Old Nov 06, 2012, 06:28 AM
cleaverpj is offline
Find More Posts by cleaverpj
Joined Dec 2009
Paradude, you are the dude, thanks man, can't wait to try it with some instructions!!
I am actually using this as a vehicle for a UAV using an Android phone onboard for all comms and video. In theory, it's the simplest UAV ever.
cleaverpj is offline Find More Posts by cleaverpj
Old Jun 24, 2015, 04:46 PM
parajared is offline
Find More Posts by parajared
no guts no glory
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
I couldn't help myself and ended up buying one.
I fly full scale paraglider and the kite had some appeal to me. I know this thread is a million years old but has anyone installed a speed-bar setup on theirs? In full scale paragliding you have this bar that you push on with your legs that pulls on the A-lines down for a more aggressive angle of attack.
Has anyone used it as a skydiving chute?
parajared is offline Find More Posts by parajared
Old Jul 04, 2015, 11:57 PM
sonnier00 is offline
Find More Posts by sonnier00
sonnier00's Avatar
United States, TX, Huntsville
Joined Oct 2011
How to dribble go I'll just got one myself but I haven't flown it
sonnier00 is offline Find More Posts by sonnier00
Old Jul 04, 2015, 11:58 PM
sonnier00's Avatar
Joined Oct 2011
How to build go I'll just got one myself but I haven't flown it
Old Jul 05, 2015, 08:01 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
I just got it yesterday; I think I am going to throw my paratrooper off a cliff first and if he survives the fall I will drop him out of an airplane using the J-bag technique like with full scale paraglider pilots.
I built the arms out of popcicle sticks and I made some duct tape hang points. I have a low a medium and a high hang point because I'm not sure which will fly best. I plan to separate the hang points by 190mm which is why I built an EPP tray of sorts.
The chest (or servo tray) is made out of some epp from a badly crashed Tek Sumo I decommissioned a while back. I have started light (only about 100 grams) because it is easier to add weight later than it is to try and lose weight
Old Jul 07, 2015, 09:45 AM
no guts no glory
parajared's Avatar
Joined Oct 2013
I maidened my little paradude (read threw him off a cliff) yesterday and he flew.... right into a rock. This snapped both popcicle sticks so I was unable to continue testing with any rc control. I still did some testing with different weights however and here is what I came up with.
My initial tests yielded the following observations (weight of pilot only)
103 grams: waaay too light (collapses, nasty characteristics)
212 grams: flew light, may be ok for light wind stuff
323 grams: seemed to fly fine
488.2 grams: sunk out a little faster but also seemed to fly fine. Initial impression is that this is about the "normal weight", but further testing, preferably with actual rc control, is warranted to make sure.
My little 9 grams servos were really struggling with the torque so I replaced them with a couple of 50 gram servos. I also swapped off of my LiFe battery and switched to a larger, heavier nimh receiver pack. I put a layer of duct tape over everything to slick it down because the lines were catching on the balance lead, the servo wires and the zip ties although I am still worried a skydiver setup will potentially end up with lines snagged on the arms.
Old Jul 17, 2015, 03:30 PM
fly103-rcu is offline
Find More Posts by fly103-rcu
fly103-rcu's Avatar
USA, NC, Cullowhee
Joined Jan 2004
R/C Skydiving
Check us out at www.solomonrc.com
fly103-rcu is offline Find More Posts by fly103-rcu
Old Sep 25, 2015, 04:26 PM
Cluster is offline
Find More Posts by Cluster
Cluster's Avatar
Czech Republic
Joined Feb 2005
Hello gentlemen,
can somebody show a picture of arrangement of paraglider chords due to HK foto with signs A, B, C, D as it is attached to the parafoil and arranged together on the ends with connecting rings. I donīt know which is which.
My next questions are obout gondola construction.
1. 1150 g flyght weight with 850 g thrust OK?
2. Can be gondola made of semi hardened Aluminium plates with thickness of 2 mm (I am not able to cut Dural by the laser and bend it on the CNC machine.
3. Is a good idea to cover gondola by 4 mm Mirelon?
4. What are good or recomended glight conditions?
Vaclav
Cluster is offline Find More Posts by Cluster
Old Jan 11, 2016, 07:14 AM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
This thread has help give me a few ideas for a powered parasail project I've been collecting parts for. So far I have:
5.6 sq m Peter Lynch 4 line Power Kite
2 - Hitec monster HS-805BB servos, 343 oz-in
Dualsky XM6360DA-10, 218KV, 10s, 20x13 - 22x12 prop
I have test flown the kite with the OEM long lines and got it to fly pretty darn high, not straight overhead but pretty close. It's quite impressive in the air. It has tons of pull, had to let go of it a couple of times to keep from being dragged off my feet. So my gondola weight shouldn't be a concern building too heavy.
jwellsy is offline Find More Posts by jwellsy
Old Jan 11, 2016, 01:23 PM
jwellsy is offline
Joined Aug 2012
I'm debating on getting a set of these 1:5 ratio torque mulipliers to bump those brake line servos up to over 1700 oz-in power.
https://www.servocity.com/html/spg80...ous_rotat.html
That's probably over kill, but this powered parasailing is a stepping stone to rerigging it into an experiment for a giant scale controllable rescue/recovery emergency chute for a 15 - 20# plane. The forces on those lines on deployment will be harsh which could easily destroy servos. So I want to have very strong servos and progressive sets of shock absorption in the lines.
Old Apr 17, 2016, 08:34 AM
MikeCr is offline
Find More Posts by MikeCr
United States, WI, Slinger
Joined Mar 2006
Originally Posted by inventing_man View Post
Dont count yourself out Bill , I'm 53 .
There are Real trikes out there . The One I'm saving up for is this .
http://www.falcon4strokeppg.com/
I would like a to do a scale RC flyer of it one day.
I agree. I got into it almost six years ago now, I'm 58 right now. I've met guys who were much older than me that got into it.
Originally Posted by Paradude View Post
That would be awesome to do it for real but as I live in Australia with anal retentive folk hell bent on regulating the colour of our farts my bet would be 100 times the cost of the paraglider in fee's and license. Not only that but by the time it all got past and approved my blood pressure at 85 would not allow me to travel higher than 2 feet....so rc ones will have to do LOL.
I've met a few guys from Autralia and NZ at some of the Fly Ins I've been to, not sure what hoops they have to jump through. I'm fortunate living in the US that we have Ultralight Part 103. No hoops at all if you follow the basic rules of Part 103 and your equipment meets the rules.
MikeCr is offline Find More Posts by MikeCr
Discussion Powered Paraglider forum, please gatorlynch New Forum Requests 4 Jan 12, 2012 01:32 PM
Discussion RC Powered Paraglider in process... jrbackus Fuel Plane Talk 56 Nov 13, 2011 09:14 AM
Sold Powered Parachute/Paraglider RXR Blue Collar Aircraft - Electric - Airplanes (FS/W) 0 Jun 13, 2011 10:49 AM
Video RC Powered Paraglider... jrbackus Electric Plane Talk 8 Aug 23, 2009 09:09 AM
powered paraglider 24" x 62" chute GlobeWideWeb Power Systems 1 Dec 12, 2003 07:49 AM
