Old Sep 20, 2003, 01:15 PM
jms336 is offline
Find More Posts by jms336
Deland FL
Joined Jan 2003
Li-poly for 1.5-2.0 amps (Wal-mart sky surfer)
I have another thread over in parkflyers on my $18, 26", 2.0 oz
wal-mart sky surfer. It is controlled by differential thrust.
http://www.rcgroups.com/forums/showt...40#post1314640
Stock battery is 3-cell 200 mah nimh weighing about 0.4 oz.
The plane will only climb on the very top of the pack, so I would like to put a bit more kick in the pants with a single lipo.
I checked the amp draw and it is 1.5 at about 3.4 volts. I would guess less than 2.0 amps at 3.7 volts. What is the best li-poly in the 0.4 oz weight class to support this draw? I tried a 830 qualcomm, but it was too heavy at about 1 oz.
Also, any ideas on how to make a RFFS conversion from this plane are welcome. I have no RFFS experience. Maybe I should start another thread here in indoor.
Thanks, John
jms336 is offline Find More Posts by jms336
Old Sep 21, 2003, 07:39 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
John,
The best Li-poly is the Kokam 340mAh capable of 6.8A, it only weighs 0.32Oz
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Sep 21, 2003, 08:36 AM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
John, I second Andyone, get yourself a 340 pack, you'll have what you need. You might even try a 600 kokams, its only a tenth and change heavier.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Sep 22, 2003, 01:14 AM
Dan Leonard is offline
Find More Posts by Dan Leonard
Dan Leonard's Avatar
Lenexa KS USA
Joined Jun 2001
I bought one of these today and I think the best battery would be the E-Tec 250. Longer flight time then the NiMH but 1/2 the weight. And it will fit right in where the other batteries fit without mods.
Dan
Dan Leonard is offline Find More Posts by Dan Leonard
Old Sep 22, 2003, 09:29 AM
jms336 is offline
Deland FL
Joined Jan 2003
Let me know how yours flies Dan. Mine will not really climb, but will achieve level flight on the top of the pack. Only good for a minute or so before it becomes underpowered.
I am doing a mod right now to make it a pusher. I suspect that the prop position in the middle of the wing was destroying much of the lift. Probably not giving the best thrust either.
I reversed my polarities on the motors and put the prop on "backwards" haven't had a chance to fly it yet. I'll close up the stock prop holes in the wing with tape to restore the wing's lifting ability.
I moved the rx to the rear of the compartment and am going to put a 850 Li pO (lightest I have)
(0.6 oz) to the front. Should balance at stock point more or less. I probably gained 0.2 oz or less, as I have removed the on/off switch and fuse bottom and some tape.
I was going to take off the foam fuse but it really serves a structual function keeping the wing from folding.
John
Discussion Speed 1.5, 2.0 and 2.6 at F3X SchiessCo Slope 4 Aug 15, 2006 03:47 PM
GOOD pattern plane for FMS v. 2.0 Alpha 8.1 ?? Arthur_GA Simulators 4 Jun 02, 2005 05:35 PM
2 Phoenix 10's & 2 Tanic 2S - 2450 mah Li-poly FOR SALE tyrolean_marcus Aircraft - Electric - Airplanes (FS/W) 8 Mar 08, 2005 03:34 PM
Li-poly for Hacker B20 4.1 HELP vw63 Foamies (Kits) 16 Sep 24, 2003 10:24 PM
Looking for motor/gearbox with 1.5 to 2 oz of thrust fritts Parkflyers 5 Nov 13, 2001 02:10 PM
