Old Oct 19, 2011, 07:55 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Disney Bird Foamie Aladdin's Iago
Here is a video of Iago in flight; Caution: You will need transmitter mixing of ailerons to rudder in addition to V-tail mixing if you plan to build this model.
Disney's Iago from Aladdin (Radio Controlled) flown by Otto Dieffenbach (0 min 43 sec)
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Last edited by Otto Dieffenbach; Oct 20, 2011 at 10:34 AM. Reason: Added a caution.
Old Oct 19, 2011, 08:05 PM
Joined Aug 2011
Build description and plans/photos
The build is fairly easy. This is what you need to do.
1. Cut out the wing and tail from 6mm Depron. Separate control surfaces, bevel edges and attach with hinge tape.
2. Install carbon spar in wing.
3. Shape body from a hunk of foam.
4. Cut body at wing/waterline.
5. Make parallel belly cut (about an inch below, for eventual electronics installation) and cut at the front at 3 degrees (right thrust) for ply motor mount installation.
6. Hollow body and nose for electronics/motor.
7. Make ply motor mount.
8. Glue wing to body at wing/waterline cut.
9. Glue L & R tail together in V at specified angle.
10. Glue tail to body at wing/waterline cut and add carbon tube stiffener. Check alignment and check it again.
11. Epoxy motor mount to front.
12. Install motor and glue nose on. I use collet type prop adapters so I can remove prop easily for display.
13. Install electonics so that CG is at the carbon spar.
14. Install linkages.
15. Make hatch for battery where required.
16. Important: Put 75% throw mix of rudder slaved to the ailerons.
17. Paint and fly or fly then paint.
If this is within your capabilities or you want develop some skills let me know what you need. The foam carving is the hardest part; foam is cheap/free, so carve til you get it right. Best.
Old Oct 19, 2011, 08:07 PM
Joined Aug 2011
Electronics requirements
Most materials were ordered from Hobby King at hobbyking.com.
AX1806N, 2500kv motor (1) $8
Plush 10amp ESC (1) $8
Light receiver (5g) for your transmitter (1) $5
HXT900 servos (3) $2.77 a piece
3mm collet prop adapter $2
GWS 6x3 prop
I use GenAce 2s450 25c batteries from hobbypartz.com. Good alternate source for 9g servos and 10amp esc. Batteries have good quality at $4 per.
Old Oct 19, 2011, 09:41 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Wonderful!
vtdiy is offline Find More Posts by vtdiy
Old Oct 20, 2011, 01:46 AM
KenChin is offline
Find More Posts by KenChin
NewFlyer
KenChin's Avatar
Kuala Lumpur, Malaysia
Joined Aug 2006
OMG ! That's looks stunning in the air !
KenChin is offline Find More Posts by KenChin
Old Oct 21, 2011, 09:21 PM
Mifoamflyer is offline
Find More Posts by Mifoamflyer
Mifoamflyer's Avatar
Michigan
Joined Nov 2009
[QUOTE=KenChin;19642813]OMG ! That's looks stunning in the air ![/QUOT ,
Absolutely the coolest !
a must have
Mifoamflyer is offline Find More Posts by Mifoamflyer
Old Oct 24, 2011, 08:35 AM
wing_man is offline
Find More Posts by wing_man
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Pdf
I printed this at 235% in Adobe Reader and it gave me a 18.5" body...hope it helps someone.
Dennis
wing_man is offline Find More Posts by wing_man
Old Dec 29, 2011, 12:16 AM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
awesome work ,you are very talented my friend!! thank you for sharing, geoff
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Dec 29, 2011, 07:38 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Flies like .... a Bird !!!
gpw is offline Find More Posts by gpw
Old Mar 18, 2012, 08:00 PM
MrGloriousfall is offline
Find More Posts by MrGloriousfall
France, IdF, La Roche-Guyon
Joined Oct 2011
such a lovely bird, and that flies great,i may build one for my kid (or for me...) !
thanks for sharing!
MrGloriousfall is offline Find More Posts by MrGloriousfall
Old Mar 22, 2012, 12:10 AM
RCSquale is offline
Find More Posts by RCSquale
Sometimes it work some don't
RCSquale's Avatar
Émirats arabes unis, Ras el Khaïmah, Ras Al-Khaimah
Joined Oct 2010
To Otto Dieffenbach, is there any chances to have more details on your build my friend... like a building log, where the electronics are coming in your body, building techniques and so on? I will start this build very soon and I would really would like to have some more inside infos.
Thank you in advance.
Regards.
Pascal.
RCSquale is offline Find More Posts by RCSquale
Old Mar 22, 2012, 02:20 AM
Joined Aug 2011
In the Red Tail Hawk thread there are general building instructions for all my birds. The process is the same. Give me a list of specific details you'd like and I'll address them.
Old Mar 22, 2012, 09:13 AM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
This one is very colorful. I like it!
DaDesign is offline Find More Posts by DaDesign
Old Mar 23, 2012, 02:43 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Cheers Wing Man...
Old Mar 23, 2012, 07:20 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Now here is a little question for you Otto, How do you keep the body closed and the nose once the Electronics is installed? Are you using small magnets?
Ok for the CG by the CF rod in the wing or slightly further.
I'm planning to use a 1200kva motor E-MAXX 2812, 1000 mAh battery 3Cell, 9gr servos and a 20A ESC, will that be not to heavy for the size of it? Or do I need to blow it even bigger?
I printed out the file and blew it at about 300 or 400% can remember now but I'm attaching the file anyway. It seems to be slightly bigger then the given dimension... Might work for my bigger power set up.
Discussion It's a bird...it's a plane...it's time for a conversion? strictlyscale Glow to Electric Conversions 0 Sep 22, 2011 02:43 PM
Discussion Smart Bird, Plane that fly's Like a Bird,,, WOW!! daboz Dynamic Soaring 5 Aug 20, 2011 01:29 AM
Yippee! It's a bird, It's a Plane, No, it's a Jet Ski? WTH?! Tollytime Scale Boats 4 Jun 28, 2011 11:35 AM
Discussion It's a bird, it's a plane, it's.........a Bird! Utahrd Slope 3 Sep 10, 2006 07:47 AM
Charity Big Bird Flyin has ONE Foamie Electric - JKA Big-T Bird (96" version) bjsiegel@texas.net Foamies (Kits) 5 Nov 03, 2001 11:44 PM
