Old Dec 02, 2011, 06:05 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Rich,
Marks and Sparks!! great time of year this...just means money these days!
I don't think I have the skill to restring (or patience), I think I will get a kite like Bill and try again. But it will be next year now as I am up to my neck in Panther builds!
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Dec 02, 2011, 07:32 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Rich Glad to see that you are coming to grips with the monster.I have not been quite so lucky yet.I have had a couple of "tumbles' and was supprised to find how soft the ''aluminuminumillium''frame is. It bolted together perfectly but bent several parts with only light contact. But we dont give up that easy,do we?
Chris...........
britinoz is offline Find More Posts by britinoz
Old Dec 03, 2011, 05:38 AM
Ricardo1500 is offline
Find More Posts by Ricardo1500
Ricardo1500's Avatar
Wolverhampton, England
Joined Jun 2010
Hi Chris
Yes the trikes do fold into some really interesting shapes when "landing" but I think thats probably not a bad thing as it may absorb some of the loads and prevent damage to the expensive bits!!. Bends back easily enough though.
Found this video on the HobbyKing forum showing a mod for a springer front end and other useful ideas. If you watch his other videos, his really flies well.
http://www.youtube.com/watch?v=Urqek...eature=related
Cheers
Rich
Ricardo1500 is offline Find More Posts by Ricardo1500
Old Dec 03, 2011, 12:02 PM
popad is offline
Find More Posts by popad
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
The best link about this paraglider (Thanks, Padalec).
Hi,
after long research on internet, I found this link , where Padalec Nace from Slovenia (author of this kind of rc paraglider) give right length of lines, and what knots to use for rigging this paraglider.
I have 4 paraglider from HK. One I re-string like RTF parachute with succes, using Surfplan. Now, after that I found this link (is in bottom of the page, post of Padalec), I want to re-string one, using Padalec's length of lines.
Many thanks to Padalec for his post !
Happy landings,
Popa D.
popad is offline Find More Posts by popad
Old Dec 03, 2011, 07:40 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G'Day Rich
Thanks ,I have seen that video,and I did modify my gondola in a similar way ,but I have not even had the model in the air yet, and it has still been damaged just by tumbling over on the ground.If all go's well I am pretty shore that I can make a suitable one of my own.
happy Landings
Chris...........
Old Dec 04, 2011, 01:26 PM
EINA is offline
Find More Posts by EINA
South - Africa
Joined Nov 2007
Wish I saw this tread yesterday. Tried my HK foil and condola today and it flipped backwards. After I've replaced the broken motor shaft Ill check the cg and AoA like suggested here and I'll try again next weekend. Thanks for you're input.
EINA is offline Find More Posts by EINA
Old Dec 07, 2011, 12:57 AM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Several days ago I went along to see the' Paradude',fortunately for me he is only a couple of "Km s' down the road,and he helped clear up a couple of my concerns and he showed me how the foil should open. Today was the first chance since then that I was able to try my Bela trike.First attempt it was up and away,unfortunately in left banks only with right stick not having any effect on the flight. So I put the model down pretty gently,but unfortunately causing a major ball of string.(wheels ,prop,frame all tangled.)
I'm a big boy .I didn't cry or say bad words. I am pretty sure that it will be OK in a day or so!!
Happy Landings
Chris...........
Old Dec 08, 2011, 02:08 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
Experimenting with my HK parafoil at the moment, had a few relatively successful flights (and some very successful crashes), turning seems to be the problem being marginal at best.
@EINA, where do you fly from? I might be going out to White Hills on Sunday otherwise flying in Northcliff, JHB.
pardus is offline Find More Posts by pardus
Old Dec 08, 2011, 04:43 AM
EINA is offline
South - Africa
Joined Nov 2007
Pardus, I'm flying at RAM just outside Pta north, we'll be camping at the field for the weekend, unforunately I will not have the canopy set up to take along.. Would larger inputs help with the stering?
Old Dec 08, 2011, 07:07 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Have just lengthened the arms, hopefully I'll have some more directional control. The parafoil seems to fly OK but it would be nice to see someone else's setup.
I've also been trying to get all the strings to pull equally on the foil, the far outer trailing edge strings seem too tight pulling the trailing edge tips inward almost like "wash-in" so I have lengthened them slightly too, will test again...
Old Dec 16, 2011, 08:45 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Been having a couple of nice flights with the parafoil, setting up and tuning is still a work in progress though...
Here's a vid:
HobbyKing Parafoil with ply Gondola, R/C - launch, flyby & land (0 min 53 sec)
Old Jan 17, 2012, 03:59 PM
gatorlynch is offline
Find More Posts by gatorlynch
gatorlynch's Avatar
United States, FL, Sarasota
Joined Mar 2010
Here's my last attempt with my PPG, taken a couple of weeks ago by my brother.
I have shelved this project for now. After many launches and even a few (short) flights, I believe my foil will fly - with the right buggy & power set-up.
The buggy needs to be within the acceptable weight range (mine was initially too heavy) and the lines should attach above or towards the top of the prop ring - this saves on lines being eaten by the prop. It also needs to be set up for a 12" prop. My power plant was a 3536 1450kv. I believe this is not a suitable motor. It's powerful enough, but should be lower kv, so it can be used with a 12" prop.
I'll give this another chance someday, when I have a better suited motor & a new buggy.
FL Flying Day Two - HobyKing 2.5 M Paraglider Multiple Crashes (4 min 20 sec)
gatorlynch is offline Find More Posts by gatorlynch
Old Jan 17, 2012, 04:22 PM
EINA is offline
South - Africa
Joined Nov 2007
Pardus, seemed to me that you had some great socsess with your foil, nice vid.
I did not go back to see what you did but could you please share some tips so I can give it a try again when the dc-3 is done?
Old Jan 17, 2012, 08:14 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G'Day Gator
If I did not know better,then I would have said that you had been filming my futile attempts to fly these accursed machines. May be that I also should shelf this project. I think that I should just stick with autogyros,
Happy Landings
Chris............
Old Jan 18, 2012, 03:03 AM
Paradude is offline
Find More Posts by Paradude
Joined Dec 2010
G'day Chris, shame you have not had yours in the air yet mate. Looks like we will be flying this Sunday so more than welcome to come in and we'll help you get it flying
Paradude is offline Find More Posts by Paradude
Discussion Powered Paraglider forum, please gatorlynch New Forum Requests 4 Jan 12, 2012 02:32 PM
Discussion RC Powered Paraglider in process... jrbackus Fuel Plane Talk 56 Nov 13, 2011 10:14 AM
Sold Powered Parachute/Paraglider RXR Blue Collar Aircraft - Electric - Airplanes (FS/W) 0 Jun 13, 2011 11:49 AM
Video RC Powered Paraglider... jrbackus Electric Plane Talk 8 Aug 23, 2009 10:09 AM
powered paraglider 24" x 62" chute GlobeWideWeb Power Systems 1 Dec 12, 2003 08:49 AM
