Nov 26, 2012, 08:09 PM
United States, FL, Palm Coast
Joined Mar 2012
Originally Posted by LarsDennert
Thanks for that. I'll try it. Why would you want the tail pitch at zero when the linkage is in the middle? Wouldn't you want it set up for center of travel when hovering? Maybe there's not much difference to matter...
Maybe i'm not explaining properly. The gyro is what will be doing the "trimming" for the tail, so the gyro needs to know the neutral and end points. The ext. pot for the rudder is what tells the gyro where the END of travel is. But you can only adjust BOTH extremes at the same time. But for it to hold the tail properly you have to set the tail properly. You do want it in the center of travel, if possible but the tail blades must be at zero pitch at the "neutral point", which is where the servo centers to after binding. So typically on the V120D02S if you put the servo horn at 90° and have the tail rocker at 90° the tail pitch should be set just about right. If you do that then the tail blade pitch will be nearly zero. So using a gyro setting of 70% or 80% should hold the tail solid if you set it correctly. If your using a slipper clutch you might need to use a little bit of counter thrust if your tail kicks a tiny bit, or possibly adjust the clutch depending on what is causing the tail kicking. Having the tail setup properly is essential for 3D. Otherwise you will spin out when you pitch too hard to go to flip. But you also don't want the steering slide to press or "bind" on the extremes of travel. Adjusting "traveladj" only adjusts the TX control's end of travel, NOT THE GYRO! This is important! Because while you might move the rudder stick back and forth and the servo does not bind on the ends, the gyro might still be capable of binding the servo. Binding a servo will cause premature burn out of the motor. I've seen the analogy used of closing an already closed door. If you keep pressing against it eventually your arm will get tired and quit too. So this is where you use the rudder ext. pot. After adjusting the tail's neutral point properly you would then adjust the rudder ext. pot to give it the max travel both ways without binding.
If you have any questions please ask. I'm trying to explain this in the best way possible. But sometimes i get too technical or just don't make sense. lol.
Originally Posted by Rain4LA
I wish I was clear on exactly where you're talking about, but to tell if there's vertical movement in the main shaft, do I have to take the rear part of the tail assembly off? Or do I need to take the landing skids, main gear, and shaft holder off to figure this out?
I think you should just have to lift up on the rotor head. See if there is any movement without the servos moving. if the shaft's locking collar moved there could be some shaft play. The main gear and everything should not wiggle up and down if you lift up on the rotor or push up on the shaft and main gear from the bottom.
