Old Jan 20, 2012, 03:01 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Thanks for the offer mate .I appreciate ,But the dragon is in Tasy, and I have to get the house in order before she returns on Monday. BUT BUT I will contact you soon
Happy Landings
Chris...........
britinoz is offline Find More Posts by britinoz
Old Feb 26, 2012, 07:02 AM
Luppie is offline
Find More Posts by Luppie
Joined Aug 2009
hey guy's i tried my HK parafoil yesterday.
I have build a trike with a .35 os-max weighing just over 1kg.
I din't work out as i hoped but i have a vid and maybe you can have a look and brainstorm about what went wrong. I think the trike has not enough weight so i will put some heavyduty wheels on it . I have 7cm shorter line on riser A
MVC Cumulus...25-02-2012 (7 min 41 sec)
Luppie is offline Find More Posts by Luppie
Old Feb 26, 2012, 07:25 AM
popad is offline
Find More Posts by popad
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Hk Paraglider 2.15 that fly !
Take a look HERE
Description: Name: restringHKParaglider215m10.jpg
Description: Name: TestHKParaglider2156.jpg
Description:
just restring, and change control (steering by weight shift)
Happy landings,
PopaD
popad is offline Find More Posts by popad
Old Feb 26, 2012, 09:45 AM
inventing_man is offline
Find More Posts by inventing_man
Whats a search engine?
inventing_man's Avatar
Missouri
Joined Jun 2006
Did you Kite the paraglider first to see if would even fly right? Like in this vid http://www.ehow.com/video_4468486_pa...ting-tips.html
If you cant get the wing to do this first .... very stable over head , with little input from you. it will never fly RC'ed
My HK wouldn't after the riser mod , which I had to go way beyond to get it to fly half way right just for use as a power kite, . which is not near good enough for RC . The wing was sewn bad, not symmetrical in my case.
inventing_man is offline Find More Posts by inventing_man
Old Feb 28, 2012, 01:46 AM
Ricardo1500 is online now
Find More Posts by Ricardo1500
Ricardo1500's Avatar
Wolverhampton, England
Joined Jun 2010
Having got mine to fly successfully i would say that you are quite close!!
Firstly try some more weight on the front of your gondola and secondly pick a calm day!! I don't fly mine if its windy they are a reall handfull then.
Keep trying and keep us posted
regards
Rich
Ricardo1500 is online now Find More Posts by Ricardo1500
Old Feb 28, 2012, 03:01 AM
tedrobphoto is offline
Find More Posts by tedrobphoto
Joined Jun 2006
Luppie and Rich.
Rich, I would agree with you from my own experience. Also, I.C. engines are a bit tricky to finely control the speed which should have been cut soon after take off as the machine was tending to power-stall and together with the wind the flight unfortunately was a "No-No!"
Calm day for first flights ESSENTIAL
Ted
tedrobphoto is offline Find More Posts by tedrobphoto
Old Aug 30, 2012, 11:31 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
Hi guys, I;m thinking of using this foil for as a steerable parachute for a RC-paratrooper...
the weight will be around 400-600g and it will have no form of propulsion...
any takes?
T-BONEZ is offline Find More Posts by T-BONEZ
Old Aug 30, 2012, 01:20 PM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Flying test HK Paraglider Parafoil 2.15m (0 min 47 sec)
780 grams
Happy landings,
PopaD
Old Aug 31, 2012, 02:52 PM
T-BONEZ is offline
Joined Jun 2007
Originally Posted by popad View Post
that's BEAUTIFUL!!!
may i ask, does it need to be set at an angle of attack for this case?
Old Aug 31, 2012, 04:09 PM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Thanks! Yes, AOA is modified (see pictures from HK site).
or I can show some pictures, soon.
Old Sep 01, 2012, 10:46 AM
T-BONEZ is offline
Joined Jun 2007
yeah, that would be great! thanks in advance man!
Old Sep 01, 2012, 12:27 PM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
AOA setup in my case
Here is some pictures with my setup AOA:
Description: Name: DSC01037.JPG
Description: Name: DSC01038.JPG
Description: Name: DSC01039.JPG
Description:
Description:
Description: Name: HPIM2342_AOA.jpg
Description:
Description:
Happy landings,
PopaD
Old Nov 03, 2012, 09:30 PM
cleaverpj is offline
Find More Posts by cleaverpj
Joined Dec 2009
Frustrated
Hi,
Can anyone please direct me to a page that shows the definitive setup of this paramotor. It is so ridiculous that HK do not give any instructions whatsoever. Do they think we enjoy wasting time and breaking things??
I would love to know:
ideal weight
AOA - distance from A lines to B lines
How to set the break lines
What overall balance should be (nose up, nose down, or level)
How much the brake lines should move.
Prop size and pitch (I am using the recommended XR Type D Beechwood 3-blade Sport Propeller 12x5)
Motor Specs ((I am using the recommended NTM Series 3536-1400kv Brushless Outrunner)
Thanks a million in advance.
cleaverpj is offline Find More Posts by cleaverpj
Old Nov 04, 2012, 03:36 AM
Paradude is offline
Find More Posts by Paradude
Joined Dec 2010
1. 1.4-1.8kg
2. 70-75mm
3. slight nose down to level (depends on power system)
4.hold up side down and adjust so just loose, once glide rate is sorted make adjustments
5.depends on how long servo arms are, longer is better
6.Prop is about right, two blade works better
7. chuck that motor, HK are boof heads for recommending that high kv. 1000kv-1200kv for 3s.
The foil is too stiff on rear edge and needs softening by scrunching as has been soaked in rice milk and left to go off lol. If you use too higher kv it cause prop torque, the trike tries to twist.....widening the tie bar to 180mm helps.....usually with high kv and/or incorrect cog it will bank up and left then nose dive. As mentioned above use the kite method to test foil, it wont stay in the air like a kite as the foil is not the right design but if you grab it by the ties and walk backwards give it a tug and it should pop up in the air. If set around 70mm it should pretty much stay above your head while walking backwards.
I am by no means a guru or eddy expert but myself and a good flying buddy have spent countless hours testing different configurations, it is so so at best and takes a bit of tuning but it does flyafter plenty of look up farrkenbeauty on youtube to see different weight/power setups
Paradude is offline Find More Posts by Paradude
Old Nov 06, 2012, 06:23 AM
Joined Dec 2009
Paradude, you are the dude, thanks man, can't wait to try it with some instructions!!
Discussion Powered Paraglider forum, please gatorlynch New Forum Requests 4 Jan 12, 2012 01:32 PM
Discussion RC Powered Paraglider in process... jrbackus Fuel Plane Talk 56 Nov 13, 2011 09:14 AM
Sold Powered Parachute/Paraglider RXR Blue Collar Aircraft - Electric - Airplanes (FS/W) 0 Jun 13, 2011 10:49 AM
Video RC Powered Paraglider... jrbackus Electric Plane Talk 8 Aug 23, 2009 09:09 AM
powered paraglider 24" x 62" chute GlobeWideWeb Power Systems 1 Dec 12, 2003 07:49 AM
