Since i got you, i've been meaning to ask you something don! Do you know where i can get a 2mm motor shaft replacement for my TA 215 motor? |
You'll need align feathering shaft because the HK is like butter. Order a complete set of align ball links because the HK ones are loose and not long enough to set the head up properly. The main gear assembly often won't fit properly and the auto rotate won't work. You either replace with align or sand the spacer washer to make it fit. When you get it all done, you are in for a ride with probably the hardest to handle heli of all. Read the posts on the HK250 thread and you will get lots of pointers. You will also need a 3.5mm ball sizer. |
I got a spin 16300kv & oversky hp08s 16500 kv motor this weekend. I have parts that should be here tomorrow so I can test fly the spin motor with the 10t stock pinion. I have a couple 8t pinions on the way.
I may also try the 130x main & tail blades. I'll post some video once I have a chance to run some packs through both motors. |
Thanks for the heads-up.
True, everyone had mentioned about the feathering shaft and the belt needs to be replaced with align. But 'ill try to fly first before doing that. If I find it not a fun heli even just for mild sports flying, I'll sell it all built for $60 . Rx ready. So no loss on my side, since I only paid under $42 including S&H. Electronics are old spares from my box.- Spyro Quote:
http://helidirect.com/advanced_searc...s=130x&x=0&y=0
STRANGE BUG on THROTTLE HOLD! OR is it some Tx setting?
* NEW 120D02S & DEVO 8S 1. Took-off the ground from NORMAL FLIGHT MODE. 2. Then, toggled to STUNT MODE. 3. Landed on the ground, still on STUNT mode (@ middle throttle stick position). 4. Flipped the THROTTLE HOLD. Motor stopped spinning. 5. Flipped the switch to NORMAL flight mode, then, back down throttle to ZERO. 6. Released throttle HOLD (back to idle UP). 7. The motor started spinning though I am on number "5" * The only way to avoid a damage is GO BACK TO THROTTLE HOLD IMMEDIATELY, (otherwise this thing would have gone crazy by itself), then, disconnect the battery. I repeated the procedure holding the heli, & it does exact the same thing. Meaning, the only way to fly back again is disconnect the lipo and start from scratch. Otherwise, releasing the throttle hold will spool up the motor regardless of throttle position even @ normal mode. I wonder if the new Rx FW release will fix it. But I'd still have to get the plugs to do the update. For now, I just have to remember that If I click the throttle hold, "that's it", can't fly again unless I disconnect & reconnect the lipo. Unless, someone knows the answer... - Spyro |
Japan, Tokyo
Joined Jun 2011
You need to go into the menu for THRO HOLD and edit it. I find -12 or -12.5 is good for me when I have the throttle trim all the way to the bottom and 0 if throttle trim is also zero. |
Hong Kong
Joined Jan 2010
I am going through a rotten patch with the V120D02S at the moment. i am having these brownouts seconds into a flight and two different receivers seem to be involved. I have also burnt a large number of tail servos at the same time.
I don't have a clue what is going on as everything appears to be working normally on the ground. I am going to send these two receivers back to Walkera for a check. However, I am not hopeful that they will be able to find anything out. I am going to order a new receiver and see whether the problems persist or not. |
Some dumb newbie questions
Hello !
I'm new on this thread, and havn't the courage to read the more then 400 pages ! I'm actually flying FP helis, but I know I will have to try CP helis soon (I'm addicted !)I'm looking for a model that's not too big (more crash-resistant), and the fact it has a brushless motor and can bee ordered with a Devo transmitter is a plus for me. It should also beeing able to handle some wind outdoors. So I think the V120D02S should be a good entry in the CP world. I'm also a little confused because Walkera has also the V120D05 and V120D06, and I don't know if one of these would be better then the V120D02S. Speaking about spare parts, what is necessary, knowing that in the begining, I won't try to fly 3D. I will have to learn that on a simulator before trying for real, are the Devo transmitters connectable on simulator programs ? And a last question, where would you recommend to order one and spare parts ? Again, sorry for these basic questions, but I'm totally new in CP and Walkera. Roland |
Japan, Tokyo
Joined Jun 2011
The V120D02S (3 axis) and the NEW V120D02S (6 axis) are arguably 2 of the easiest CP helis to start with. Forget the D05 and D06 at least for now, maybe forever.
There are 2 things that you will need to do to your V120D02S to make it more crash resistant: 1) Slipper clutch mod for the rear rotor 2) Servo saver mod to the servo arms (plus 3 - replace the main gear pin with some shear pin arrangement 4 - method to keep a hold of flying tail control rod (dental floss method/tape method/under boom method/reduced collective pitch, etc etc) 5 - hot glue and tape to reinforce/repair skids and canopy 6 - ... -). Search the thread for the slipper clutch, livionabob can supply you a kit for a tail clutch if you need - or you can run the V1 non adjustable fuel tube one instead. The servo saver mod - search the thread again but basically, it's a small slit in the servo arm which allows it to expand and slip instead of destroying the servo. Spare parts... main gears x5, tail gears x5 (if you skip the clutch), main and tail blades x2, landing skids, canopy (if you care about the looks), tail control rod x2, boom. Then you may, depending on how badly you are crashing require tail boom and drive shaft, tail servos (they tend to fry), cyclic servos (if you skipped the servo saver mod).... rotor head assembly with blade grips ... etc etc... |
| Thread Tools | |
| Discussion new heli from walkera HIKO400? | xyzy2 | Micro Helis | 15 | Jan 12, 2012 11:16 AM |
| Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! | HD Hucker | Aircraft - Electric - Helis (FS/W) | 3 | Oct 13, 2011 12:37 PM |
| Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli | LittleG | Coaxial Helicopters | 32 | Jan 14, 2011 12:55 PM |
| Discussion Walker 4#3 throttle problem – new heli | Ronon | Micro Helis | 2 | Jan 24, 2009 04:22 PM |
