Old Sep 18, 2012, 12:02 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I'd fly at 100% rates with 50-70% expo to start. It's kinda standard on all my 3D planes. You might even want to try 80% expo on all surfaces.
BryanEW710 is offline Find More Posts by BryanEW710
Old Sep 18, 2012, 06:55 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
My as3x board went out yet again (elevator servo again lol) So now this plane has been benched for a while.. Well I am going back to individual servos and thinking about tossing my park 250 motor in this thing for kicks lol. Havnt decided yet but its a great possibility.. Thoughts??
3d astronaut is offline Find More Posts by 3d astronaut
Old Sep 23, 2012, 09:40 PM
ad skyraider is offline
Find More Posts by ad skyraider
ad skyraider's Avatar
United States, IL, La Grange Park
Joined May 2012
Originally Posted by Krycek W View Post
I had glue everything together last evening and all pieces of foam fit together very well. Final look is awesome.
I had made the pre-flight check, motor and servos are Ok. No problem with the possible bare wires between the ESC connectors and the motor. I will adjust the position of the ESC, Rx and battery for the right CG in the next evening. I use the Nano-Tech 180mah-3S.
I plan to adjust the low rate for the maiden around 50% of throw for the elevator and aileron as some of you suggest in the previous post about the 2S version. Other suggestions about throw and expo %?
Have you had a chance to fly this plane yet?
ad skyraider is offline Find More Posts by ad skyraider
Old Sep 24, 2012, 11:00 AM
Krycek W is offline
Find More Posts by Krycek W
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
No, not yet, I was out of town for the last few days. I plan to tune the CG in the next evening. Maybe I will post some pictures of my final setup (ESC, Rx and battery position) if some of you are interested.
I plan to do the maiden on the next week-end.
Krycek W is offline Find More Posts by Krycek W
Old Sep 27, 2012, 07:29 PM
msdumo is offline
Find More Posts by msdumo
Canada, ON, Calabogie
Joined May 2011
I have a very beat up T28 that I converted to 2S brushless. More than 9 lives out of this one.
Linear servos are getting tired and there is a pile of gorilla glue.
My new Edge 540 should be in tomorrow. Just joining this thread.
I'm hoping for a good experience. My first HK plane.
msdumo is offline Find More Posts by msdumo
Old Sep 28, 2012, 11:32 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Late to the party
Removed
speedy01 is offline Find More Posts by speedy01
Last edited by speedy01; Sep 28, 2012 at 11:41 AM. Reason: Removed spinner by cutting through glue....
Old Sep 29, 2012, 06:55 AM
msdumo is offline
Joined May 2011
Assembled and maidened my Edge.
Motor sure is noisy. Servos are quick and very silent compared to linear servos from HH.
Had a great start. It flew well and required no trim.
I got carried away after several minutes and don't really no what happened after agressive flying but crashed nose first.
Knocked the rudder and vertical wing off. Bent the motor shaft.
It survived very well considering the crash.
I had a burned out AP05 and used parts from it to repair the shaft. Changed the prop to a balanced 5030 and should be back flying today.
I'm still trying to find a better way to improve the battery storage area to keep the battery from shifting.
Too early to be happy yet but I think this plane will work out.
A big change from HH planes. I do like working with individual servos and the OrangeRX receiver.
Old Sep 29, 2012, 07:45 PM
Joined May 2012
What tx are you using?
Old Sep 29, 2012, 08:29 PM
msdumo is offline
Joined May 2011
DX6i
Old Oct 01, 2012, 10:28 AM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
I finally find some time to finish to setup my Slick v2
Old Oct 01, 2012, 10:33 AM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
Final Setup with the manuel CG
Here are some pictures of my Slick v2 with the manuel CG.
I use a Nano-Tech 180mAh-3S.
Old Oct 01, 2012, 10:42 AM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
Final Setup with the manuel CG ESC location
Here is where I glue the ESC for the correct CG. It's glue at the rear side of the pocket suggest for the ESC.
Old Oct 01, 2012, 10:45 AM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
Final Setup with the manuel CG Rx location
Here is where I glue the Rx for the correct CG.
Picture with and without the canopy.
Old Oct 01, 2012, 10:48 AM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
I found that the magnets for the canopy are no very strong. I think I may lost the canopy on a quick snap roll.
Does somebody have make a modification/improvement to be sure that the canopy will stay in place?
Old Oct 01, 2012, 11:05 AM
JPHen is offline
Find More Posts by JPHen
JPHen's Avatar
USA, VA, Spotsylvania
Joined Nov 2003
Remove the tape over the magnets and also use your fingernail to push the foam so the magnet sits flush on the metal.
JPHen is offline Find More Posts by JPHen
Discussion Micro Magic - Official thread Boomer1 Sailboats 1124 Yesterday 08:50 PM
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
Discussion official thank you thread. antslake The 2011 NEAT Fair 24 Sep 27, 2011 09:53 PM
Discussion Slick-3D-micro for PZ Brick - Now 2S Brushless! rcflyer11 Scratchbuilt Indoor and Micro Models 153 Mar 15, 2011 10:09 PM
Off Site Official Micro Citabria Thread youngblood22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 21, 2008 09:05 PM
