Old Feb 01, 2013, 02:27 PM
FlyingPhilUK is online now
Find More Posts by FlyingPhilUK
I built a new
FlyingPhilUK's Avatar
United Kingdom, Scotland, Edinburgh
Joined Jan 2013
Originally Posted by IntegrityHndywrk View Post
Today i had my tail steering slider go out again. It's the second one in maybe 50 flights or something. Not sure. But i think it's from the oil. Otherwise my tail shaft is giving it lots of grief, or something. But for the time being, i have to recommend people stop oiling this part:
I'm fairly sure the oil is causing the bearing to separate. I think part of the bearing is plastic. I can't see too well in there, and i don't have a new one right now. But this was a all of a sudden thing the last two times. I also have a lot of sand here. Could be part of it or not. But i would think it's best to not oil this part and replace if needed otherwise.
I think sand is your killer there, mate!
- plus the oil helps the sand stick more - making it worse!
- need to be very careful with oil, especially if there is a lot of dirt around....
BTW, which slipper-clutch are you using?
FlyingPhilUK is online now Find More Posts by FlyingPhilUK
Old Feb 01, 2013, 02:29 PM
I built a new
Joined Jan 2013
Pimped out V120D02s
This guy has pimped out his V120 with a new Gyro, Rx, Servos, Motor, Esc!
http://www.helifreak.com/showthread.php?t=486675
Gyro: ZYX-S - Looks good!
Rx - I would go with FrSky Rx
Servos - any suggestions?
Old Feb 01, 2013, 02:46 PM
OrbitalGolem is offline
Find More Posts by OrbitalGolem
Joined Jan 2012
As FYI, I've been using TriFlow on the tail steering sliders for almost a year and have had no issues.
OrbitalGolem is offline Find More Posts by OrbitalGolem
Old Feb 01, 2013, 03:57 PM
I built a new
Joined Jan 2013
Originally Posted by lasakro View Post
Looks a bit like a bunch of Quad-copters hovering in the background!
Old Feb 01, 2013, 05:37 PM
IntegrityHndywrk is offline
Find More Posts by IntegrityHndywrk
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
Actually, i agree. But i still think part of that bearing may be plastic. Anyway, i also found that my tail servo is oscillating violently, not just in the center like i had thought. Full on, constant oscillation. I'm sure that didn't help things. I use the microline hobbies slipper clutch because i can easily straighten the bent shafts and i can oil my bearings regular, without too much worry.
He has the right idea, but man, what a mess!! lol hanging all those wires out the nose and everything. Looks real heavy too.
This is more my style, of course. Everyone knows i love my BeastX. Either way this is still a much cleaner install. I suppose it depends on your solder capability. I could pull this off, but i'm not going to waste my time or money.. He makes everything nice and tight though. It's a Microbeast with a Spectrum Satellite, all installed in the nose.
http://www.helifreak.com/showthread.php?t=284773
Walkera M120D01 BeastX Microbeast (2 min 57 sec)
IntegrityHndywrk is offline Find More Posts by IntegrityHndywrk
Old Feb 01, 2013, 10:51 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
put this on the v120 upside down and the tail rod will never go anywhere.
http://www.rcheliresource.com/exclus...om-kde-direct/
pmerritt is online now Find More Posts by pmerritt
Old Feb 02, 2013, 08:17 PM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Originally Posted by sbstnp View Post
If someone wants I can build a DSMX .dfu.
I would like to try the latest DSMX protocol under development.
lasakro is offline Find More Posts by lasakro
Old Feb 02, 2013, 11:05 PM
sbstnp is online now
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
You didn't specify your TX so I sent you the Devo 8 dfu.
sbstnp is online now Find More Posts by sbstnp
Old Feb 03, 2013, 03:46 AM
mountainman13 is offline
Find More Posts by mountainman13
mountainman13's Avatar
United States, CO, Colorado Springs
Joined Aug 2012
Well since my Super CP came with a DEVO7e, I decided to jump on the bandwagon and buy one of these. I'm mainly looking at it as a training tool for my Goblin 500. Wish me luck.
mountainman13 is offline Find More Posts by mountainman13
Old Feb 03, 2013, 09:02 AM
microrcfiend is online now
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Strongly consider some servo gears from chinesejade dude, then you won't be downed for weeks
microrcfiend is online now Find More Posts by microrcfiend
Old Feb 03, 2013, 10:09 AM
IHW Heli Division
Joined Mar 2012
V120D02S-XTR (V1) - Xtreme spin with 9T pinion (5 min 53 sec)
I know some of you either had once owned, or currently own a 4f200. I'm quite proud of how mine is flying lately... Hopefully it keeps together mechanically though Running close to 5000 rpm at the beginning of the flight, it can fly easily @ 70% - 80% without struggle. I'm thinking about gearing down too, well see when i get the CC Phoenix 35 ESC setup for governor though. Oh well, the project is nearly complete... Still waiting to afford a better gyro to complete the package though.
Custom 4f200 - 80% throt. You'll wish your's flew like this! (3 min 53 sec)
Old Feb 04, 2013, 06:30 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
IntegrityHndywrk, I put some of those KBDD main blades on my stock motor V120 & it's awesome. Had to increase my expo cause it banks fast to keep from dumping it. Got 2 more sets in today to put on my HP08S V120's. Might be going back to stock motors on them. Flips are no problem flying low like I do in my front yard with stock motor & KBDD blades. You should try going back stock motor with those KBDD blades you get longer flight times & see what you think.
Crash Survivor is offline Find More Posts by Crash Survivor
Old Feb 04, 2013, 10:07 PM
IHW Heli Division
Joined Mar 2012
I've been thinking about doing that actually. But with the 9T pinion on my Xtreme spin 16,300. I think i'm getting around 4 minute flights. With the Turnigy Nano packs i should be getting more. Those packs in my D05 give me a easy 5 minutes, and the D05 is quite a bit heavier. The D02S has been down for a while because the tail pitch slider blew out on me again. I have some on order though. I have a feeling that with these batteries the performance will still be better with he Spin motor. But i'm positive that the stock motor would be ripping pretty good with the KDBB blades.. Supposedly the bulleted blades are even better. I have not tried them yet. But a few people here said they work good.
You might want to dial back your cyclic EXT. pot on the RX rather than increase expo. It might feel better for you. It will calm down the cyclic. If you feel like the collective response is too high you might adjust your pitch curve a little bit more flat in the center. It's all preference, so you just have to tune it how you like.
Old Feb 05, 2013, 03:17 AM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Looks Like some illegal MO I just came across while surfing for a new Tx
-http://www.cheapproductssale.com/walkera-v120d02s-flybarless-helicopter-with-devo7-transmitter-p-451.html
- http://www.cheapproductssale.com/fut...sga-p-646.html
Spyro37 is offline Find More Posts by Spyro37
Old Feb 05, 2013, 03:49 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
That site was only created on Jan 30th this year. This is an outright scam!
http://whois.domaintools.com/cheapproductssale.com
zadaw is offline Find More Posts by zadaw
Discussion new heli from walkera HIKO400? xyzy2 Micro Helis 15 Jan 12, 2012 11:16 AM
Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! HD Hucker Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2011 12:37 PM
Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli LittleG Coaxial Helicopters 32 Jan 14, 2011 12:55 PM
Discussion Walker 4#3 throttle problem Ė new heli Ronon Micro Helis 2 Jan 24, 2009 04:22 PM
