Old Oct 15, 2012, 07:26 PM
IntegrityHndywrk is offline
Find More Posts by IntegrityHndywrk
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
Originally Posted by livonia bob View Post
The tail one will work on the S the main one will not.. These are what I buy to replace the tail collar ones that I screw up while drilling, tapping, screwing the set screw into them.. I have a lot of the main shaft 4#6/4G6 and all V120's but the "S" models size collars on hand... I even took one and drilled it out to the right shaft size for the S and installed set screws in it after I broke off one of the screws and had to cut the collar off with the Dremel tool. Must say that it sure locks the collar in place on the shaft now.. I was thinking of offering them as a upgrade for the S but it's very hard to drill out the shaft hole correctly every time..
Yes, i forgot to mention that the main collar won't work. Thank you. But the one in question was the tail collars. Thank you again for verifying for me.
As far as drilling the hole correctly. I would have pegged you as the type with a drill press. I used to have one myself, but my drug addled, douche of a brother broke in my shop and sold a lot of the bigger equipment quite a few years back Anyway. Since i know you are the hobby type and have a full plate, time wise, probably budget too, like the rest of us. I just wanted to suggest something i've had my eye on for months now but never end up pulling the trigger. You've probably even seen them before. But they really do work well.
The Dremel drill press! This thing looks amazing for the cost. Especially for our little hobby aircraft and little jobs like those shaft collars.
IntegrityHndywrk is offline Find More Posts by IntegrityHndywrk
Old Oct 15, 2012, 07:31 PM
IHW Heli Division
Joined Mar 2012
Hey all you guys out there that complain about the visibility of the V120d02S canopy. I'm just courious. I know there is a new green one and everything. But why are people not using this one instead/Too?:
I'm not a big fan of green. Yellow either. But if i had to choose, yellow looks better for my money. Plus it seems more visible? Just seems like all the guys complaining about visibility problems would have been using these by now. Keep in mind though that they are 3 piece composite canopies. Like all the older Walkera canopies. They are glued together down the center and around the windshield. So they will break apart easier than the new D02S or Extreme canopies that are vacuum formed as a single piece of plastic.
Personally i use these because they are cheaper, just as durable and look better (IMO)
Especially after using some decals that come with them:
Old Oct 15, 2012, 08:43 PM
RaymondM is offline
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
subscribed
RaymondM is offline Find More Posts by RaymondM
Old Oct 15, 2012, 08:49 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
That dremel press is great...it can be used as a basic router as well, I double stick taped a piece of mdf to the base and then you can position any bit right into the mdf a bit and fairly precisely cut (with a plunge cutter) and sand cf sheets among other things. It's also nice to just turn the dremel 90 degrees so that you can cut and sand or what ever without having to hold the dremel tool. I have actually only used it as a drill press once or twice,lol
I just finished using it to make new cf plates for my hotenx in this post
candy76man is offline Find More Posts by candy76man
Old Oct 15, 2012, 09:05 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I am using the Green one but it actually does not make that much difference to visibility. When the heli is inverted, the both the green and red canopy are white anyway. It is the white Solo Pro blades that makes a lot of difference. The white 4G6 tail blades seem to help a bit as well but they are smaller and do not hold the tail as well.
zadaw is offline Find More Posts by zadaw
Old Oct 15, 2012, 10:13 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
[QUOTE=IntegrityHndywrk;23010872]Yes, i forgot to mention that the main collar won't work. Thank you. But the one in question was the tail collars. Thank you again for verifying for me.
The Dremel drill press! This thing looks amazing for the cost. Especially for our little hobby aircraft and little jobs like those shaft collars. QUOTE
I have a mid size table top drill press with cross feed vise down here that has been tied up making the slipper clutch shaft notches since January.. As I'm afraid to change the set up on it as it took me a while to get it set up just right.. I have a bigger floor one at the cottage..
If there was a market for the main shaft collars with the Allen set screws like I use on the clutch I'm sure I could come up with a better way of doing it than by hand like I did mine.. But probably not at a price anyone would be willing to pay.. But mailing would be cheaper as I could send them out in a #10 envelope.. So $5.00 shipped in the USA
livonia bob is offline Find More Posts by livonia bob
Old Oct 15, 2012, 11:48 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by BThirsk View Post
Have you updated your 8S to the latest TX firmware. I think that is also suppose to have throttle postion fixes. I have it, but have not installed yet.
I have the same issue with my V400D02. I have to set -42 on the throttle subtrim to keep the rotors from spinning with or without TH. It's the only heli I have the issue with.
I read that on Walkera's website. It mentioned regarding "throttle", but not quite sure if it also relates to the TH/throttle issue.
I have not upgraded my 8S, since everything (4 models) are programmed in it & afraid of loosing them & lazy to go back to scratch. I don't think it would though.
Plus, I don't see any changes or added feature, so I'll probably wait, if anything is new, then, I'll upgrade the firmware.
- Spyro
Spyro37 is offline Find More Posts by Spyro37
Old Oct 16, 2012, 12:30 AM
IHW Heli Division
Joined Mar 2012
Very nice work. Cutting CF is exactly why i've been looking at it lately. It seems like such a great utility to have for approx $30.
The V120D05 tail blades are white and are the same size as the D02S blades. Just in case you want to try them out.
[QUOTE=livonia bob;23012349]
Well, I just thought it was odd you were doing this kind of work and putting key marks on shafts like that and everything else. I just figured you had to have a press. But i never thought about the aspect of having to set it up and align everything. So, there it is then, a useless drill press, at least for anything but making clutches
- Spyro
Since i got my first Walkera heli with a 2801-pro, It just seems like every Devo TX/RX since, including the magic cube, has seemingly been released with some kind of seriously dangerous/annoying problem that you have to spend $50 on an updater patch cord & adapter that is only worth about $2 in materials and maybe $9 retail. I'm sure they are trying their best not to profit too much on their UP02 unit. But, seriously. They seem to have a trend. Just be glad your not having the blackout issue some experienced with it. I think that was with the telemetry modules though. So don't try that until you update.
Seriously, some times i think Walkera's business model goes like this:
Step 1: Underpants
Step 2: ????????
Step 3: Profit!
If you are one of the lucky ones that know what that joke is taken from, pat yourself on the back after you get done laughing .... Otherwise, well...... I suppose you'll just have to wonder .....
Old Oct 16, 2012, 05:30 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Step 1: Underpants
Step 2: ????????
Step 3: Profit!
Microsoft / Walkera?
BThirsk is offline Find More Posts by BThirsk
Old Oct 16, 2012, 06:35 AM
Tampa,FL
Joined Dec 2003
Step 1: Underpants
Step 2: ????????
Step 3: Profit!
lol, my wife gets irritated everytime I mention how something that happened reminds me of a southpark episode
Old Oct 16, 2012, 02:08 PM
joliecoeur13 is offline
Find More Posts by joliecoeur13
joliecoeur13's Avatar
Canada, BC, Fernie
Joined Dec 2009
couple quick questions...
I noticed some recomend the gyro to be set to manual and some say set it as auto?? I have it set on auto at 80% seems ok (Devo7E)
Mine as a good wobble in windy condition ? probably need to turn something down ?
anybody ever tried to move the TH on the other side on the Devo7E ?
cheers
joliecoeur13 is offline Find More Posts by joliecoeur13
Old Oct 16, 2012, 04:10 PM
ju204 is offline
Find More Posts by ju204
Joined Jun 2008
I just hope for a plain old white canopy!
So that I can put the right visible stickers I want
(Any link would be appreciated)
ju204 is offline Find More Posts by ju204
Old Oct 16, 2012, 04:13 PM
ju204 is offline
Joined Jun 2008
I don't own this TX, but as long as I know, all devo TX have a model backup system. Maybe you should plug your TX on your pc and use the walkera dfuse software.
Also, the guys from deviationTX.com (to be checked on their forum) said that even putting a hacked firmware would keep the models. So I would not be worried. Just plan for the worst
Old Oct 16, 2012, 04:17 PM
alfmateos is offline
Find More Posts by alfmateos
alfmateos's Avatar
Spain, Madrid, M
Joined May 2012
Zadaw, what do you think about using the t-rex 250 tail blades on the v120d02s, in combination with the Solo Pro white blades? I've seen those tail blades here at this video:
v120d02s tail blade t-rex 250 la aldea de el portillo de busto de bureba.mp4 (7 min 59 sec)
alfmateos is offline Find More Posts by alfmateos
Old Oct 16, 2012, 08:19 PM
zadaw is offline
Hong Kong
Joined Jan 2010
http://www.youtube.com/watch?v=O_VztwefImU
I have heard of the small Trex 250 tail blades being used but I don't have a set right now. If you want to try, be aware that there is a larger set of 250 tail blades that will probably not fit. If you are flying backwards, it doesn't necessarily mean that bigger tail blades will be better. So I would be inclined to try a selection of different sizes.
Discussion new heli from walkera HIKO400? xyzy2 Micro Helis 15 Jan 12, 2012 11:16 AM
Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! HD Hucker Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2011 12:37 PM
Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli LittleG Coaxial Helicopters 32 Jan 14, 2011 12:55 PM
Discussion Walker 4#3 throttle problem Ė new heli Ronon Micro Helis 2 Jan 24, 2009 04:22 PM
