Old Oct 18, 2011, 10:20 AM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
prop advice: calm day vs. windy day props?
Hi All,
Does anyone know or have experience using different size/pitch props on windy days, and did it make much difference in flight?
Its starting to get windy and cold here in the great white north, and this past weekend I was flying my PZ P-51 with winds of 35kph/50+ gusts, but it was a little hairy with the 10x6 I had on it. Needed about 70% throttle on my 3536-1020kv 3s2200mah to move forward into the wind, and battery was completely up front, a little nose-heavy for the wind.
Maybe a smaller diameter or smaller pitch on windy days?
protocol is offline Find More Posts by protocol
Old Oct 18, 2011, 10:35 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Going to a smaller diameter would result in less thrust, exactly the opposite of whats needed! If your wattmeter tests allow an increase in pitch, you would get a little more forward airspeed. The only other recourse is a bigger motor for more power.
Your plane likely flies at 80 klm/hr in still air, if your flying in a 50 klm/hr headwind, it will certainly take 3/4 throttle to go forward, that completely normal! It will go like a rocket the other way, tho. Have fun!! Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Oct 18, 2011, 10:45 AM
protocol is offline
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
thanks for the advice Doug!
I was thinking that a smaller diameter means less of a 'wall' for the wind to run into (drag?), but then again, I don't know anything about props
Maybe I'll put in that G10 I have, I've been slowly working up to it.
oh yeah, the downwind speeds were the fastest I've flown, pretty zippy!
EDIT: mailman just came with some 10x8 props, will try soon (ordered last wk)
Old Oct 18, 2011, 11:17 AM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Originally Posted by protocol View Post
...I was thinking that a smaller diameter means less of a 'wall' for the wind to run into (drag?), but then again, I don't know anything about props
A larger diameter prop running at a slow RPM can have a significant braking effect that can make handling in the wind more difficult. A moderate RPM will prevent braking and maintain the thrust needed to counteract wind speed and turbulence.
whitecrest is offline Find More Posts by whitecrest
Old Oct 22, 2011, 07:05 AM
GTAEF is offline
Find More Posts by GTAEF
Account Closed
GTAEF's Avatar
Toronto, Canada
Joined Aug 2009
Hi All,
James..try the apc 10/7 or the MAS 10/8
MUCH better choices for your setup,,,and mate, plop that G10 in,,,mine is now a rocket with the 10/7 apc or mas 10/8 she is FAST!
cheers
GTAEF is offline Find More Posts by GTAEF
Old Oct 22, 2011, 12:51 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
I generally fly my planes with two different props, depending on whether it's windy or calm.
On windy days, I drop the diameter by one inch, and increase the pitch by one inch.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 22, 2011, 10:13 PM
protocol is offline
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
NFZ, that's exactly what I was thinking, except for increasing the pitch. I will try the next windy day
Tommy, I'll be bringing all my 10x props, including 10x8 to the field. I'm going to put in the G10 next week
thanks for the replies all, great info!
Discussion One prop + gearbox vs. Two props? nekoji Power Systems 32 Oct 17, 2011 01:41 PM
Discussion What Happens The Champ Flies in a Super Windy Day! TheLeabres Beginner Training Area (Aircraft-Electric) 4 Sep 30, 2011 12:34 AM
Discussion Raboesch vs. Prop Shop of England vs. Rivabo props- xx29l9 Scale Boats 9 Dec 02, 2009 05:40 PM
Load of E-Prop Vs Cam props Vs glow prop chronos333 Power Systems 6 Oct 10, 2005 12:01 PM
