Old Oct 20, 2011, 12:14 AM
Flying V is offline
Find More Posts by Flying V
Porro et Sursum
Flying V's Avatar
Australia, New South Wales, Lismore
Joined Oct 2010
How are they using a AP05 on 2s with the 5043. From my extensive experience with these particular motors, that prop draws closer to 5 amps than 3 and HK says peak current is only 2.8 amps on the AP05, and hovering can only draw more current. Sounds suspect to me.
Flying V is offline Find More Posts by Flying V
Old Oct 20, 2011, 03:31 AM
will3d4food is offline
Find More Posts by will3d4food
H-King, DuraFly, Turnigy
Joined Mar 2008
Testing between 8-10 different models with about 5-6 flights on each in 90 degree weather I have not had any over heating issues or motors fragging. The AP05 because it is smaller does not have the surface area to dissipate and distribute the heat efficiently as compared to larger motors so in that case we have made sure that all our micro airplanes have Naca style cooling underneath the cowling along with other cooling holes in the fuselage along with our open motor compartment design we are able to move the most volume of air throughout the motor compartment as possible while keeping the motor mount rigid, We have also made some other smaller changes such as a large spinner to cut down on the prop disc area etc etc. Alot of focus on the details went into this plane.
In my personal opinion I do believe the AP05 is a little underrated and is capable if sustaining around 3.4amps continuously only with proper cooling, this ap05 setup is not pulling anywhere near the amp draw you had mentioned, the reason we chose this setup is because it is tried and tested in models like the umx beast.
As like any electric plane i do disclaim 15-20 seconds of throttle burst, this is noted on the box and manual. I am using a flightmax 2s 180mah 15c, so if you wish to get longer flight time with a little lower thrust you can use a gws 5x3, this will also cut down on amp draw.
will3d4food is offline Find More Posts by will3d4food
Old Oct 20, 2011, 09:58 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Flight times?
stgdz is offline Find More Posts by stgdz
Old Oct 20, 2011, 10:29 AM
Joined Mar 2008
out of the box its designed for performance, with a 180mah it gets a modest 2:30 with a bit of 3d, if you use a 5x3 I know guys who are getting 3:00+
Zippy 180's sell for $1.58/piece so you can grab a hand full and go fly.
Old Oct 20, 2011, 12:52 PM
richos is online now
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
will3d4food ? The DSM2 Compatible 4Ch Micro 2.4Ghz Receiver has only 4 conector holes so how do you conect 4x 1.7g micro Servos and a 6A ESC in to the 4 conector holes
Will a servo Ylead be used?
Will a 6A ESC w/BEC with Molex 3 Pin conectors be available as a part?
richos is online now Find More Posts by richos
Old Oct 20, 2011, 01:14 PM
Joined Mar 2008
Yes our ailerons come with a pre-installed molux y-adapter to plug into a single aileron channel leaving enough space for throttle, elevator, and rudder.
The equipped Turnigy 6amp ESC comes already installed with a molux 1.25 connector.
We will soon have some of our smaller ESC's with the molux 1.25 connector already installed as a part, but this will be a couple weeks from now. In the meantime we will have molux adapters and leads for you to convert your existing servo leads over, this new item will be coming within the next week or so.
Old Oct 20, 2011, 01:58 PM
rcinstructor is offline
Find More Posts by rcinstructor
Joined Nov 2008
I will buy one so long as it is guranteed to always land inverted power on at me in my hand. Hope you never fly in front of whoever insures the AMA (I know youur in China). You must make of a video of that "hover to the wall and then your taxi up and down the wall thing you do".
rcinstructor is offline Find More Posts by rcinstructor
Old Oct 20, 2011, 02:04 PM
why_fly_high is online now
Find More Posts by why_fly_high
Even that isn't fast enough
United States, OK, Edmond
Joined Sep 2004
7. Under no circumstances may a pilot or other person touch a model aircraft in flight while it is still under power, except to divert it from striking an individual. This does not apply to model aircraft flown indoors.
At the very second he touches it, it is no longer in flight.
why_fly_high is online now Find More Posts by why_fly_high
Old Oct 20, 2011, 07:08 PM
edak is offline
Find More Posts by edak
edak's Avatar
Joined Feb 2009
I couldn't help myself so I bought one...
I was quite peeved that I couldn't use UPS shipping (customer service couldn't explain it and basically told me I am crazy) even though it was clearly under the 1kg limit. EMS is slower and more expensive.
I have been waiting for a micro 3D which will hopefully be more fun than my PKZ UM T-28 but in the same size range.
I will let you guys know what I think of it when EMS (eventually) delivers it.
edak is offline Find More Posts by edak
Old Oct 21, 2011, 04:32 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Buddy code!
maukabud is offline Find More Posts by maukabud
Old Oct 21, 2011, 07:39 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by maukabud View Post
Order up while they last...and save a little bit of dough:
http://www.hobbyking.com/buddy.asp?c...1-35E18C588EA9
(must be logged in as member)
Bud, pulled the trigger Bud
PS- myself and other are searching for better runtimes...perhaps makeup some 240s' for it? 3 min. runtimes are pretty short.....
Hyperion has a 2s 240mah that weighs 2g more and is actually the same size, just a little thicker. $11 a pop but you get free shipping.
http://rclipos.com/Hyperion_G3_CX.htm
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 21, 2011, 08:18 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
Old Oct 22, 2011, 01:55 AM
edak is offline
edak's Avatar
Joined Feb 2009
woah woah woah woah..... only 2:30 flight time? daaaaaamn!
You make me wish I ordered 10+ batteries, I only ordered 4!
Old Oct 22, 2011, 02:10 AM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
Old Oct 22, 2011, 02:13 AM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
Discussion Micro Magic - Official thread Boomer1 Sailboats 1134 Yesterday 09:39 PM
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
Discussion official thank you thread. antslake The 2011 NEAT Fair 24 Sep 27, 2011 09:53 PM
Discussion Slick-3D-micro for PZ Brick - Now 2S Brushless! rcflyer11 Scratchbuilt Indoor and Micro Models 153 Mar 15, 2011 10:09 PM
Off Site Official Micro Citabria Thread youngblood22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 21, 2008 09:05 PM
