This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Old Oct 18, 2011, 12:23 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
SR-71 profile rocket glider
For those of you that missed out on a hobbylab SR-71, or just thought it was too expensive or hard to fly, I decided to update my profile version, larger than the hobbylab version but for the same 24mm reloads.
I used up all my scrap depron last night, re-working my SR-71 profile for rocket boost. I pushed the motor mount as far forward as I could for CG reasons, without sacrificing the look, and I modified the elevons to be a bit thicker and took out the carbon reinforce and the decorative cuts that were to match the top view. I don't think it will impact the look at all.
It's very simple, only carbon needed is a single 1/8" longeron to give some support to the neck area, only difficult part is slicing the slots for the nacells at a slight angle, not hard, just need to do the same thing on both sides.
This version came in around 9.75 oz or so, about 50% less than the hobbylab version.
Here are the pieces and assembled test version. And then the final product, showing servo and rx/bec mounting and launch lug.
Test flight today, 10/22/2011 was perfect, about 3/16" of uptrim on the flap switch for glide, very nice easy slow landing and flare
Plans are here:
http://www.rcgroups.com/forums/showthread.php?t=979395
Frank
burkefj is offline Find More Posts by burkefj
Old Oct 19, 2011, 02:29 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Profile SR-71
Looks good to me!
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Oct 20, 2011, 08:31 PM
FlyBoy38L is offline
Find More Posts by FlyBoy38L
Failure is ALWAYS an option
United States, PA, Quakertown
Joined Mar 2008
Ha I love the idea of a profile boost glider. I've been wanting to try boost gliding and now have found the way!
Can't wait to see this video!
FlyBoy38L is offline Find More Posts by FlyBoy38L
Old Oct 22, 2011, 10:33 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Yes indeed. It was a nice landing. Interesting idea, even if I have seen projects like it before. It has been a while. Really liked to see your success.
Old Dec 05, 2013, 11:37 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
I made another adapter for my SR-71 and X-15 using a grayson V3 microjet and a 20 amp esc that I can swap between them using the same motor that plugs into the rocket mount. Works great. I'm using an apc 6x4 and a 3 s eflite 800mah pack and get between 5-6 minutes at about half throttle, unlimited vertical etc. I got bored with the full flat black and decided to put a bit of silver sharpie accents on the SR-71.
Frank
SR-71 Hobby Labs R/C rocket plane to electric pbrokaw Electric Ducted Fan Jet Talk 6 Aug 30, 2008 03:07 PM
Discussion Hobbylabs SR-71 Rocket Glider gfrench Rocketry 1 Feb 04, 2006 10:25 AM
FS- Sr-71 Hobby Lab RTF rocket with radio sgonzo Aircraft - Electric - Airplanes (FS/W) 4 Jul 01, 2004 02:55 PM
