Old Oct 17, 2011, 06:21 PM
cass3825 is offline
Find More Posts by cass3825
Joined Feb 2005
WiiTOL, MultiWiiCopter based VTOL software
With the enormous following of Alex's code for multicoptors built around the Arduino Pro Mini / Wii Motion Plus combo, it was only a matter of time before folks started building VTOLS around this affordable and flexible platform. RCvertt, leadfeather, and foam and tape have all ventured down this path. It has been an exciting adventure to watch their builds unfold, and to help with the code development along the way. I had the pleasure of working alongside leadfeather in the evolution of his F-35, manipulating the code based on his feedback. There are two tri-copter templates available (one with tail motor yaw control, one with individually tilting front motors for yaw control) as well as a quad-copter template (yet to be test flown!). We are working towards having Alex include the VTOL models in the standard code, but for now it is available as a branch and can be downloaded here. This thread was created as a starting point for those who wish to build an Arduino based VTOL of their own, to take what we've done and expand on it, to ask questions and offer up ideas to better the code, and to show off your WiiTOL creations!
  • Overview; resources required to build and fly a VTOL
Building and flying a VTOL (except tail sitters) is not easy, but it can be very rewarding if you succeed. Here are some resources and skills you may need:
Patience and the ability to plan and think ahead
Materials such as foam, tape, glue, carbon tube; and a place to work
A computer for running the required software; Java, Arduino, Multiwii
RC aircraft airframe scratch building or kit modifying ability
Tools: basic hand tools, drill, soldering iron, others????
Flying skills: 4Ch helicopter and 4Ch fixed wing proficiency, recommended that you build and fly a multicopter first before VTOL
A good radio and some cash
  • Software, links and step by step instructions
Download the Arduino software here. This will allow you to open, modify and download the .pde files (commonly referred to as 'sketches') to the Atmel processor.
Download the latest VTOL sketch and graphical user interface (GUI) here. The first post of this thread includes some great links for wiring and board orientation.
  • Building or buying a good breakout board
The most basic setup consists of an Arduino Pro Mini 16MHz from Sparkfun (as well as many other vendors) and a Nintendo Wii Motion Plus add-on module. Good places to find these are pawn shops and game resellers. Ebay is another source, but many modules sold are clones and performance varies. A USB to FTDI adapter is also required to download sketches.
Here is a great tutorial on how to assemble the components above.
Several members here on rcg (Warthox and JussiH to name a few) have created 'shields' to ease the burden of wiring the receiver, Wii Motion+ and esc's to the arduino. Yet another option is an all-in-one board, which includes the processor, gyros and accelerometers all on one circuit board, therefore minimizing wiring for a neat installation with a small footprint. My personal favorite is the MiniWii from ViaCopter.
  • Airframe considerations
  • power and electronic considerations
  • Building protocol to minimize pain (matching software and airframe, matching hover and forward flight cg etc.)
Building protocol to make it as easy as possible:
1) Make sure the Wii board is installed in the correct orientation if possible. Cass has now mad it easy to compensate for non-standard orientations.
2) Determine the fixed wing cg. This is not changeable without airframe changes so it becomes the anchor for your design. Design the helicopter portion to coincide with the fixed wing cg.
3) Set up the copter/hovering operation first... before installing any of the servos for the control surfaces or the tilt servos.
3a) Copter: Make sure the gyros are providing the proper control corrections. Low throttle, props off to check this. If everything is whacky recheck the Wii orientation or change the orientation in the code.
3b) Copter: Make the required reversals in Tx for each channel (if required) for proper control response; roll left input give copter roll left etc.
5) Test the tilt servos for proper direction before installing to the airframe, then install.
6) Ready for test hovering. If hovering is good and controls correct proceed. Get the yaw trimmed by mechanically adjusting the tilt of the fans. Save the rudder Tx trim for forward flight.
7) Before installing control surface servos check direction of movement and place the servos accordingly to get coordinated hover/control surface movement.
  • Tuning and tweaking
Tuning:
1) Adjust pitch and roll trim for hovering (if required) in the Tx. Then set the control surfaces to neutral with the hover "trimmed in" and the sticks neutral.
2) Adjust the yaw in the Tx so that the motors pull equally in forward flight. Do this by taxiing and get the jet to taxi straight, especially at high throttle. Mechanically adjust the tilt servos to get neutral yaw in hover, never use the Tx to trim the yaw hover as it will mess up the forward flight.
3) In hover flight the front motors can be tilted slightly forward to give a slight nose up hover; looks scale. For fast hover the motors should be tilted about 45 degrees forward. In forward flight, the fans should be pulling in line with the wing.
4) I use a little offset in all my motors to counter prop torque when not using counter rotating fans. Each of the three fans are tilted a little to compensate for this torque. In forward flight I retain the main motor offset to; again; compensate for prop torque in forward flight.
If you decide to add accelerometers (Nunchuk, etc.) then here is a great tutorial on how to tune autolevel.
cass3825 is offline Find More Posts by cass3825
Old Oct 17, 2011, 08:17 PM
Tifani is offline
Find More Posts by Tifani
United States, IL, Park Ridge
Joined Apr 2010
Hi !
Thanks a lot - great work.
To complete full fly controller we need only WiiFixWing = ordinary airplane.
Tom
Tifani is offline Find More Posts by Tifani
Old Oct 17, 2011, 09:36 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
I think a complete "how to" would be useful for guys getting in to VTOL. I think this may need to be be a sticky thread
leadfeather is online now Find More Posts by leadfeather
Old Oct 17, 2011, 09:43 PM
Tifani is offline
Joined Apr 2010
Originally Posted by leadfeather View Post
i think a complete "how to" would be useful for guys getting in to vtol. I think this may need to be be a sticky thread
+++1
Old Oct 17, 2011, 11:40 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
+++2
I found it pretty difficult to understand the arduino stuff. A sticky and an updated how to would be very awesome! oh, and does anyone have a good how to guide on the multiwii GUI , I still have alot of questions on what it does and how it works?
foam and tape is offline Find More Posts by foam and tape
Old Oct 18, 2011, 05:56 AM
Winging it >
Joined May 2006
Here is an outline of what I think a "how to VTOL with Wii" should include.
I think the GUI really needs a good video to demonstrate how to use it.
Old Oct 18, 2011, 08:53 AM
cass3825 is offline
Joined Feb 2005
Excellent suggestions! I will get busy rounding up the software and electronics related items, but will need help with the VTOL airframe/building items. I know the code inside out, but I'm not much of a builder or pilot! In fact, it's my lack of piloting skills that got me interested in building/programming Arduino based flight stabilization systems!
Old Oct 18, 2011, 10:03 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Good point,Sir!!!!!
nadine is offline Find More Posts by nadine
Old Oct 18, 2011, 05:31 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Dan,
I can see you have really thought this out. I'm subscribed and eagerly looking forward to what you and Billy put together.
Bob
bobandris is offline Find More Posts by bobandris
Old Oct 18, 2011, 09:27 PM
cass3825 is offline
Joined Feb 2005
I have edited the first post to include the suggested "how to" list, and have begun filling in the blanks. I will continue to add to this based on all of your input!
Old Oct 18, 2011, 10:16 PM
Winging it >
Joined May 2006
This is gonna be a really useful thread. I'll pitch in where I can.
Old Oct 18, 2011, 10:25 PM
beavercreek,ohio
Joined Jan 2007
hmmm, I may be able to contribute on the airframe considerations, question is what all would I put in a video?
Old Oct 18, 2011, 11:42 PM
Tifani is offline
Joined Apr 2010
Hi !
Some time ago I was playing with gyro only bicopter/VTOL but have to postpone it due pitch instability. I will come back to project with WiiVTOL controller.
In my build log http://www.rcgroups.com/forums/showthread.php?t=1413924 is some pictures and videos, I will add new pics. this weekend (I have changed motor tilt plane to be closer to prop. plane)
Regards
Tom
Old Oct 19, 2011, 06:42 AM
Winging it >
Joined May 2006
Here is something to get this section started:
  • Patience and the ability to plan and think ahead
  • Materials such as foam, tape, glue, carbon tube; and a place to work
  • A computer for running the required software; Java, Arduino, Multiwii
  • RC aircraft airframe scratch building or kit modifying ability
  • Tools: basic hand tools, drill, soldering iron, others????
  • Flying skills: 4Ch helicopter and 4Ch fixed wing proficiency, recommended that you build and fly a multicopter first before VTOL
  • A good radio and some cash
Old Oct 19, 2011, 06:53 AM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
This quality being the biggest one needed : Well next to CASH and lots of it
v22chap is online now Find More Posts by v22chap
Discussion RC VTOL based on Osprey r.Scott VTOLs 0 Jan 16, 2011 10:39 PM
Discussion Sim for custom made Ducted fan based VTOL ? ashvani Simulators 10 Jan 24, 2007 01:56 AM
Discussion My VTOL Project-Based Around Osprey Osprey WannaB VTOLs 27 Apr 09, 2006 07:19 PM
