Joined Jun 2008
OK, I never ordered on WOW because I thought they would not ship int. I still believe it is hard to get the right info on their site:
http://www.wowhobbies.com/faq.aspx#1 Quote:
http://www.wowhobbies.com/hm-4g6-z-0...ovus125cp.aspx By the way, did anyone do the mod to get the servo system under the boom instead of over it? |
For anyone who is using the extreme skids and wondered. Below is how i mount my ESC to the airframe/rx shelf. This also helps eliminate ESC vibes from effecting the gyro. |
Can't believe that you of all people haven't covered the bare tip of the antenna wire with something to make sure you don't get a short... I use a dab of hot glue but that electrical tape we know you have is better than nothing.. |
Joined Mar 2012
Bob, Thanks for that one! Again something I never thought of but this time of year with dry air and an exposed antenna wire....ZAP...there goes an expensive RX. I do remember your tip on glueing also...the bigger the glob...the better the job .I might not put a big glob on my antenna wire tip ( I remember that was for landing gear repairs), but there will be enough there to protect from static shorts. The hot glue gun is heating up now. Again Thanks!! ![]() Viking |
It's fun being able to do stuff that I dreamed about doing 60 years ago.. But I still wish now that I had waited two more years before getting back into heli's.. As my shelf full of heli's shows, buying each new model (some times two of them) as they came out takes up a lot of space and money in spare parts for heli's that I don't fly any longer as each newer one has been easier to fly, breaks less and is easier to fix and that's just what I need.... ![]()
I'm very new to the hobby and can NOT do the all the tricks that you guys do with your 120s. I can 3D my 130X with great comfort but not with the V120. Stability and power plays a big role for me as a newbie. The V120 cost me more than my 130X due to mods, reapairs, & upgrades, forget about the repair time which is part of the hobby. The 130X's parts are very durable and I usually walk away with no broken parts, just as long as TH is toggled early enough. I have yet to strip any gear (tail/main/TT). I broke a blade grip on maiden when I smacked it to a building wall. It's got countless flights and bad crashes that the linear servo's worm gear shaft broke last Thursday. One great thing with linear servo, they can take crashes without stripping. Replacement servo won't be in 'till Tuesday. So the 300X & the V120 flew a lot today. But I can't 3D them (300X & V120) low, unlike my 130X After flying this morning, I just can't help it, so I stopped by at the LHS & ordered another/spare 130X. I don't want to have a "down time" again. Yes, it has tail issues (vibration) but fix is now available for $4. Installing silicon O-rings on the 3 Swash ball links takes care of it. - Spyro |
I don't think i've kept the D02 in the air for more than 30 seconds since getting these blades
So since the wind is being so ruthless. I brought out the v450, which was more stable but still having some trouble.
When you see the grass dancing, that's definitely some crazy wind.
My morning flight today was just 5-8mph. The 130X blades on the V120 makes the heli feel light and more responsive Much be more obvious with your upgraded motor. I tried going back to stock blades just for kicks, it felt weird like something is wrong .Did not really noticed any difference with the flight times. |
For me, the 215 motor eats the stock battery. I keep crashing so i'm not sure. But i'd think since i reduced the throttle so much for st-1, it's at like 50%-60% in the center now. So i'll probably get a little better flight times out of it. But the D05 with the 950 mAh 25C packs there is a little increase. I can get about 5 minutes of 3d now instead of 3-4 minutes. Hoping for the same result on the D02S. |
@ integrity I have realflight g5 with the controller and stuff I could sell you for $150 I've only used it maybe 20 times. The controller is in perfect physical and working condition. I just never use it. If $150 is to steep let ne know I just want to sell it for a fair price.
| Thread Tools | |
| Discussion new heli from walkera HIKO400? | xyzy2 | Micro Helis | 15 | Jan 12, 2012 11:16 AM |
| Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! | HD Hucker | Aircraft - Electric - Helis (FS/W) | 3 | Oct 13, 2011 12:37 PM |
| Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli | LittleG | Coaxial Helicopters | 32 | Jan 14, 2011 12:55 PM |
| Discussion Walker 4#3 throttle problem – new heli | Ronon | Micro Helis | 2 | Jan 24, 2009 04:22 PM |
