Okay, so i got board and went to put a 9T pinion i've had for a while on in place of my 10T pinion. I never wanted to pull my 10T pinion because if i do i won't be able to get it to hold again probably. I'm out of pinion glue and don't want to get more. The drill hole is rather worn out, as is the outside of the teeth. It's had probably 500 flights or more. Hard to say.
Anyway, The 9T pinion... This has left me very confused about something i was POSITIVE about.... So what pinion modulus are people using today for the V120d02S???? ![]() ![]() ![]() ![]() ![]() Okay, the problem is. The 9T 0.4m pinion i have here did not mesh with the main gear properly! I measured it and checked the modulus myself, just to be sure (Diameter (mm) / Tooth count = Modulus). The 9T pinion came out to 0.44444, something like that. So if the pinion i have is a 9T 0.4m pinion. Why doesn't it mesh with the main gear?!? The pinion teeth are too small... So i took my caliper and measured the stock 10T pinion from the D02S. That ended up being 0.5m?? So the proper size for the V120D02S would be 0.5m if that information and calculation is correct. The Stock pinion measured 5mm diameter / 10T. So i'm very confused right now because i really was certain. Hell i've read it other places enough times too. Does anyone have a 0.4m 9T pinion they can measure and see if my particular pinion is just some "off size" toothing or something? |
Hong Kong
Joined Jan 2010
Transitions are much smoother for me because the heli regains balance much more quickly with the 6 axis gyro. Whereas those with 3 axis gyros will lose much more height and you have to compensate much faster. |
[QUOTE=hawk01;23785835]
Before maxing your cyclic ext pot. Did you by any chance try flipping the heli forward and backward? Sometimes the neutral pitch of the heli can really effect rotation rate in one direction or the other. Thats why we set zero pitch at neutral. Otherwise the pitch and cyclic pitch ranges can be skewed to one side. So a front flip might be really fast with a slight positive skew, but back flips would be slow, or slower than expected because you need more stick to do it now, and the same the opposite way around. |
United States, ND, Bismarck
Joined Mar 2012
| Thread Tools | |
| Discussion new heli from walkera HIKO400? | xyzy2 | Micro Helis | 15 | Jan 12, 2012 11:16 AM |
| Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! | HD Hucker | Aircraft - Electric - Helis (FS/W) | 3 | Oct 13, 2011 12:37 PM |
| Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli | LittleG | Coaxial Helicopters | 32 | Jan 14, 2011 12:55 PM |
| Discussion Walker 4#3 throttle problem – new heli | Ronon | Micro Helis | 2 | Jan 24, 2009 04:22 PM |
