Old Aug 23, 2012, 09:27 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Well that's a tough question.
It's slow capable but you won't be doing that for long. Way too much fun running and gunning with rolls, etc.
I glide it in to land with throttle off.
I would say a touch faster than you're Sukhoi is a safe minimum.
If you dial the rates way down, you can control it fairly easily.
It can turn super quick if you're not easy on the ails.
I can't even imagine this thing on 3s in a V2 model.
My V1 is fast as heck.
I'm assuming the extra power is for aerobatics.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Aug 23, 2012, 09:28 AM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
If you've flown a HH micro, I would say a touch faster than a Trojan is a safe minimum.
That makes sense.
Thank you
BryanEW710 is online now Find More Posts by BryanEW710
Old Aug 23, 2012, 09:38 AM
strykerf27q is offline
Find More Posts by strykerf27q
Joined Mar 2012
im going to dial down my elevator today until i can pull full back on it at speed without the plane wanting to spiral.
strykerf27q is offline Find More Posts by strykerf27q
Old Aug 23, 2012, 02:40 PM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Well, don't turn your expectation up to high
Maidened my V2 today and flew it back to back with my V1.
No noticeable higher top speed, and the added weight just makes the V2 more brutal in the stalls. More wing rock in harriers, and needs to be landed at higher speed than the V1. On the positive side I like the newer color scheme better, and I get a bit longer flying time with V2.
I am seriously considering swapping the 2 cell motor and ESC over in the new body, like that setup better, and take the inevitable crash with the 3 cell setup in the old worn V1 airframe
KaiWE is offline Find More Posts by KaiWE
Old Aug 23, 2012, 02:48 PM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
As expected. This bird needs to be kept light. I think the Zippy 2s 350 batteries are the max. you want in them. As you keep piling on weight the flight characteristics take a dive.
Flown near stock weight and at correct CG it's fast but very stable and rolls and loops amazingly. Being virtually symmetrical it has zero self-righting tendencies, however.
4x4rc is offline Find More Posts by 4x4rc
Old Aug 23, 2012, 04:50 PM
Joined Mar 2012
i have a really weird problem with this plane. When flying with high rates, when i pull back hard on the elevator at speed, the plane obviously goes up but it also wants to spiral. If i don't pull back as much, it doesn't spiral. The same thing happens on low rates?? I don't see the ailerons moving when i pull back hard when the plane is in my hand. I make sure I am pulling straight back when in flight as well.
Old Aug 23, 2012, 04:52 PM
Joined Mar 2012
is the v2 airframe different?
Old Aug 23, 2012, 10:06 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I don't mean to be rude but this info really makes me happy!
I'm thrilled with my V1 and was feeling the pain of just missing out on the V2.
Now I don't feel so bad about the whole deal.
It almost sounds like the V1 is a better overall plane.
Thanks!
Old Aug 23, 2012, 10:11 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Every time you post about this you say "I pull back hard" on the elevator.
Stop doing that...
You have to limit travel with your low rates.
What do you have them on?
Keep going down until you can't do tight enough loops to suit you.
At that point if it's still spraling out, you have another issue perhaps.
Old Aug 23, 2012, 11:23 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Just the colors, all parts are interchangeable (and it comes in the V1 box with picture of a V1, just a small sticker to tell its V2 - and a V1 manual)
Old Aug 23, 2012, 11:28 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
It is not the ailerons - it is because you stall...
Old Aug 23, 2012, 11:30 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Thanks!
Yep, I prefer the 2 cell version too - so the old motor/ESC is moving over in the new airframe
Old Aug 24, 2012, 07:20 AM
CorvetteC5 is online now
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
I have had this same issue on some light foamy aircraft. In each case it was the elevator twisting in the middle where the foam is thinnest, when in flight. Reinforcing this weak point with small music-wire taped in place solved the problem.
CorvetteC5 is online now Find More Posts by CorvetteC5
Old Aug 24, 2012, 08:04 AM
BryanEW710's Avatar
Joined Sep 2010
Stop doing that...
I was kinda thinking that, too.
Old Aug 24, 2012, 12:20 PM
Joined Mar 2012
Good call! I noticed my elevator was creased a bit but dident pay much attention to it. I will try to reinforce it to see what happens.
Discussion Micro Magic - Official thread Boomer1 Sailboats 1159 Sep 29, 2016 05:25 PM
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
Discussion official thank you thread. antslake The 2011 NEAT Fair 24 Sep 27, 2011 09:53 PM
Discussion Slick-3D-micro for PZ Brick - Now 2S Brushless! rcflyer11 Scratchbuilt Indoor and Micro Models 153 Mar 15, 2011 10:09 PM
Off Site Official Micro Citabria Thread youngblood22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 21, 2008 09:05 PM
