The side wall of aluminum can is just about 0.1mm thick. Cut and drill a hole, mounting on main shaft, then cut around with a scissor, the thickness of scissor may control the place to cut. I made two for you in one min, the outer diameter is just 3.5mm. Not only that, I also added it to the main blades damper to harden it, the skill developed from my first heli Walkera 52# until now, every heli from Walkera all get too soft in the damper. |
Incredible!!! Your answer is awesome! That's what I did this afternoon, it suddenly came to my mind, and it seemed to work, but I did it thinking that you would not advise it. Your answer "the material for those 0.1mm washers is everywhere" is like an a answer from a Zen Master. Simple and useful solution. THANKS A LOT!!!
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
In crashes, when the tail is stopped and main rotor keeps spinning, the main shaft slips down and the gear is no longer attached, thus prevent gear from getting damaged. Since having this mod, I did not replace the gears for > 20 crashes so far, some of them is even tail in crash. |
Joined Jun 2011
thank you.... =) |
Joined Apr 2012
Tail Booms in the UK
I've been lurking here a while -well actually reading shed loads of threads and I'm just about up to speed on all things Walkera 120 size.
I was having trouble finding a suitable supplier for DIY tail booms in the UK since the postage from USA is prohibative to say the least. Anyway I finally found a place in the UK that does them with only £3 P&P ... the guy even cut them to approx lengths to save on the shipping. SQUARE TUBE 3.0mm x 750mm (2mm round internal bore) £2.99 http://www.conceptmodels.co.uk/CARBON%20MATERIALS.htm One length makes enough for 4 booms & I got 5 lengths (which worked out about 90p a boom inc P&P) so I have a few in reserve now for when I have gravitational issues
| Thread Tools | |
| Discussion new heli from walkera HIKO400? | xyzy2 | Micro Helis | 15 | Jan 12, 2012 11:16 AM |
| Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! | HD Hucker | Aircraft - Electric - Helis (FS/W) | 3 | Oct 13, 2011 12:37 PM |
| Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli | LittleG | Coaxial Helicopters | 32 | Jan 14, 2011 12:55 PM |
| Discussion Walker 4#3 throttle problem – new heli | Ronon | Micro Helis | 2 | Jan 24, 2009 04:22 PM |
