Old Dec 09, 2012, 04:05 PM
ad skyraider is offline
Find More Posts by ad skyraider
ad skyraider's Avatar
United States, IL, La Grange Park
Joined May 2012
Originally Posted by vmmattil View Post
With what receiver did u bind it to the champ tx?
I used the OrangeRX R415 Spektrum receivier.
It does not come with a bind plug but all you need to do is temporarily connect the two bind posts together with a wire while you bind it to the Champ tx.
The Champ tx does not have expo so the plane reacts a bit twitchy but is completely flyable if you do small movements on the sticks.
The plane fly's great but I do not suggest a beginner go from the Champ to the Slick. The PZ UM T-28 is a good in between plane.
ad skyraider is offline Find More Posts by ad skyraider
Old Dec 10, 2012, 12:58 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
The Champ Tx does have low rates though by pushing down on one of the sticks.
That should help a lot.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Dec 10, 2012, 09:49 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I personally think that's bad advice, especially on a plane with good control authority. The problem with the toy transmitters is that you cannot set rates on surfaces differentially. I've nearly lost a couple birds because I couldn't pull enough G's (for lack of a better term) to pull up.
BryanEW710 is offline Find More Posts by BryanEW710
Old Dec 10, 2012, 11:32 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
You can run super low rates on these planes with no problem at all.
They are way too sensitive to maiden at full rates for an average pilot.
Was for me anyway.
Just my opinion though.
EDIT - Will the Champ Tx give Ail control? Don't like the idea of no Ailerons.
Old Dec 10, 2012, 01:16 PM
BryanEW710's Avatar
Joined Sep 2010
Was for me anyway.
I've gotten to the point where I won't fly on low rates. That's just me, though. I'd sooner dial in a ton of expo.
Old Dec 10, 2012, 01:22 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I like to start low and work up as I gain experience with the planes.
Can't stand a twitchy maiden flight trying to trim out.
Old Dec 10, 2012, 08:45 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
I have a brand new v2 for sale if anyone is interested http://www.rcgroups.com/forums/showthread.php?t=1786786
3d astronaut is offline Find More Posts by 3d astronaut
Old Feb 12, 2013, 08:23 PM
ampdchaos is offline
Find More Posts by ampdchaos
United States, CA, San Diego
Joined Oct 2012
Man i shouldve read this thread before maidening my slick.. I thought my rates were low enough to maiden but it wasnt. nothing major lowered even more now and its flying great!
ampdchaos is offline Find More Posts by ampdchaos
Old Mar 21, 2013, 12:15 AM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
About to pick up one of these slick Slicks... do these servos plug straight into the R415, or did you need adapter cables?
To anyone - what are the receiver options out there that have mating sockets for the servos on the V2? Seems like the AR6310 is the wrong pitch
habitforming is offline Find More Posts by habitforming
Old Mar 23, 2013, 05:12 PM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
The R415 is the best choice. Cheap and works great. Servos plug right in, no adapters required.
4x4rc is offline Find More Posts by 4x4rc
Old Mar 23, 2013, 10:35 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I was going to say basically the same thing but then wondered if he just has a different Tx.
P.S. - HK just came out with the OrangeRx/Gyro combo.
Would it not be awesome as heck to get a micro combo?
Would love to fly this plane with a gyro.
Old Mar 24, 2013, 10:02 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Here's the link:
http://www.hobbyking.com/hobbyking/s...dproduct=31586
Gene K
speedy01 is offline Find More Posts by speedy01
Old Mar 24, 2013, 06:01 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Thanks guys, I had browsed the thread and thought I saw somewhere that someone used adaptors to hook up the R415. Looking back at it now, I think it was just extensions. Bought a R415 from someone on here, which actually arrived yesterday. Just starting to put her together now.
I did have one problem with it - the motor sounded very rough turning it by hand. After taking everything apart, I found that one of the magnets had popped loose. It was a simple fix - pick out the glue residue, put back in place, and flow a bit of thin CA over it. I've only dry fit the parts and hooked up the electrics so far, motor seems to work fine and all the servos move, so we're off to a good start
Old Mar 24, 2013, 09:48 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Those of you with the v2 (or using 3s), are you holding the battery down with velcro, or just allowing the canopy to hold the battery? I have a v2 and just had to sand a good bit off the bottom of the front canopy tab so that I could even install it over the battery. If I need to add velcro underneath and thus remove more off of the canopy, there won't be much of a tab left.
Old May 08, 2013, 05:49 PM
Marwin is offline
Find More Posts by Marwin
Marwin's Avatar
The Netherlands, ZH, Wassenaar
Joined May 2011
Can somebody help me to tell where I need to putt the 3s 180mah lipo in this small handsome slick v2 version. Do I user the same place (front between the wing) just like the 2S version or do I need it to slide it in the front under the motor-hood because there is a opening were the 3s 180mah seems just to fit in...
Marwin is offline Find More Posts by Marwin
Discussion Micro Magic - Official thread Boomer1 Sailboats 1053 Feb 07, 2016 05:02 PM
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 02:41 AM
Discussion official thank you thread. antslake The 2011 NEAT Fair 24 Sep 27, 2011 10:53 PM
Discussion Slick-3D-micro for PZ Brick - Now 2S Brushless! rcflyer11 Scratchbuilt Indoor and Micro Models 153 Mar 15, 2011 11:09 PM
Off Site Official Micro Citabria Thread youngblood22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 21, 2008 10:05 PM
