first crash today.
First flight this morning, during stunt flight mode, the tail boom partially slipped out of the body, pushing the beveled tail gear out of the drive shaft. Lost (NO) tail control. - lost the tail servo linkage (pushrod), & the tail rocker arm's metal ball link, which probably, still attached to the pushrod. - But found the tiny tail gear that was keyed to the drive shaft on the runway. - Everything else are OK & all servos are fine... |
Joined Jun 2012
On my maiden flight i put the V120D02S down from about 2 feet into soft grass by turning off the engine. I broke off the lead on the rotorhead, one of the links flew off and one of the balls broke of the swashplate and the little tail gear in the gearhouse lost 5-6 teeth.
I then ordered A LOT of parts as I expected the worst. But since then nothing has broken, and I have crashed it a lot of times and from far higher altitudes and speeds.. (Knock three times on the table )
1st crash with the new slipper clutch
It was pretty far away when it went in. I got TH just a few feet before it hit the ground. All that grass & it goes down on the hard packed desert. I popped the ail servo loose & lost a link. The slipper clutch seemed to do it's job.
Rocker arm.
Has anyone used this, looks like it's for 120D02S CNC upgrade? http://www.wowhobbies.com/hm-4g6-z-0...p-1-1-1-2.aspx |
Funny enough, i always find lost parts out in the field though.. I crash and walk past a blade grip there, a stopper cap here. My favorite was a WHOLE helicopter i though i lost on a lake bank! The landscapers found it and returned it to me when they saw me flying! lol. Quote:
Joined Jan 2012
I just replaced a main gear, "A" gear, and turned the elevator servo gear 180 degrees after a tooth broke off during a front flip (eerily similar to TucsonFlyer's mishap on 8/13, also leading to my first heli-injury when the little bastard shot at my right arm - scary how sharp these little blades are).
Everything is smooth again and the servo is working well on its "second life". What is baffling me is when I checked the tail adjustment mechanically with 20% rate-hold gyro on the test flight. The tail had been dialed in prior to the repairs with a tiny amount of CCW rotation. I didn't expect the quick CCW spin though after the work was done and I switched to rate hold. I had to tighten the tail rod several turns to get it dialed in again. What is this indicative of? Do I now have more or less main rotor torque/power than before? Can these new parts really have that much of an effect on the mechanical tail adjustment? I'm assuming that I may need to re-check the adjustment as the parts "break in"?
Check that your tail servo did not slide back on the boom.
OK, thanks.
I just then ordered the stock rocker & tail pushrod from here: http://www.nitroplanes.com/walkerahe...7-rtf-24g.html I also added a feathering shaft & mainshaft, just in case... This (U.S.) store have it in stock as well http://helircstore.com/shop/index.ph...product_id=405 , but Nitroplanes is local & I usually get them in 2 days. WOW is out of stock... - Spyro Quote:
Joined Jul 2008
Finally figured out why I was going through a silly number of tail shaft gears, and always the hard-to-replace one under the main gear:
I had the tail shaft in the wrong way around! It has a longer 'notch' on the end which is supposed to be under the main gear. It seems to fit fine if reversed, but it doesn't go the full length into the gear, making it strip (notched->round) a lot more easily. (yes, I know... I need a slipper clutch!) Had to replace my rotor head today for the first time... that's a fairly nasty job, isn't it... especially when the screws holding the blade grips strip extremely easily, and the only way to save the blade grips is to cut your way through the old rotor head, so you can grip the shaft with pliers... Anyway, after a few more repairs my heli is flying smoothly again ![]() The biggest problem that I've got with this heli is that you need a very smooth surface for take-off - smooth enough for the tail fin to slide over and not get stuck in. If the heli is unable to rotate freely (e.g. tail fin digs into carpet), the heli gets very confused, tries to overcompensate, and spins all over the place when the tail fin leaves the ground... |
Joined Jan 2012
Patients is a virtue. Something i typically have none of. But if you have that problem again. Bust out a soldering iron and let it get hot. Touch the tip to the screw head being careful not to touch the plastic! Let the screw get hot for a second (be mindful it's connected to plastic!) and then try to loosen it. The heat will loosen any thread lock on there and thermal expansion also aids in removal of tightly threaded screws too sometimes. Also, As orbital mentioned. You should be lifting off rather rapidly once you get your head speed up. Leaving a 3 axis gyro sitting on the ground will give odd feedbacks to the gyro. "Scale" lift offs are not usually recommended. You want to slowly spool the rotor up to get the head speed up and avoid kicking the tail around right off the bat! But once the head speed is up you want to kind of "pop" off the launch pad. WITHOUT using cyclic!!!! This is why it is very important to have your mechanics setup correctly! Because using cyclic before the heli is in the air will also confuse the gyro because there is no motion going on besides the feedback resonance from the landing skids touching the ground. So once you "pop" into the air. All your controls should feel and work normally. If you set up your mechanics right the heli should just lift straight up into the air. |
Joined Jun 2005
I typically take off from my driveway. I spool up the heli which I have set to not take off in spool-up mode. Once the blades have reached speed, I roll the cyclic and also give it a left & right move of the rudder before lift-off. I've found doing this "sets" the gyro. Note that I do all this in perhaps 2-3 seconds, it doesn't take long. I then throw the switch for flight and give it a bit more throttle and it lifts off nice and smooth, no tilting, rotating, nothing. Just how I found to do it and it works well for me. YMMV... |
| Thread Tools | |
| Discussion new heli from walkera HIKO400? | xyzy2 | Micro Helis | 15 | Jan 12, 2012 11:16 AM |
| Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! | HD Hucker | Aircraft - Electric - Helis (FS/W) | 3 | Oct 13, 2011 12:37 PM |
| Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli | LittleG | Coaxial Helicopters | 32 | Jan 14, 2011 12:55 PM |
| Discussion Walker 4#3 throttle problem – new heli | Ronon | Micro Helis | 2 | Jan 24, 2009 04:22 PM |
