for a few seconds and the voltage of the battery has come down, the system will not hit OCP.
This does not occur on all models and should be checked on the ground before each flight. Larger and or higher C rating batteries are not recommended for the Gee Bee, as this could cause the power system to run above the designed limit and hit OCP. Follow the instructions below to prevent hitting OCP during a flight.
Throttle the model up to full power on the ground and let it run for 10-15 seconds. If the model hits OCP and the motor shuts down, cycle the throttle and run the motor again near full power for at least 10 more seconds. This will bring the battery voltage down low enough to prevent hitting OCP during the flight.
Horizon is working to find a long-term solution as soon as possible."
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Feb 11, 2013, 10:54 AM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
"Gee Bee EFLU4580
rc
Perhaps this is the reason for the crash sales - v2 coming with better brick?
Old Feb 11, 2013, 10:55 AM
rtbates is offline
Joined Mar 2010
Prop adapter
when taking off the stock prop the nose of the prop adapter was so glued to the prop that it sheared off and came off with the prop. Anyone know where I can find the Gee Bee prop adapter?? I've got a service enquiry into Horizon but no response so far..
THANKS
randy
I've located one for the Beast and looking at my Beast it could very well be the same adapter. EFLU4067. I'm off to get it at Hobbytown. Wish me luck
tks
Yes indeed, it's the exact same adapter. Works perfectly.
Old Feb 11, 2013, 02:37 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
You guys who are using the low-power, low cycle-life Zippys & Nanos aught to try a TP 325 65c pack. The difference in flight-performance is like night & day. Plus, you get 10x the cycle-life @ 12c charge, which more than compensates for the difference in price.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 11, 2013, 03:14 PM
Bloosee is offline
Bloosee's Avatar
Joined Jan 2012
Originally Posted by turboparker View Post
You guys who are using the low-power, low cycle-life Zippys & Nanos aught to try a TP 325 65c pack. The difference in flight-performance is like night & day. Plus, you get 10x the cycle-life @ 12c charge, which more than compensates for the difference is price.
Joel
I'm sure its a great battery, (TP always are) but its awfully expensive (as TP always are), I like to bring 6-8 packs with me to the field, that's why I run the cheaper stuff. Maybe I'll get a couple.
Old Feb 11, 2013, 03:36 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Joel
You charge at almost 4 amps??? How long does it take to fill the tank on those bad boys?
Old Feb 11, 2013, 06:24 PM
Joined Jul 2009
But you get a lot more power, and you get 600 cycles with the new TP G6 packs if you take care of them properly. With a 600 cycle lifespan & the ability to charge at 12c (7-8 minute charge from the 80% discharge point), you can fly non-stop all day with just three packs per plane & a dual-channel charger. So, they're cheaper in the long run, and you get a large bump in power thrown in on the deal.
Definitely pick up a couple & try them. You will see what many of us have been taking about. Also, look at my test data on my blog thread. You can clearly see the significant power bump with the TP 325 65c pack. They even outperform the new Hyperion 500 VX 35c packs. (The new Hyp 400 & 500 VX 35c packs are by far the highest performance 'max endurance' packs that will fit the plane.) The Hyp 500s do produce more thrust than the TPs, but not enough to compensate for their extra weight, so the TP 325 65c still provides a better thrust-to-weight.
Oh, yeah! Only takes 7-8 minutes from the 80% discharge point. You need to use a very accurate charger when charging at these rates. You should see how I charge my TP 2250 65c 3s packs. I crank both channels on my TP 820CD up to 20A, plug in a pair of TP 2250s, and let 'er rip at 8.9c charge. Almost 300 cycles on them & they still pull nearly the same static RPM as they did just after break-in.
Joel
Old Feb 11, 2013, 06:54 PM
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
enter GeeBee and it gets way cheaper
Like 70ish bucks cheap....great deal it is..
http://api.viglink.com/api/click?for...13606302825662
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Feb 11, 2013, 07:25 PM
big ignore list
Joined Nov 2011
Help! Adrienne Paige Gee Bee R2 Plans Eric Giorgiantonio Fuel Plane Talk 5 Jan 29, 2012 11:02 PM
For Sale Herr Gee Bee R2 (NIB) 25" wingspan pdawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Oct 12, 2011 10:20 AM
Wanted Adrian Page Gee Bee Z 1/5th and/or Gee Bee R2 1/5th (looking for) Xanix Aircraft - Fuel - Airplanes (FS/W) 0 Jul 23, 2007 06:16 PM
