Brand new in the box. still taped on all 4 sides. $195 shipped to lower 48! paypal verified only.
Castle Creations 1/10 Mamba Max Pro SC System 2400kV
Description
This is the Castle Creations Mamba Max Pro Speed Control with 2400 kV Sensorless, Brushless Motor.
FEATURES: Rated for 4S maximum input
Suitable for use with stock gearing on AWD (all wheel drive) vehicles
in basher applications not recommended for 2WD vehicles
ESC
Switching BEC provides power for servo and receiver all the way to
6S
Profiles can be custom designed on a PC with the Castle Link
PC programming software
Infinitely adjustable throttle and brake curves with timing advance
Punch Control allows dialing in horsepower where needed
Brake Strength allows straight tracking under hard braking
Drag Brake helps entry into corners
Start Power for smooth launches
Motor;
INCLUDES: Castle Creations Mamba Max Pro Electronic Speed Control, 2400kV motor
SPECS: Electronic Speed Control-
Cells: 6-12 NiCd/NiMH, 2-6 cell LiPo
Brake: Proportional
Reversible: Yes, with lockout
Low Voltage Cut-off: Programmable
Size: 45.5mm x 36.5 x 21.5mm (1.79"x1.44"x0.85")
Weight: 81g (2.8oz)
2400 kV Motor;
