Old Oct 19, 2011, 01:07 PM
bombardierJay is offline
Find More Posts by bombardierJay
Joined Oct 2011
Signs of a bad ESC ?
Last night i hooked up my HK-20 amp ESC to my 28-10 motor . and evertything worked fine for about 2 min's . then the motor was not spining no more but going back and forth real fast and making a bad noise . kinda seems like it was trying to turn both ways left and right and glittering ?
i tried another motor and same thing . is this what a bad esc will do if its faultly ?
bombardierJay is offline Find More Posts by bombardierJay
Old Oct 19, 2011, 01:09 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Been there and done that. Be careful, the next stage is fire.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Oct 19, 2011, 02:09 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Sounds like the ESC is missing a phase. either a FET has gone out OR you may just have a bad solder joint... are you using bullet connectors to the motor? if so were these were factory soldered? cold solder joints are not all that uncommon from the factory just out of habit I resolder any factory connector... if it's bad after that I have no one to blame but me
If the motor does not start up right away STOP! nothing good will come from keeping the throttle pinned as the motor stutters...
shultz is offline Find More Posts by shultz
For Sale 4mm Coroplast - Yellow signs flyboy330 Aircraft - General - Miscellaneous (FS/W) 11 Oct 12, 2011 01:41 PM
Discussion Obama Signs Draw Criticism....... LcJ Life, The Universe, and Politics 69 Sep 30, 2011 10:57 PM
Help! Bad motor or bad Esc Danielocean Electric Motor Design and Construction 1 Aug 28, 2009 08:17 AM
What are the Signs of a Bad Lithium Charger? JIMJAM Batteries and Chargers 2 Nov 11, 2003 10:59 AM
Signs of a Kokam pack gone bad? navyflier Batteries and Chargers 3 Jan 27, 2003 09:09 PM
